Question about Apple iPod U2 Special Edition MP3 Player
My ipod has a wall plug sign that blinks on and off since i reset it i am bumd out
  • 55 Answers
You need to restore the iPod, if the problem continues go to the apple store.
Here is the guide to how restore your model of iPod:
  1. Verify that you have an active Internet connection, because you may need to download new versions of the iTunes and iPod Software.
  2. Download and install the latest version of iTunes if necessary.
  3. Open iTunes. Connect your iPod to your computer using the USB or FireWire cable that came with your iPod.
  4. After a few moments, your iPod will appear in the Source panel in iTunes.
  5. Select your iPod in the Source panel. You will see information about your iPod appear in the Summary tab of the main iTunes window.
  6. Click Restore.
  7. If you are using a Mac, you will be asked to enter an administrator's name and password.
  8. A progress bar will appear on the computer screen, indicating that stage one of the restore process has begun. When this stage is done, iTunes will present one of two messages with instructions specific to the iPod model you are restoring.
    • Disconnect iPod and connect it to iPod Power Adapter (typically applies to older iPod models).
    • Leave iPod connected to computer to complete restore (typically applies newer iPod models).
  9. During stage two of the restore process, the iPod displays an Apple logo as well as a progress bar at the bottom of the display. It is critical that the iPod remain connected to the computer or iPod power adapter during this stage.
    Note: The progress bar may be difficult to see, because the backlight on the iPod display may be off.
  10. After stage two of the restore process is complete, the iTunes Setup Assistant window will appear. It will ask you to name your iPod and choose your syncing preferences, as it did when you connected your iPod for the first time.
Source: Apple support page http://support.apple.com/kb/HT1339
Posted on Mar 17, 2011
I had my iPod (5th Generation Late 2006, 30gb) plugged into my computer yesterday and my computer went to sleep (with my iPod still plugged in). I woke my computer up and then all my iPod would say was: ...
Try a manual reset by holding the center button and the play button together for at least 10-15 seconds, this should reset your iPod and should refresh the battery,
In future do not let your battery run flat completely always keep a charge, and lastly charge through a wall charger and not from the usb port,
good luck
Aug 12, 2010 | Apple iPod MA446LL/A MP3 Player
IPOD FROZEN
  1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
  2. Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step.
If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep.
Jul 28, 2009 | Apple iPod 4th Generation MP3 Player
My ipod has just stopped working, the battery is full, but nothing is happening when try to do any thing. My ipod classic just stopped working, won't turn on even though it has a charge.
There are a couple of things it could be. But first try this.
Press and Hold the MENU and CENTER buttons until the ipod reboots. You will see the apple reappear and it will boot normally.
If it doesn't, here are a few things to check.
  • Plug the ipod in to an a/c wall plug and it should boot
  • have you played your ipod on a dock? that could have fried the motherboard and it needs to be repaired.
  • your battery could just be completely dead (very Common)
  • your hold switch is broken inside and stuck on hold.
If you need more answers comment back.
May 18, 2009 | Apple iPod classic MP3 Player
Apple iPod Classic 8GB
Have you tried a different cable or plugging it into a wall charger, or another computer? That would be the first thing I would try.
Dec 27, 2008 | Apple iPod nano
Ipod won't charge
The easiest thing to do to solve this is to reset the iPod. Apple has a small resetting program especially for this type of ipod. The program is free and downloadable from apple.com. Try this url:
http://support.apple.com/kb/HT1238?locale=nl_NL
If that url doesn't work, go to Apple.com, click support and choose iPod and search for reset utility to look for the download link. And if that doesn't work let me know and I'll send the program to you by e-mail.
O, the reset will erase all your music/data on the iPod.
Apr 15, 2008 | Apple iPod shuffle MP3 Player
Ipod show plug in
This is the result of a firmware update.
You need to plug it into an Apple wall charger rather than a generic USB charger in order to complete the firmware update.
If you have used an Apple charger already then take your iPod to an Apple store as they can remedy this.
Mar 05, 2008 | Apple iPod MP3 Player
Ipod only shows outlet
Start with these five simple solutions: Reset, retry, restart, reinstall, or restore
http://www.apple.com/support/ipod.five_rs/
If you need more assistance let me know. Good luck.
Feb 23, 2008 | Apple iPod 4th Generation MP3 Player
Dock Connector Charging Problem
I had that problem one time and the only way to get rid of that icon was to plug it into my Bose sound dock. You could also try another brand of sound dock to see if it works. Good luck
Nov 11, 2007 | Audio Players & Recorders
My mini ipod freezing, showing charger sign i could not turn it to menu
Try resetting the ipod, this usually works. As follows: How to reset iPod To reset an iPod with a Click Wheel, including: iPod nano (3rd generation) iPod classic iPod (5th generation) iPod nano (2nd generation) iPod nano iPod with color display (iPod photo) iPod (Click Wheel) iPod mini iPod mini (2nd generation) Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.) Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step. Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center. If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep. To reset iPod, iPod (scroll wheel), iPod (touch wheel), and iPod (dock connector) Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.) Press and hold the Play/Pause and Menu buttons simultaneously until the Apple/iPod logo appears, about 6 to 8 seconds. You may need to repeat this step. If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep. If you are still unable to reset your iPod, use only one finger from one hand to press the Center (Select) button, and one finger from the other hand to press the Menu button. When you reset iPod all your music and files are saved, but some customized settings may be lost. Date and time is preserved (unless the iPod reset itself because it had no power and then was reconnected to power). Other customized settings, such as Bookmarks, On-The-Go Playlists, Shuffle, Backlight timer, and so forth are preserved from the last time the hard drive turned on. Good luck, and I hope this helps.
Sep 14, 2007 | Apple iPod mini M9160LL/A MP3 Player
Apple iPod U2 Special Edition MP3 Player Logo
167 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
