My guitar processor (digitech RP70) is softly buzzing but no audio or lights come on, hopefully not the transformer (only part i know.) Also, when I felt around, this one small circutboard part (having 2 black rectangular parts [clamped top to bottom] in front of the power supply plugin [circ board space labeled "D3"]) get's really hot. I've just had it sitting a few weeks and now it doesn't work. It that just somthing like a small part replacement,maybe the part that's hot?....... oh and also my alarm was fried during a lighting surge or something........Is that a simple fix? (maybe like ordering a trnsformer and soldering it?) thanks jim :)
soldierruel
  • 175 Answers
SOURCE: Problem with Gateway Plasma TV power supply
Mate i think you'l have to buy a new one and save this one for parts if something does go wrong with your new one.
Posted on Jun 20, 2006
SOURCE: broken headphone jack
hmmmmmm.i wiould suggest going to a proper shot that can do it for you better than stuffing it up more :)
Posted on Jul 25, 2007
SOURCE: Headphone jack
http://esupport.sony.com/perl/news-item.pl?news_id=244&mdl=NWS705F
will repair free
Posted on Apr 17, 2008
  • 3 Answers
SOURCE: PT-53X54J Power Switch Flashing Red and more...
think it's the projection bulb, easy to replace yourself
Posted on Jun 04, 2008
SOURCE: Sansa E260
my sandisk e260 4.0 gb will turn on to the screen where it sais "sandisk" and the blue light is on, but it wont do anything after that, it like just freezes everytime. i tried holding the power button to reset it but it still does the same thing.
Posted on Oct 20, 2008
The lights are on but nothing is coming out,, no voice no guitar nothing???
Double check all your settings, then do a reset. If that doesn't work it will need to go to the shop. Here is the Digitech contact page to ask them or to find a service center-
Support DigiTech Guitar Effects
Apr 01, 2015 | DIGITECH Vocalist Live 5 Vocal Harmony and...
My DigiTech RP355 turns on but only buzzes
Sounds like a classic ground-loop issue. Sound-on-Sound had a great article some time back that may help you.
Apr 10, 2014 | Music
I have a Digitech RP70 guitar processor. Both of the foot switches are garbage! Can they be replaced?
I also have an RP70 with the same problem. You can fix it, but know what you are dealing with. I love the sounds I can achieve with the unit (hard to replicate). Open the unit up by removing 4 phillips head screws on bottom and remove plate/cover. The poor design is the rubber snubbers on the inside of each plastic foot switch. The rubber snubbers press against switches that are part of the circuit board. You have a few ways of adjusting the foot switch tension: 1. Tighten or loosen the 2 screws of the circuit board closest to the foot switches and check the response; 2. If that doesn't work, insert tiny washer (s) under the rubber snubber(s); 3. I did all of the above and continued to have inconsistent responses until I just left off the bottom cover which effects stress on the unit's frame. I keep it on a very level location and have had no more problems.....except, it is exposed to the dirt etc.
Mar 23, 2011 | Digi-Tech DIGI TECH Replacement Battery...
The foot pedal (not the switches) on my "DigiTech RP90 Modeling Guitar Processor does not work...it will move but it changes nothing.
All DigiTech expression pedals use an optical system instead of potentiometers.
Either the light is broke, or the filter.
The filter protrudes from the bottom of the pedal, and is darker at the top and gradually fades to clear at the bottom. If this breaks off, then there's nothing to limit the amount of light to the optical system.
If it is the light, then you'll have to have it serviced by someone qualified to work on it. Your local music shop should be able to help you out.
Hope that helps!
Jan 13, 2011 | Music
Vocalist live 2 problem. power to unit OK , lights up. Guitar output OK. No tuner, no vocal output.
NO power light or audio from Digitech Vocalist 2 live. Check that your power adapter is for 9 Volts AC (not DC like most pedals) and is rated at 1300ma or more. A DC adapter MAY light up the unit but not make it pass audio. Lights can be lit but that is NOT an indication thaat correct power is applied. They likely use the AC input to generate both positive and negative voltage within the unit. The use of a DC adapter will prevent generating one of these required voltages and prevent audio from passing.
Jan 13, 2011 | DIGITECH VOCALIST LIVE 2
Hi having trouble when i plug guitar or mic into the neo. when i raise the trim to hear the input, the re is a big buzzing sound that just wont go away... any ideas?
Do you have any light dimmer in the house?
Are you using humbucking guitar pickup?
Do the the buzz change when the move the guitar around, it may be picking up radiate magnetic field from the transformers of the equipment.
The preamp is very sensitive with very high gain circuits that amplify signals in the millivolt range, so godd shielding and grounding is needed.
Dec 31, 2010 | Audio Players & Recorders
Hiwhat is the best way to connect my DigiTech RP10 to my Marshall MA100H Guitar Amplifier
Read your manuals for both pieces of gear carefully first. You only have one amp so you won't be able to take advantage of all the FX on the Digitech as a lot of them are designed for stereo. The Digitech manual shows guitar into the Digitech and output from the Digitech into input of any guitar amp. Since you have a Marshall and can already get some great sounds by running your guitar straight into the Marshalls input, you would probably be better off using your Digitech in the FX loop. Run a guitar cord out of the send on the loop into the input of the Digitech and a guitar cord out of the left / mono output jack on the Digitech into the effects return jack on the Marshall. Start out with the effects level on the Marshall all the way down. Do the same with the Digitech with both the input and output levels. (Read the manual carefully) I think the choice of the Digitech isn't that great because it is already trying to reproduce a lot of what you can already get with just your Marshall but with a little experimentation and some careful adjustments you should be able to add to the sound of the Marshall. Hope this helps.
Oct 23, 2010 | Marshall MG100HDFX 100-Watt Amplifier Head
Need printable manual for digitech rp50 multi effects guitar processor
ftp://ftp.digitech.com/pub/PDFs/Manuals/RP50%20Manual%2018-1396V-A.pdf
Aug 18, 2010 | DIGITECH Audio Players & Recorders
No vocal sound
It sounds like the guitar level input to the unit is too low.
NOTE: With this product you MUST use an amplified or electric guitar that has a preamp within it.
If you have a straight guitar that does not have an amp in it, buy a preamp to first run the guitar through.
Apr 26, 2010 | DIGITECH VOCALIST LIVE 2
Digitech RP3 Guitar signal processor only lights up.
Check that connectors are seated AND the input and output are correct.
Sometimes1/4 inch plugs are not seated correctely. The power adapter plugs are notorious for not making contact.
Oct 26, 2009 | Music
98 people viewed this question
 Grubhead
Grubhead
