Question about Nvidia GeForce FX 5500 Video Card Graphic Card
I want a download driv boot ge force fx5500 256mb 32-bit
Posted on Jul 03, 2011
  • 922 Answers
How do i load a34bit onto a 64 bit system ?
Normally, a 32-bit program will run fine on a 64-bit system. However, a 64-bit program will not run on a 32-bit system. In a 64-bit system, there are sometimes two directories for program files, one for 32-bit programs and one for 64-bit programs.
If you are trying to load a 32-bit operating system over a 64-bit operating system, I think you loose everything on the 32-bit system, so make sure that you backup all your files. Another alternative would be to make a dual boot system, where when it boots up, you have the choice of going into the 32-bit system or the 64-bit system.
Good luck,
Paul
Mar 26, 2016 | Computers & Internet
How do i get floppy disk to run on windows 7..
Your computer is running a 64 bit Operating System. This means it is compatible only with 64 and 32 bit software. It is extremely likely that the floppy disk your are trying to use contains 16 bit software which was common in during the era of floppy disks.
The solution is to use VMWare, Virtual Box, or similar software to virtualize a 16 bit compliant operating system.
Jul 27, 2012 | Sabrent sbt-ufdb SBTUFDB USB external 3.5...
My laptops cant open when you turn it on, but if you put in a cold place it will open when you push the on/off button
Usually the problem is with the video card. You might need to have it serviced/replaced. Try booting in Enable Basic video driver:
1. Turn the computer on 2. Tap on F8 as the computer boots up 3. you will get the advanced boot option 4. Choose enable basic video driver
Once you have booted the computer, you will notice all the icons will be larger. Go to support.dell.com and try to look for the driver list for the model type of computer that you have. Download the latest chipset and the latest video card driver.
Things to take a note of:
1. Check the driver that is compatible with your operating system 2. Make sure you know if your OS is 32 bit or 64 bit. Download the appropriate driver.
To check on the type of operating system
1. press on the windows button + R 2. type msinfo32
check on the Operating system
if it says x86, it means that it is a 32 bit OS if it says 64 then it is 64 bits
Jun 28, 2011 | Computers & Internet
Looking for ge force 8600 agp driver
You can find your driver here:
http://www.nvidia.com/Download/index.aspx?lang=en-us
Select your operating system 32 or 64 bit.
Be sure its the rigth software because there is 3 models.
Good luck.
Feb 21, 2011 | Computers & Internet
I'm trying to upgrade from 64-bit Vista to 64 bit Windows 7. When I run the installation disk, I'm getting the following error message, which appears to be contradictory in my opinion:...
I have seen this type of problem before, the only real way around it is to install a fresh copy of windows 7 not to upgrade, you will receive a message that asks you if you want to keep the previous windows in a folder called old windows, from there you will be able to access all your old files and programs, be aware though some programs may not work on windows 7, and you may need to have updated drivers for the systems peripherals. So when you run the windows 7 disk choose clean install and go from there. i hope this helps
Feb 04, 2010 | Microsoft Computers & Internet
Dryer squeaks when drying clothes
try letting the mouse out??? its likley to be the drive belt or rear bearing dry,,, could be the motor bearings dry,,
back bearing and motor bearings could be lubed with WD40 but dont put it any were near the drive belts as they will then slip like mad,
spray on the driv belt a bit of "stop squeak" its for car fan belts realy but it works on any rubber belt
Oct 24, 2009 | GE DRSR483ED Electric Dryer
GE wireless optical mouse #98763 worked for 2 weeks then.........
http://www.microsoft.com/hardware/download/download.aspx?category=MK
Jul 19, 2009 | GE Optical Mini Wireless Mouse 98793
Promble with Ram
No the problem isn't the ram, or video card, or lack of video cards.
The problem stems from using a 32 bit O/S, (Operating System), like Windows XP Home, or Windows XP Pro. (The 32 bit version of XP Pro. Microsoft made a 64-bit version of Windows XP Pro)
A 32 bit O/S will only 'recognize' UP TO 3.2GB's of ram. (Sometimes up to 3.5GB's)
You need a 64 bit O/S so that your computer will recognize all 4GB's of ram, when it is installed.
32 Bit? 64 Bit? What is all of this? It's kind of hard to explain in a few sentences. I would like to refer you to these links on Wikipedia, to explain 32 bit, and 64 bit further,
A.32-Bit:http://en.wikipedia.org/wiki/32_bit
B.64-Bit:http://en.wikipedia.org/wiki/64-bit
Jul 14, 2009 | Computers & Internet
ATI Radeon X1300 wont work with my Vista 32 bit
Try this.
Download the unified Radeon drivers from ATI's website... do not use Windows update. Get the Drivers Only package. for Vista 32-bit
If you can get to the desktop:
Uninstall the existing display drivers by using the remove hardware utility. Whatever they are... remove them. Reboot. Windows will try to reinstall the drivers on the next boot. If it allows you cancel the installation at any time during install do it. Run the downloaded package from ATI. Reboot.
If you can't get to the desktop:
Press F8 when booting and enter safe mode with networking. Download the ATI drivers from ati.com for Vista 32-bit.
Uninstall the display drivers. Reboot. Should take you to the desktop on the next boot so you can run the install program.
Jun 22, 2008 | ATI RADEON X1300 Pro 256MB PCIE Graphic...
Nvidia GeForce FX 5500 Video Card Graphic Card Logo
124 people viewed this question
Top Nvidia Computers & Internet Experts
David
David
Matthew Spark
Matthew Spark
Are you a Nvidia Computer and Internet Expert? Answer questions, earn points and help others
