Question about FrancisFrancis! X1 Espresso Machine
Temp gauge has quit working, and the temperature safety is burned out because the pump check valve stuck and wouldn't pump water causing it to overheat. The water pump is repaired but I need a new over temp protector electrical link and a new temperature gauge.
  • 100 Answers
Unless you have electrical expertise repairing this, I advise you not to. What state do you live in, we are here in los angeles we repair these.
Posted on Apr 02, 2011
My 88 Montero sport motor runs very hot but the temp gauge reads normal. Could it be a head gasket
run the fault codes to start with
next have the temperature SENDER unit check for correct operation
have a compression test done to check for head gasket/cracked head
check for coolant level at the radiator cap as the sender unit needs water around it to indicate properly or else it only reads the metal temperature that it is screwed into and may actually read a lot less causing you to burn the motor
I have experienced where the bottom plastic tank of a radiator has come off and the temp gauge went down with out going up that resulted in a burnt motor.
Jul 23, 2015 | Cars & Trucks
My engine overheating problem is in my 2000 land rover. The fan is running and the electric fan comes on at correct engine temperature. After start up the engine runs normal the temp gage rises slowly to...
the usual suspects are:
stuck shut thermostat
clogged raiator
dead water pump
low coolant level
it's sunday, rovers don't work on sunday.
Then again, maybe its wednesday, rovers take half a day then. 25322555-21syibu3fgwpdxocjnkpw0ib-5-0.jpg
Dec 15, 2014 | Cars & Trucks
I have a 2006 expedition 5.4 the temp gauge stays on cold whats wrong?
check your coolant. the temp is the water temp. Your radiator is out of water? you`ll burn out your water pump. Also check to see if your radiator fans are running constantly.
Apr 23, 2014 | 2006 Ford F-150
HEATING ISSUES
One way to tell a bad thermostat in a car is if the car overheats frequently even if there is water in the radiator.Stuck open - no heat from heater, temp gauge hardly moves off of cold.
Stuck closed - overheats engine, temp gauge quickly climbs to hot.listen for any rubbing, grinding, or whining noises from the pump. look under water pump while running, if pump is going bad. water will come out of weep hole on the bottom of the pump. good-day!
Apr 07, 2014 | 2005 Kia Sorento
My heating isn't working, it sometimes works but majority of the time it blows cold. Also when the engine is running, there seems to be a noise coming from the engine, could these be related? Engine temp...
No heat or low heat in a water cooled engine is worthy of an immediate check as major damage to engine could be the result of continuing to drive it. Things to check:
These two things may cause no heat and possible not ever show as a problem on the temp gauge or temp warning light until far to late:
Low coolant/antifreeze level
Frozen coolant/antifreeze
Stuck thermostat
Other possibilities that may/may not show other signs of trouble as well:
Failing water pump (this would also explain some noise, typically like a grinding, scraping or bad bearing noise)
Slipping belt (Typically associated with the famous belt squealing or chirping noise)
Clogged radiator and/or heater core
Non-operating temperature control valve
Stuck thermostat
Hope this helps!
Nov 24, 2013 | Ford PUMA Cars & Trucks
Guages not working,
If all voltages checked ok,then most probably its faulty instrument cluster board on which gauges are connected.Yes if cluster circuit board looks ok,then also it can be faulty.Somewhere there is minute short or burn on board then such prolem arises.
Also check the fuse box.One under hood and other under dash.Inspect each and every fuse and see if all are fine or not.
---------------For more troubleshooting on these cluster gauges i suggest you to refer the list of help links mentioned below.Its step by step instructions will help you to confirm the exact cause of problem in these conditions:---------
Click the link below:------
2004 Toyota Tundra: Oil Gauge and Temp Gauge Not Working?
http://howtobyme.blogspot.in/2012/05/2004-toyota-tundra-oil-gauge-and-temp.html
2005 Lexus SC430: Fuel Door, Dome light and Fuel Gauge Fuse Location?
http://howtobyme.blogspot.in/2012/05/2005-lexus-sc430-fuel-door-will-not.html
Toyota 4Runner: Temperature Gauge Sensor
http://technoanswers.blogspot.in/2012/04/toyota-4runner-temperature-gauge-sensor.html
Temperature gauge sits over half way mark?
http://schematicsdiagram.blogspot.in/2012/04/temperature-gauge-sits-over-half-way.html
Heater blows intermittently and temp gauge goes erratic?
http://technoanswers.blogspot.com/2012/01/heater-blows-intermittently-and-temp.html
Temperature gauge does not move and no heat when heater is ON?
http://technoanswers.blogspot.com/2012/01/temperature-gauge-does-not-move-and-no.html
2003 Pontiac Grand Prix: Erratic Fuel Gauge?
http://technoanswers.blogspot.in/2012/06/2003-pontiac-grand-prix-erratic-fuel.html
Temperature gauge keeps fluctuating up and down close to red?
http://technoanswers.blogspot.com/2012/01/temperature-gauge-keeps-fluctuating-up.html
Temperature gauge on the dash quit working on Pontiac Grand Prix?
http://technoanswers.blogspot.com/2012/01/temperature-gauge-on-dash-quit-working.html
Fuel gauge jumps from empty to full?
http://schematicsdiagram.blogspot.com/2011/12/fuel-gauge-jumps-from-empty-to-full.html
Gas gauge stuck on empty on 2002 Mercedes Benz 240c?
http://repairhelpcenter.blogspot.in/2012/02/gas-gauge-stuck-on-empty-on-2002.html
Oldsmobile Temperature Gauge Lamp Switch?
Fuel gauge drops to Empty?
http://technoanswers.blogspot.com/2012/01/fuel-gauge-drops-to-empty.html
Dodge neon gauges not working?
http://technoanswers.blogspot.in/2012/02/dodge-neon-gauges-not-working.html
Temperature gauge went up?
http://schematicsdiagram.blogspot.com/2011/12/temperature-gauge-went-up.html
Temperature gauge stays At cold on jaguar?
http://technoanswers.blogspot.in/2012/02/temperature-gauge-stays-at-cold-on.html
How to replace Instrument panel and dashboard on Toyota car?
http://repairhelpcenter.blogspot.in/2012/02/how-to-replace-instrument-panel-and.html
How to remove instrument panel on Chevrolet car?
http://technoanswers.blogspot.in/2012/02/how-to-remove-instrument-panel-on.html
How to remove control panel on Buick regal?
http://howtobyme.blogspot.in/2012/02/how-to-remove-control-panel-on-buick.html
These details will help.Thanks.
Nov 28, 2012 | 2000 Mitsubishi Lancer
No guages working
If all voltages checked ok, then most probably its faulty instrument cluster board on which gauges are connected. Yes if cluster circuit board looks ok, then also it can be faulty. Somewhere there is minute short or burn on board then such problem arises.
Also check the fuse box. One under hood and other under dash.
For more troubleshooting on these cluster gauges I suggest you to refer the list of help links mentioned below. Its step by step instructions will help you to confirm the exact cause of problem in these conditions: ---------
Click the link below: ------
Thanks.
Heat gauge goes way up,then by reeving motor it will go down.blows cold air
Check out related help links with solutions to troubleshoot the problem:---
Toyota 4Runner: Temperature Gauge Sensor http://technoanswers.blogspot.in/2012/04/toyota-4runner-temperature-gauge-sensor.html
Temperature gauge sits over half way mark? http://schematicsdiagram.blogspot.in/2012/04/temperature-gauge-sits-over-half-way.html
------------- No heat on Oldsmobile Silhouette? http://technoanswers.blogspot.in/2012/02/no-heat-on-oldsmobile-silhouette.html
Temperature gauge does not move and no heat when heater is ON? http://technoanswers.blogspot.com/2012/01/temperature-gauge-does-not-move-and-no.html
Temperature gauge keeps fluctuating up and down close to red? http://technoanswers.blogspot.com/2012/01/temperature-gauge-keeps-fluctuating-up.html
----------- Temperature gauge on the dash quit working on Pontiac Grand Prix? http://technoanswers.blogspot.com/2012/01/temperature-gauge-on-dash-quit-working.html
Dodge neon gauges not working? http://technoanswers.blogspot.in/2012/02/dodge-neon-gauges-not-working.html
Heater blows cold? http://schematicsdiagram.blogspot.in/2012/02/heater-blows-cold.html
Heat blows cold on drivers side and hot on passenger side? http://schematicsdiagram.blogspot.com/2011/12/heat-blows-cold-on-drivers-side-and-hot.html
1992 Lexus LS400: Engine overheats, Antifreeze out of reservoir and heater Blows Cold Air? http://whatisbyme.blogspot.in/2012/05/1992-lexus-ls400-engine-overheats.html
Thanks.
Nov 22, 2012 | 1997 Ford Taurus
My fuel gauge tach gauge speedometer heater temp gauge and driver power seat quit working
check the fuses. they are under the back seat just pull up on the lower part of the back seat and it will come out. fuse box is on the drivers side. check to see if water is getting in that could be the cause.
Feb 10, 2012 | 1996 Oldsmobile Aurora
Engine run good until warmed up
One runs the gauge (or light), and one is for the computer. You want the one for the computer. You can unplug to see if it's for the guage when warmed up.
Sep 21, 2009 | 1992 Chevrolet Lumina
FrancisFrancis! X1 Espresso Machine Logo
263 people viewed this question
Top FrancisFrancis! Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a FrancisFrancis! Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
