I have a bar in the middle of my screen that says 2/25 pre system, please wait. it's been there for 4 hours now. i cant move it or shut it down.
  • 62 Answers
Turn off the machine pull the plug! and then see if you reproduce the effect on next boot
Posted on Aug 02, 2008
The bar that holds 3-5 app icons that is usually at the bottom of the screen, somehow got stuck in the middle of my screen and I can’t get it to move back down... help?
Whatever the device is, shut it down, wait a minute, then turn it back on. That should reset and fix things for you. Let's hope so.
Nov 05, 2017 | The Computers & Internet
Problems during Recovery of Factory Default Software
Don't stop the presses during recovery
its too bad to stop
wati more than 3 or 5 hours
cuz it depends on your pc specs
Dec 13, 2012 | Toshiba Computers & Internet
I cant pass a gate that it has two bottoms and one dead man
on the right take the dead man drop him in the water right beside were u pick him up at and run to the other side and wait for him to float around it will take around 10 seconds then pick him up and drop him on the pressure plate. then run to the middle jump on the second plate then it will take about 5 seconds for the gate to shut and that is plenty of time
Feb 22, 2009 | Sony God of War 2
Canon imageRUNNER C2058 color network printer board-B1 only. Upon power up the display screen indicates "Wait...".
The printer Board B1: you must shut it down by hitting the Options button and then selecting Function >Shut down > Shut down sytem>OK. Then power the machine off with the main switch. If the Customer has not been shutting off the machine properly and you get the please wait message you might try reloading system software first before replacing the hard drive.
Or = remove and reseat the printer board, if that doesn't work then you'll have to reformat the HDD unit and reload system software from a laptop. If the problem remains, the printer board may need to be replaced.
The Color Network Printer Board -B1 has a shut down function. It is for preventing corruption of the HDD. Be sure to turn off the main power switch after performing shutdown.
To properly shut down the Color Network Printer Board -B1:
1. Press the Option key on the control panel if the copier is in copier mode.
2. Make sure that the LCD reads Idle.
3. Select Functions on the LCD.
4. Select Shut Down from the Functions screen.
5. Select Shut Down System from the Shut Down screen.
6. The message 'It is now safe to power off the system' appears on the screen.
7. Power off the main power switch located on the lower right side of the copier.
* Note- After powering off the copier, wait at least five seconds before powering the copier back on.
Jan 25, 2009 | Canon imageRUNNER C2058 Led Printer
No display lights
Run the PSA Diagnostics and Obtain the PSA Error Code
To run the PSA diagnostics and obtain the PSA error code, perform the following steps:
Shutdown the computer.
Press and hold the <Fn> key, then press and release the power button.
Release the <Fn> key when the lock lights above the keyboard begin to flash or Diagnostic boot selected is displayed in the upper right corner of the screen.
Release the <Fn> key.
The PSA diagnostics sequence begins.
After approximately 2 minutes the system produces a number of alert tones.
After the alert tones, the system produces either a series of low beeps or error codes.
Note:
PSA diagnostics will prompt for input during some tests. The resulting error message does not necessarily indicate hardware failure.
For example, input is required during the color bar test. Failure to input a response will eventually result in a timeout error: 1000-0333 Graphics test timed out waiting for keyboard response. This does not indicate a graphics failure has occurred.
Note the sequence of beeps or error codes.
Initialize LCD BIST Diagnostics
You can initialize the LCD Built-in Self Test (BIST) in two ways, depending on the revision of Pre-boot System Assessment (PSA) diagnostics:
PSA versions 3019 and greater run LCD BIST immediately after failing the color bar test, via user input of <N> or waiting for it to time out prior to generating the 3-3-3 or 3-3-4 error. PSA version 3019 became available in November 2005 on various Dell laptops. The PSA version is upgraded with the BIOS.
With older versions of PSA diagnostics prior to November 2005, LCD BIST runs after responding with a <Y> after receiving a 3-3-3 or 3-3-4 error code.
To initiate the LCD BIST on PSA versions 3019 and greater:
Boot to the PSA Diagnostics.
Watch the screen and listen for the color bar test prompt tones emitted by the PSA Diagnostics. If the screen is visible, one will see the PSA diagnostics draw a series of multi-colored bars across the screen. When completed, a prompt asking if the pattern was seen appears, accompanied by a brief series of tones.
Press <N> or wait approximately 30 seconds to fail the color bar test.
Watch for the LCD BIST color generation and listen for the beeps every 2 seconds that indicate LCD BIST is running.
LCD BIST runs for approximately 20 seconds, then stops. The 3-3-3 or 3-3-4 error code is then displayed when the LCD BIST is complete. If LCD BIST does not initialize, then the system may not have been upgraded to PSA version 3019.
To initiate LCD BIST on systems with PSA versions prior to 3019:
The system emits a 3-3-3 or 3-3-4 PSA error after failing the color bar test. Wait for two iterations of the failure code and then press <Y>.
Note:
On a working LCD, the PSA diagnostics shows the following message:
Error Detected, continue testing? Yes or No or Retry.
Watch for the BIST color generation and listen for the single beeps that indicate LCD BIST is running.
Patterns of flashing color should appear on the screen. With every color change, an audible beep is heard. If the patterns of color do not appear, and the beeps are audible, an LCD failure may be the issue. If the patterns of color appear, a video card or motherboard failure may be the issue.
IF AN ERROR IS INDICATED, PLEASE CALL DELL SO YOU CAN SEND SYSTEM TO SERVICE DEPOT FOR REPAIR (WE'VE JUST TRIED TO ISOLATE ISSUE TO SEE IF ERROR IS CAUSED BY HARDWARE OR SOFTWARE, OR JUST SOME CONFIGURATIONS)
Thanks and Goood luck! =)
Jan 03, 2009 | Dell Inspiron 9100 Notebook
Acer Extensa 4420 -- Process: 2/25 Pre-System
i also had the exact same problem.....but i got rid of it .....the setup is not yet done so yeah all i did was :
1. make sure there are no start up applications ......like msn ......make sure noe program will open during startup
2. dont close the window that has black screen on it iunno wat that is.....i think its ms-dos or something anyways
3. ok then after that just dont touch your computer at all ..... just leave it there on
4. after a while you'll notice the 2/25 will become 3/25 then 4/25 ...yeah just leave it like that ....until its done
this process performed by the computer really takes a long time to do so ......
I really hope i helped =) have fun
Nov 16, 2008 | Acer Aspire 5100 Notebook
My new acer works fine but there is something loading in the middle of the screen and i cant get rid of it .... how ?
these are system set up routines, when you first boot up Acer laptops they configure themselves, then reboot about 4 times, to load all the drivers and pre installed software, but if its taking too long (hours) then you need to speak to Acer technical, see below for tel no.s
http://support.acer-euro.com/phone.html
Aug 29, 2008 | Computers & Internet
Vertical Black bar on the screen
What is the model number it sounds like pixel problems or board problems. For more info ctechnicians.com
Jan 06, 2008 | Televison & Video
Nintendo ds
Setting the Time and Date
Changing the time
  1. Remove all games from the Nintendo DS.
  2. Turn the system on by pressing the POWER button.
  3. Tap the screen using the stylus when the "Touch the Touch Screen to continue" message appears.
  4. When the main menu appears, tap the stylus on the Settings Menu Panel at the bottom middle part of the screen. icon_settings.gif
  5. Tap the calendar/time icon (the blue icon, second from the left). icon_clockdate.gif
  7. Tap the up or down arrows above the hour and minute to change the time. When finished, tap the "Confirm" button in the lower right corner.
  8. Wait for the the confirmation message to disappear, then tap "Go Back," then "Quit," then "Yes" to exit. The unit will shut down automatically to save the settings.
Changing the date
  7. Tap the up or down arrows above the month, day, and year to change the values. When finished, tap the "Confirm" button in the lower right corner.
Dec 30, 2007 | Nintendo DS Console
Computers & Internet Logo
23 people viewed this question
David Payne
David Payne
