Question about Viking Professional VGSO166 Stainless Steel (Gas) Range
My door will not open more than 30 degrees. What is holding it?
**** your ***...45 degrees
Posted on Mar 17, 2011
Accidentally hit clean button on a Frigidaire Gallery Oven. Hit Cancel button. Oven door won't open.
I appreciate your post, C Maury!
From my understanding your hit the clean button on your Frigidaire wall oven and now the door will not open. I would hold down the cancel button for at least ten seconds, this should unlock the door. If that does not help I would recommend disconnecting power from your wall oven by flipping the household circuit breaker for ten minutes. I hope this information was helpful to some degree. -Matt
Nov 20, 2014 | Frigidaire 30 in. Electric Gallery Series...
How to install a door closer
Most come separated but if not separate the arm that holds to the door and door frame. Look to your installation manual or instructions to see the proper placement of unit to door. Depending on the door/frame you might want to pre-drill some holes for the screws after placing and marking the spots. Place the main piece back on an screw to the door. Mark out where to drill the arm to the frame of the door. Turn arm or use screws to adjust it to fit to the main unit without connecting it. On the bottom take the cap covering up the nut and turn it 30 - 45 degrees (or recomended by maker) with wrench HOLD it there until you connect the arm to the unit. Make sure that it connects properly. After screw the arm onto the unit and recover bottom with cap. Done!
If the door closes too swiftly, slams, or is hard to open then it needs to be adjusted by turning the S, L, or BC valves on the side.
S- how fast it swings from wall to 1-3" from door frame (hits you)
L- those 1-3" to the frame ( Slamming)
BC - controls how much force is needed to open the door
Apr 19, 2013 | Global Door Controls Residential Mini Door...
Oven door came off. how do I put back on?
Hi, W/D here.
Open the hinges about 30 degrees, and open the locking latches that are on the hinges. Slide the door on the hinges and set the locking latches. Done!
--W/D--
Apr 01, 2011 | Whirlpool Accubake RF362LXTT Electric...
How do I install addition ram in my toshiba satellite laptop L30 134
  • Shut down your Toshiba L30-10S.
  • 2 Unplug the A/C adapter and disconnect all external devices.
  • 3 Turn the L30-10S over and locate the battery pack at the top edge of the computer.
  • 4 Slide the battery release switch to the bottom right of the battery to release it. Set the battery to the side.
  • 5 Locate the RAM compartment door in the center of the computer.
  • 6 Remove the four screws holding the door in place.
  • 7 Lift the RAM compartment door off to reveal the RAM slot beneath.
  • 8 Lift the clips on the ends of RAM slot to release the current module.
  • 9 Slide the module out of the slot at a 30-degree angle and set it to the side.
  • 10 Slide the new module into the slot at a 30-degree angle and press gently down until the latches lock down and hold it securely. Replace the RAM compartment door and battery, then reconnect the AC adapter and external devices.
  • Dec 31, 2010 | Toshiba Computers & Internet
    My driver side door cannot open fully anymore, I am able to open about 10 degrees, just enough to slide into the driver seat. Yesterday I heard some clunking noises and had a lot of resistance opening and...
    the DOOR CHECK is broken. There is a screw are at the opening handle trim and the arm rest should have a screw. then the plastic clips, hold the panel to the door. You may pry gently to get the panel off, if you have to force it apart, not all screws are out. The window handle has a small clip holding it, it pulls out towards the knob, be careful that it doesnt fly off and you lose it.
    Nov 16, 2010 | 2001 Honda Civic
    It is not holding temp. its range is 30 to 49 degrees in one hour
    As a refrigerator, it should not go below about 34 degrees. If it is going down to 30, it may be freezing up on the coil. If you get a chance, do this: unplug the refrigerator and let it sit for 4 hours with the door open. If the coil is frozen it will defrost. You can feel the coils inside the box at the top back inside the unit. If you feel ice at any time it is an indication that it is getting too cold. Once the inside coils freeze over, the air can't flow through the coils and the unit will get warmer and warmer. When it is defrosted, set the thermostat just above the off setting. Let it run until the compressor shuts off. See what the temperature reads on a thermometer inside the cooler. If it is not cool enough move the thermostat one number colder and let it run an hour. Take your time, let it equalize before you change the thermostat. Also if the cooler is empty it is hard to set the thermostat because when you open the door all the cold air escapes and the temp will change rapidly. If it is full of cold food, opening the door won't change the temperature very quickly. Also check the radiator coils at the bottom of the cooler behind the grill. If it is clogged with dust or grease, the compressor may overheat and shut off prematurely.
    Sep 21, 2010 | True T-49 Side by Side Refrigerator...
    Last two weeks refrigerator temp goes anywhere from 30-35 degrees and freezer temp -5 to -1 degrees.several times a day we attempt to set temp to reccommended temp, but no success.we do not have mannual,...
    fridge temp should be 30 to 35 degrees/freezer -1 to -5 f or between 2 to 5 C for fridge and -18 to -22 C for freezer several times a day is too often...... try once every 2 days without opening door in between checks....
    Feb 11, 2010 | GE Profile PSW26P Stainless Steel Side by...
    I have a frigidaire mef352bgwd electric oven- after a power outage the lock engaged (door open) and now blinks continually. Tried shutting off breaker for 30 minutes- no change.
    There is a pin that tells the oven the door is open, you need to push it in an hold it. It is pretty stiff, you can't use your bear hand. It will be in the upper left of where the door closes.
    Jan 07, 2010 | Frigidaire GLEB27S7A Electric Single Oven
    Viking Professional VGSO166 Stainless Steel (Gas) Range Logo
    49 people viewed this question
    Top Viking Kitchen Ranges Experts
    Dan Webster
    Dan Webster
    Ismael Rodriguez...
    Craig Butler
    Craig Butler
    Are you a Viking Kitchen Range Expert? Answer questions, earn points and help others
