Question about Sony 900 Mhz Babycall Nursery Monitor Ntm 900
My Sony BabyCall monitors make a constant clicking noise. Changing the channels didn't fix the problem.
Bought this 42" lcd April of 2012. When changing
Try unplugging set and or a box if used for a while and then plug power back to allow units to reboot to see if that will help--a box can cause odd issues.....
Nov 04, 2012 | Televison & Video
High pitched noise coming from TV
could either be the speakers on the tv packing up and the only best way to fix this either take it into a shop to get repaired or just bin and get another one depends on how much it would cost to fix
May 18, 2012 | Memorex MT2206 TV
How do i stop the range alarm?
If the out of range alarm is beeping the batteries may not be powerful enough or there is too many walls between transmitter and receiver.
Mar 10, 2012 | Sony 900 Mhz Babycall Nursery Monitor Ntm...
I have a Sony Bravia XBR 4 LCD. I connected a RCA cable to my Denon 3805 monitor out and RCA to the Sony video 2 in.I want to set up the Denon using the Sony as a monitor to set up my speakers. The screen...
Make sure you didn't get the video line out confused with one of the audio lines.
If using composite video the connection should be yellow and the left and right
channels should be red and white
May 16, 2011 | Denon AVR-3805 Receiver
Hi, my baby monitor is making a constant pulsing noise. It's like a little surge that happens every two seconds. It almost sounds like a heart monitor at the hospital. I have had the monitor for about a...
We have the same exact problem on both channels. It has worked perfectly for a year and a half but now it has a constant pulsing. Summer is our brand too.
Jun 28, 2010 | Summer Infant Day & Handheld Video...
Clicking noises coming from monitor with hdmi cable attached to computer have no problems with other connections that came with monitor
Try getting a video card, if not look for a new monitor.
Reason i say get a video card your motherboard is probably working to hard depending on how old your pc is. When getting the video card it takes stress off the board when monitor is plugged into video card.
Apr 21, 2009 | Computers & Internet
Constant RX mode on Cobra Microtalk Walke Talke
I have the same walkie talkies and on mine I can hold down the mode/lock button and it will come off of the Rx mode. Also, you should be able to press the talk button and it will come off of the Rx mode.
Jul 06, 2008 | Cobra PR4100-2WXVP 2-Way Radio
Open Questions:
Sony 900 Mhz Babycall Nursery Monitor Ntm 900 Logo
524 people viewed this question
Top Sony Baby Gear Experts
Owen Barnes
Are you a Sony Baby Gear Expert? Answer questions, earn points and help others
