Question about GE Dryers
Want to change the timer cam to increase the time for the coin operated dryer. Need instructions to change the timer cam for DMCD330GJWC Gas Commercial Dryer and the digital panel.
  • 1314 Answers
SOURCE: I NEED FAULT CODES FOR DRYERS
PF Power Failure
“PF”
flashes to indicate that a power failure occurred while the dryer was
running. Press START to continue the cycle, or press PAUSE/CANCEL to
clear the display.
F-01 Primary Control Failure “F-01” flashes when there is a primary control failure. Replace the machine
control electronics. See Accessing & Removing the Electronic Assemblies.
F-02 Keypad/User Interface
Failure
“F-02”
flashes when there is a stuck button or user interface mismatch. This
fault code will ONLY appear when in the diagnostic test mode. See TEST #5.
F-22 Exhaust Thermistor Open “F-22” flashes if the thermistor is open. See TEST #3a.
F-23 Exhaust Thermistor Shorted “F-23” flashes if the thermistor has shorted. See TEST #3a.
F-26 Motor Drive System Failure “F-26” flashes if there is a motor drive system failure. See TEST #2.
F-28 Moisture Sensor Open “F-28” flashes if the moisture sensor strip is open. This fault code will ONLY
appear when in the diagnostic test mode. See TEST #4.
F-29 Moisture Sensor Shorted “F-29” flashes if the moisture sensor strip has shorted. This fault code will
ONLY appear when in the diagnostic test mode. See TEST #4.
1M 2M 3M 5M 6M
= Contacts closed
Contacts
Function
Start
Run Red
Lt. Blue
Blue-White (Elec)
White (Gas)
Green-Yellow
Red
Black-White
BLACK
BLUE
WHITE BLUE
WHITE
WHITE
Pluggable Drive Motor Switch Gas Valve - Gas Dryer
Centrifugal Switch (Motor)
Gas Valve this is about close as i can come its matag electronic but not comercial should be about the same software though some where on or in the dryer should be a tech sheet with codes
Posted on May 21, 2008
aborcass
  • 2651 Answers
SOURCE: Coin-op dryer: changing the length of the cycle
that is correct, there a re multiple "cams"/discs that will increase/decrease times, they should be inside the lock box atop the machine, they come with the unit when delivered and that s the likely storage spot for them
Posted on Mar 25, 2009
Healeyman
  • 1198 Answers
SOURCE: Coin-operated dryer won't turn off at end of cycle.
A dryer timer is a real simple device. Take the whole thing out and give it a good inspection. A little wd 40 can do wonders. A bad coin in the works can jam it on. Put a coin thru the works, watch the action. The timer motor can fail or get stuck, spray and test.
Posted on Apr 22, 2009
Illeagle
  • 525 Answers
SOURCE: commercial dryer coin op programming
Below is Maytag's commercial laundry website where you should be able to acquire the information requested.
http://www.maytagcommerciallaundry.com/content.jsp?pageName=CustServ
Posted on Jul 17, 2009
SOURCE: maytag coin op dryer timer programming for mde-16cs
The maximum run time on this machine's timer is 54 min. There is an adjustable peg on the white plastic index wheel which you can adjust anywhere from 30 to 54 min. For example peg in position E is 30min, D is 36min, C is 42min, B is 48min or for 54 min you have to remove the adjustable peg completely, but don't lose it in case you want to change the time in the future. If it is already in the Max "A" position and shuting off early you might have to change your torsion return spring. Hope this helps
Posted on Feb 01, 2011
How do i increase drying time coin operated kenmore model 110.60172001
in the coin box adjuct the timer by a set screw
I’m happy to assist further over the phone at https://www.6ya.com/expert/james_1cb31da1bc8c6102
Nov 20, 2013 | Kenmore 500 6952 Dryer
The duration on commercial kenmore coin operated dryer isn't long enough to dry the clothes. How do i lengthen the cycle time?
Some dryers require timer cams to extend the cycles. The electronic dryers are programmable. The owners manual will tell you how to change the times. The owners manual can be downloaded at www.searspartsdirect.com.
Kelly
Mar 21, 2011 | Dryers
We have a maytag dryer that is coin operated in our home. We want to shut the coin operated part off. how do we do that?
remove change acceptor usually 5/16 stud bolt in timer mechanism, theb remove change slot stops and reinstalll mechanism and bolt then just push in and pull out just like if you would of used change but dont need two
Jan 31, 2011 | Maytag Coin Operated Stacked...
Change the number of coins to operate
you need to take the coin slot apart take pictures as you go to put back together the parts to change amount are hidden inside it in hidden compartment if they wheren't removed by some one. your machine didn't come with the coin mech so if you don't have the parts you will need to take it with you to the parts house to get right parts. open the top of the coin mech box there are 2 long rod screws holding it in place usually 5/16 inch wrench fits may need to wiggle the heck out of it to get it out
Dec 31, 2009 | Maytag Neptune MAH5500B Front Load Washer
Mar 25, 2009 | Whirlpool ET8CHEXSQ Dryer
I have a coin op dryer modle cem2760kq0 i put im a new timer in but it dose not stop runing?
mechanical coin op timers come without the shut off cam installed
there are slots around the edge corresponding to different times, that take a pin cam. the pin cam is in the box for the installer to insert to the owners specification, between 24 and 60 minutes in 6 minute intervals usually, hope you retained the packaging, or the old timer which should have its cam pin still in it
electronic coin op timers have to be programmed
Aug 28, 2008 | Whirlpool Dryers
Find a manual
The coin operator timer consists of several small plastic gears. The teeth on the last plastic gear gets all chewed up so that the timer continues to run and unable to open the circuit which stops the dryer timer. Although the plastic gear probably costs pennies, your will need to order part number 33001275 torsion timer for about $75 - $110. Remove one screw & 3 clip-on wires - 15 min.
Mar 06, 2008 | Maytag MDG16CS Gas Commercial Dryer
Maytag coin op dryer timer programming for mde-16cs
Jan 06, 2008 | Maytag MDE16CS Electric Dryer
Dryers Logo
147 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
