Push button for windshield , will not go up or down. the scooter did fall over no damage. but after that the windshield will not operate.
  • 17,130 Answers
Please be specific on the vehicle specially the make and model of the product.
I am not able to understand if this is a scooter or a car but since your windshield wiper is not working you will need to start from the main switch . Also the mention of a fall could this mean that the line to the wiper circuit has come off or the fuse the circuit has blown.
You will require a check up with a multimeter to start the voltage check from the wiper switch to the wiper motor. If absent check on the fuse or the harness. If present and not working means that the wiper motor has failed or is struck/jammed.
Hope you clarify on these details.
Posted on Mar 17, 2011
When I turn it on an alarm sounds and won't stop. The scooter works well except alarm won't stop. It is as if you are pushing on the horn all the time.
hi Irene, sounds like you got water inside the button you push to activate the horn, the push button will need be dried out ....either by disassembly's or carefully placing a warm setting hair-dryer near the button and operate to get the water to evaporate .. but don't do it too hot otherwise the button will start to melt...
Regards
Rob
Apr 05, 2016 | Pride Go-Go Sport 3-Wheel Scooter
What to troubleshoot for in disconnected wire/s causing power shut down after a bump?
I would check the multi pin socket in the tiller is pushed in all the way. Check the underside of the scooter and track the cable to see if it is damaged anywhere. Where the cable comes up under the seat between batteries, check the plug on the end of the cable.
Also on the seat lift. Check micro switches as I believe the scooter will not run with the seat in the raised position. so check down switch first.
Oct 17, 2014 | Rascal 600 T Electric Scooter w Seat Lift...
Jazzy Select controller on-off switch (push button) very difficult to operate. Must push button down with much force to get it to work. Can I get the controller apart without ruining it?
The display on top of that joystick controller is essentially a fancy decal. it can just be peeled off. Usually when the symptom you're describing is happening it is because the button on the underside of the decal is wearing out. This can't be fixed. The joystick face must be replaced. However, you should be able to get this from a certified Pride dealer for 60 or 70 bucks versus several hundred for a new joystick controller.
Mar 27, 2013 | Pride Mobility Jazzy Select Wheelchair -...
When it rains puddles of water on the passenger side floorboards mostly in the back not coming from sunroof and theres a crack in my windshield thought it might be that but the dashboard is never wet so...
The cowl drains could be clogged. Trace from the opening at the base of the windshield down to door hinges and look for debris such as leaves in the opening behind the hinges. You may have to use a coat hanger as a special tool to remove the debris.
Oct 10, 2017 | Cadillac Catera Cars & Trucks
Have a Bolwell mobility scooter with the problem that it will not go. Battery indicator indicates fully charged but left indicator bar on battery display is flashing with a clicking sound near rear wheel...
Hi u mention the brake is off do u mean it's in freewheel if u can push the scooter it's in freewheel .push the lever into drive : when lever is in freewheel the scooter will not move..type in Google search ( bolwell mobility scooter manual ) .cheers
Jul 05, 2017 | Health & Beauty
Installing windshield mount
there are two pieces to the mount, the mount and the cradle..the cradle snaps on the gps and the mount slides in the groves on the back of the cradle.
to attach it to the window, lift the lever near the suction cup on the bottom of the mount..press firmly against the window, the push lever down toward the windshield to lock it.
you should remove it and reattach it every few weeks to prevent it from falling off the window and damaging the unit.
bill
Feb 28, 2010 | Magellan RoadMate 800 GPS Receiver
Sun Visors won't stay forward towards windshield
inside the sun visor there is a spring which is moving to side when you push down the spring pushes side so it will keep down when you want to push to the normal possition spring releces and keep to that possition any way i would like to advice you to replace sun visor.
Nov 28, 2008 | 2003 Toyota Highlander
Windsheild
125cc isn't a very big engine to push a scooter with a windshield. Adding a windshield dramitcally increases the load on that little engine. Kymco does have one and Your dealer can probably order it for you. You can also find it on http://www.kymcousa.com/access/windscree...
Nov 10, 2008 | 2004 Kymco Hipster 125
Garmin Street Pilot c340 mount
Try a hard reset using the reset button under the silver trim on the front. Pull off the trim ring by hooking your fingernail under it right below the logo.
If that doesn't work, then take the unit off of the mount for a better look at the contacts. Re-seat the mount onto the unit and see if that helped. If the mount is damaged, consider getting a friction mount instead of the suction cup. For about $40 you'd get new power contacts and a new cord, and the unit would sit on your dash instead of falling off the windshield all the time.
All of this is assuming that the problem occurred suddenly after a fall, and that your battery is still good.
Oct 13, 2008 | Garmin StreetPilot c340 GPS Receiver
Computers & Internet Logo
David Payne
David Payne
