Question about Keurig Special Edition B60 Coffee Maker
I lost my manual. How do I de-scale? Does this not allow you to brew a cup until it has been de-scaled?
    Problem Solver:
  • 13 Answers
From http://www.keurig.com/customer-service/brewer-registration-and-support/~/media/Files/Keurig%20Brewer%20Manuals/De-scaling_instructions.ashx
To begin, you will need the following:
  • 48 ounces of undiluted white vinegar
  • Large ceramic mug (do not use a paper cup)
  • Access to an empty sink
PREPARE Step 1: Empty the water in the Water Reservoir. Step 2: Disable "Auto Off" features.
FILL AND CLEAN Step 1: Pour approximately 48 ounces of the vinegar into the Water Reservoir. Step 2: Place a large mug on the Drip Tray Plate and run a brew cycle. DO NOT USE A K-CUP, just press the BREW Button. Pour the contents of the large mug into the sink. Step 3: Repeat the brew process without a K-Cup until "ADD WATER" is indicated. Step 4: Now let the Brewer stand for at least 4 hours while still on. Step 5: Discard any residual vinegar and rinse the Water Reservoir thoroughly.
RINSE Step 1: Ensure the Water Reservoir is filled with fresh water. Step 2: Place a large mug on the Drip Tray Plate and water brew cycle. Pour the contents of the large mug into the sink. Step 3: Repeat brew process until "ADD WATER" is indicated. Step 4: You may need to perform additional water brew cycles if you notice any residual taste. NOTE: If "DE-SCALE" is still displayed after completing the procedure, repeat the de-scaling procedure above.
Posted on Mar 17, 2011
Need instruction book for Cuisinart Single Serve Brewing System Model # CUISS-700
Here are the instructions to de-scale your Cuisinart SS-700, taken directly from the unit's manual, available here (www.cuisinart.com/share/pdf/manuals/ss-700.pdf):
1. Empty the reservoir.
2. Disable the AUTO OFF and OFF TIME features.
3. Making sure there is no K-Cup in the brewing chamber, fill the reservoir with 60 oz. of undiluted white vinegar.
4. Place a large mug on the drip tray and run a Hot Water cycle. Select the 12 oz. brew size. Discard contents of mug.
5. Repeat the hot water process until ADD WATER is displayed on the control panel and the reservoir lights will flash.
6. Let the Brewer stand for at least four hours while still on.
7. Rinse the water reservoir thoroughly and fill with fresh water.
8. Run another Hot Water cycle. Discard contents of large mug.
9. Repeat hot water process until ADD WATER is displayed on the control panel and the reservoir lights will flash.
10. You may need to perform additional Hot Water cycles if you detect any residual vinegar taste.
Note: If DE-SCALE is still displayed on the control panel after completing the procedure, repeat the de-scaling procedure above.
If you found this solution helpful, please leave a positive rating!
Sep 17, 2012 | Cuisinart SS700 SINGLE SERVE BREWING...
Brews about half a cup of coffee. i have tried the paper clip many times
Sorry to read about your issue.
The brewer should be de-scaled at least every 3-6 months. Scale is harmless, but if left unattended, it can hinder optimal brewer performance. De-scaling your brewer regularly helps maintain the heating element, removable water reservoir and other parts of the brewer that come in contact with water. Better water quality and water heating means a better cup of coffee, tea, hot cocoa or iced beverage. We recommend de-scaling your brewer at least every 6 months (every 3 months if your water has a high mineral content). The de-scaling process involves using 48 ounces of undiluted white vinegar.
Take 48 oz of white vinegar. place in tank. pretend you are making coffee (Do No Use K Cup). let the water fill you mug. then empty that mug. Do it again until tank is empty. then let sit for 4 hours.
Then fill with fresh water to the top. let that tank of water run thru. towards the end taste the water.
If you taste vinegar..use more clean water, until the taste is ok.
I tried to help you. Please help me and Vote/Rate this response. Thanks and good luck
Dec 25, 2010 | Keurig B100 Coffee Maker
After many uses, the cups are starting to get much smaller. when you brew a normal size cup, it comes out at about half the size of what it was previously
Dec 22, 2010 | Keurig B70 Coffee Maker
My Keurig B60 SE has recently started brewing k-cups very, very weak. I have a filter that I can put coffee in and that works fine, and I've even found that when I put the coffee from a kcup into the...
Sorry to read about your issue. plus you may have a bad k kups
Dec 22, 2010 | Keurig Special Edition B60 Coffee Maker
I'm only getting 1/2 cup of coffee each time I brew. I've changed the filter. What should be my next step?
Their is no filter on the b40 so i dont know what you mean about that.
you model may have one or two brew size 10oz and 8 oz take a kitchen measure cup and check it
Dec 21, 2010 | Keurig Elite B40 Coffee Maker
Hi! Quite often, when I put a K-Cup in to brew, the Keurig will attempt to brew but just continues to make a humming sound and nothing will come out. I try turning off the power, just opening the lever...
Dec 21, 2010 | Keurig Special Edition B60 Coffee Maker
Sometimes it brews but most of the time it will not. It says ready but still will not brew. Help
Take 48 oz of white vinegar. place in tank. pretend you are making coffee (Do No Use K Cup). let the water fill your mug. then empty that mug. Do it again until tank is empty. then let sit for 4 hours.
Dec 21, 2010 | Keurig B70 Coffee Maker
Keurig coffee maker makes loud noise single cup brewer. Make loud noise prior to brewing.
Dec 20, 2010 | Keurig B60 Coffee Maker
THE MACHINE ONLY BREW 1/2 OF THE LIQUID.THE WINDOW READS/BREWING/BUT THE LIQUID STOPS.I GOT TO SHUT THE MACHINE OFF,THEN ON,TO GET ANOTHER 1/2 CUP,BUT SOMETIMES DOES WORK AT ALL.
Dec 19, 2010 | Keurig Platinum B70 Coffee Maker
Sometimes will not brew even though it says it is brewing, then when pushed again, gives out too much. Other times gives only an inch in the cup at a time.
34m34m4
Dec 19, 2010 | Keurig B100 Coffee Maker
Keurig Special Edition B60 Coffee Maker Logo
764 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Oloyede Monsuru
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
