Its locked and cd tray wont open - Audio Players & Recorders
    Sniper:
  • 54 Answers
When you give question, you have to offer what's model. different model, use different way to unlock tray
Posted on Mar 17, 2011
Y cd driver wont open
just push the button on cd tray... then the tray will open. if won't read then maybe your cd is damage or the cd drive got in trouble unable to read. try restarting your system.
Dec 22, 2012 | HP Compaq nx9420 Notebook
C.d.s get stuck and now tray wont close
The problem is in the loading bay, sometimes 2 CD's will get jammed locking up the system, or the timing gear is out of sync, or possible broken gears.
May 04, 2012 | Onkyo DX-C390 6-Disc CD Changer
CD tray wont open! how can i open it?
There is a small hole on the front of the drive. just push a straightened paperclip into the hole and it will pop open.
Mar 20, 2012 | Acer Aspire X1200-B1601A PC Desktop
Cd compartment wont open and it is locked dvp sr200p sony
Ensure the child lock feature is disabled. Try Power resetting the Player.
Turn Off the player and remove the power plug from the wall outlet for 1 minute and reconnect it and check the operation.
If the disc tray still does not open, simultaneously press the POWER + STOP + EJECT buttons.
If the disc tray still does not open, simultaneously press the DISC1 + STOP + EJECT buttons or the RETURN + ENTER+ POWER buttons.
If the issue still persists, service might be required.
Jul 26, 2010 | Sony DVP-SR200P DVD Player
The disc tray wont open its locked. I opened it up and tried to fix it. i see that there might not be any lubricant on the bearings. could that be it. but i don't think because it should be that cd trays...
already solved the problem two nights ago. there was a CD slot inside where the lens was at and it was in the way of the control arm " part that goes up and down to grab the cd's. Also there was one other problem and got that one done as well. The part that holds the CD in place was not right so i got it where i wont move.
Jan 28, 2010 | JVC HX-GX7 CD Shelf System
Dvd drive wont open , can hear motor working but drive wont come out. we believe the cd holder isnt shifting up/down to allow the drive to activate & open
Turn the computer off,Remove power cable.Use a peper clip insert it through a hole infront of the dvd drive this will eject the door.Make sure once this is opened the tray is aligned properly,slide it in and out.Push it in all the way then power up the computer.This may work for a while,before it goes again,so you might have to replace it.
Good Luck
Jan 17, 2010 | Lite On SHM-165P6S DVD RW Dual Layer...
CD ROM is jammed-wont open
This has happened to me. Sometimes when I'm in a hurry I'll place a CD or DVD in the tray and start to close it without making sure that the disk is seated flat in the tray. If it's ****-eyed the CD wil shatter when the tray is closed. The only way to remove the pieces inside the CD drive is to take apart the CD drive. Might be easier just to replace the unit. They run from about $25.00 to $75.00. One other note: You can try to open the tray manually by inserting the end of a paper clip into a small hole on the front bezel of the drive.
Oct 17, 2008 | E-Machines emachines (emachinees) CD-ROM...
My cd trays are locked and wont open on my jvc stereo model #Ca-Hxd77 system #Hxd77 and i dont know how to unlock it.
Most CD trays have a small hole at front for you insert a straightened paperclip about 1-2 mm inwards. This allows release of tray when power is off. I assume this is what you mean by mechanically locked, not locked by software.
Jul 11, 2008 | Audio Players & Recorders
Disc tray locked on JVC XV-N322
there is a small hole in the front of the tray that will accept a straightened paper-clip. gently insert the clip and the tray should release. if the cd/dvd disc is dislodged from being flat in the tray, it may not come out. you might need to open the cover and manipulate the disc to get it back flat in the tray. a good first test is to see if the disc plays. if it does, it is in the tray correctly and should be easily released with the paper clip. the try might work after you release it.
another possible first try would be to gently push inward on the tray after telling it to release. if there is extra tension on the tray it could cause the mechanism to not release. freeing the tension on the tray could be all that you need to get the 'unlock' to release. (kinda like trying to open a door when someone is pushing it very hard against the lock mechanism. it wont be able to move).
good luck
mark
Jan 03, 2008 | Televison & Video
 Grubhead
Grubhead
