Question about Lindhaus Diamante 300 Upright Vacuum
Lindhaus- replace hose to handle_ hose came out - difficult to screw back in-
Why does lindhause Activa 30 hose on vacuum comes off
My hose comes off as well. It gets 'unscrewed' over time using it. Simply screw it back in counterclockwise...
Sep 01, 2014 | Lindhaus Activa 30-38 Bagged Upright...
How can I separatte the ****** handle of my Epic 6500 fromthe hose? I have a wrapped pair of socks stuck in it at the handle
There are two different styles of hose for the 6500 vacuums. Please be careful when you take the handles off and also when putting it back togeather. To remove the handle there are two screw caps that you need to remove to get to the screws. You can do this with the tip of a knife or something similar inserted under the edge of the screw cap and pry up. The screws can either be a Phillips head or a torx bit. Remove the screws and then separate the top part of the handle from the bottom. Make sure to notice the position of the wires and do not unplug them from the switch or the contact block.The contact block at the hose end of the handle has two contacts that transfer the power from the hose to the handle and will bend out of shape if you are not careful. To remove the contact block, use a flat head screw driver under the block and pry up. On the older models, the handle will slip right off. If you have a newer model, there is a handle retainer at the base of the handle and will push out with a screw driver. It only goes one way and
the handle will slip off.
To replace the handle just reverse the procedure. Good luck.
Aug 28, 2014 | Electrolux Epic 6500 Vacuum
No electrical continuity on one lead in hose. Cause is probably in the wiper assy. How do I disassemble hose ends to check electrical connections without breaking or cutting into plastic parts?
We have here the user manual. The page 8-9 you will see the instruction for replace the power nozzle which shows how to desmandle the vacuum and you will find the power cord connetion point. A big advice use your camera to take picture every step you make and especialy before remove the wires since in any case you will forget anything when you will try to assemble it back they will bevery helpfull.
Aug 06, 2011 | Hoover S3670 Bagged Canister Vacuum
Have a small ball caught in between the handle and the hose and was wondering if the handle comes off
Depending on which style hose you have:
Dolphin Handle: There is a small retaining clip on the hose that can be removed by a flat head screw driver. Make sure your hose is not connected to the inlet and the power cord is disconnected from the inlet valve. If not you will receive an electric shock
Non Dolphin Handle: There are two screws under the handle. One at the back and one by the suction control. Remove those two screws, and pull the wire cover off by the suction control and when the piece is removed the hose should slide right out of the handle.
Aug 14, 2010 | Electrolux Centralux Vacuum
No suction in hose
Remove the machine side of the hose--is there suction at the machine? If so, run a broom handle or similar through the hose to dislodge the clog. If no suction at the machine, you may need to fish out debris with a hooked stiff wire from the port. Remove the bag and examine the port area underneath for similar clogging. Finally, check the brush area underneath the machine bottom plate for more obstruction. Also, check the brush assembly for debris accumulation. Remove the drive belt and check for free turning of the brush. If turns hard, remove the brush, clean the bearings and roller pins, then apply a small quantity of light oil like 3-1 or sewing machine oil. Hope this helps!
Jun 20, 2010 | Lindhaus 380 Diamante Bagged Upright...
My Lindhaus Diamante 300 has great suction but clogs
Sounds like you have some form of an obstruction in the hose ( i once found a tooth pick sideways in mine) most models allow for the hose to be disconnected from the vaccum itself, also make sure theres not a setting for attachments also, some models need the suction redirected.
Apr 08, 2010 | Lindhaus Diamante 300 Upright Vacuum
Electrolux Epic 6500/ handle clip broke....
The clip can be replaced by taking apart the handle. Small round plastic inserts cover up the screws that hold the handle together. Use a very small screwdriver to pry them off, then use a small screwdriver to remove the screws(Some of the screws may be star screws requiring a special screwdriver. The top part of the handle will then lift off and you will be able to change out the clip. Before reasembling the handle, clean the contacts which attach to the hose and be careful that you do not bend the contacts. It is kind of tricky to put back together.
Good Luck
Captaintek
Mar 26, 2009 | Electrolux Epic 6500 Vacuum
I have no suction on the Lindhause healthcare pro Hepa
Make sure that the on switch is in the upright position. Down won't give you give you suction when vacuming.
Make sure that the hose is securly in the lower part of the vacuum.
Test the hose with your hand before you put it back to see if you're getting air sucked in through hose. If not it must be clogged up somewhere. You might contact Lindhause home base.
Feb 23, 2009 | Lindhaus Healthcare Pro 14 Bagged Upright...
Beam Soft Touch handle electric harness replacement
Set the bottom part of the handle down(not the part that the screws go in)the contact board will fit into slots on the left side of thehandle half, the switch will go where the cutout is for it on the top, the plug is notched to fit at the lower front part of the handle. Then put the the tube into the hose and set it into the handle. There is a ribe near where the tube sticks out of the handle, it fits into a slot just before it sticks out. There also is a stop for the hose to up against so the contact rings can't slip off. Then put the other half on and screw it down.
Jan 08, 2009 | Beam Industries Wet/Dry Auto Central...
Lindhaus Activa 30 EOS Version
Check the inlet by the brush roll for a clog, also check your hose for a clog. Usually when there is a clog, it is sensing an overfull bag and will shut down to protect the motor. If there are no clogs, then there could be a problem with the circuit board or motor.
Jan 01, 2008 | Lindhaus Activa 30-38 Bagged Upright...
Lindhaus Diamante 300 Upright Vacuum Logo
48 people viewed this question
Top Lindhaus Vacuums Experts
JoeVacs
Are you a Lindhaus Vacuum Expert? Answer questions, earn points and help others
