Question about Kitchen Ranges
I have 3 new Kelvinator split air conditioners, all with model numbers, KSV70CRB.They are all very hard to change the temperature on them with the remote control.I have to click it quite a few times before it will work, them sometimes it will jump 2 or 3 degrees at a time.I`m having trouble with all the remote controls.Just 1 click to change everything else on them, except the temperature.
  • 58 Answers
SOURCE: Oven does not maintain temperature. Part 2
sometimes when they get hot that is when they fail
Posted on Oct 31, 2007
  • 7 Answers
SOURCE: Remote Problems
you dont leve the remote in the sun do you? could be an issue
Posted on Jan 25, 2008
hemantraj
  • 638 Answers
SOURCE: Hotpoint RGB747GER oven does not heat properly
www.repairclinic.com
Posted on Aug 18, 2008
SOURCE: How can I get Westpoint air conditioner wireless remote controls?
Dear,
Do you mean thermostat, the wireless controller for air conditioner? we are exporter of this line from China. Should you be interested in our products. Please feel free contact me at leeysea@gmail.com or add my MSN lee_ysea@hotmail.com. Our website is www.yseagroup.com
Thank you!
Lee Lee
Posted on Oct 20, 2008
  • 400 Answers
SOURCE: Kelvinator Split System Air Conditioner not turning on.
On some remotes there is a reset button which is pressed by using the nib of a pen. Or if this does not work you should look under the cover for a manual button, most units have one, and see if the aircon responds. I suspect your remote sensor is faulty, but try the previous suggestions first.
Posted on Mar 05, 2009
Kelvinator split system heater off every 5 minutes for about 4 minutes then it comes back on and does this constantly .
Here is the free help link.
Air Conditioner Repair Help
Here is the PDF. It does not list the problem you identify but lists the contact information for Kelvinator. Bear in mind your problem could be a blockage, a bad sensor, or oddly enough, the filter needing changing. This calls for a service technician.
https://theelectricdiscounter.blob.core.windows.net/images/air-conditioner/air-conditioner/kelvinator/pictures/e_series_inverter.pdf
Jun 05, 2017 | Heating & Cooling
My kelvinator split sys turns on for about 5 min the 4 lights flash blows warm air have no manual
If the 4 lights are the indoor unit indicator lights, it is a fault code. Do some lights stay on or do all flash? What model is it? Kelvinator ( In Australia) are sourced from various OEM suppliers, different models will have different fault codes.
Mar 16, 2015 | Heating & Cooling
I have a kelvinator Electrolux split air con model r51k/bge it doesn't seem to keep coolits set on 17 and the control says cool the fan says high but no cold air comes out wat could be the pro
many reasons could be there, check that the outdoor fan working or not if yes my be the compressors is tripping, if no, check the volt for outdoor, check the gas and the leakage
Nov 21, 2014 | Electrolux Heating & Cooling
Hi I have lost my remote control for kelvinator split ac, where can i buy a new one?
Hello Selushi,
You can order your part from RepairClinic by calling them between 8am and Midnight Eastern Time USA the number is 1-800-269-2609 or by live chat at http://www.repairclinic.com/Kelvinator-Air-Conditioner-Remote-Control-Parts also available at the same time.
Thank you for choosing FixYa.com
Mar 06, 2011 | Heating & Cooling
Kelvinator split- type room air conditioner not working and has E9 on digital display what is happening
E-9 means high or low pressure. Please service your unit and then check. May be sometime problem would have solved. If not, check fan speed. If less rpm change new capacitor. Thanks.
Dec 27, 2010 | Heating & Cooling
Hi, i have kelvinator split system in my house.but...
Sounds like a clogged drain pan. You will need to have the unit professionally cleaned.
Hope this helps I take the time to answer your question so please rate me
May 19, 2010 | GE Zoneline AZ38H12DAD Split System Air...
Remot control not working for this unit
change batterys if not working contact tech support from kelvinator
Feb 26, 2009 | GE Zoneline AZ38H12DAD Split System Air...
Kelvinator split system a/cond
An air handler comes with a low, medium, and high speed wire taps and can only be set through these taps.
Oct 16, 2008 | Heating & Cooling
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
