Question about Philips PPF-531 Plain Paper Thermal transfer Fax
How to remove transmission report after faxing
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 37 Answers
Goto MENU 28 and disable the fax journal ( aka transmission report)
Posted on May 11, 2011
Fax transmission reports
What you are explaining should work. If you need prior activity reports from previous faxes, you can press Function then 2 (Act. Report)
I think you might need to press Function, then 7 then 1
From the manual:
Transmission Verification (Xmit) Report You can use the Xmit Report as proof that you sent a fax. This report lists
the time and date of transmission, and whether the transmission was successful.
When the feature is OFF, the report is printed automatically only if an error occurred during transmission. If the report indicates NG, send the document again. If the report indicates you should check the readability of certain pages, resend those pages.
If you typically send multiple faxes to the same destinations, you may need a reminder to identify each fax transmission. You can select OFF+IMAGE or ON+IMAGE to print a portion of the first page of the fax message on the report.
1 For the FAX, press Function , 7 , 1 .
For the MFC, press Function , 1 , 7 , 1 .
2 Press or to select OFF, OFF+IMAGE, ON or ON+IMAGE and press Set .
3 Press Stop to exit.
Hope this helps you.
Mike
Nov 14, 2007 | Brother MFC 8300 Laser Printer
Is is possible to go back two weeks to see a journal report on my brother mfc 9440 cn series? I didn't save a confirmation page and I need to see confirmation of a fax sent two weeks ago. Thanks
  1. Press the Menu key.
  2. Press the Up or Down Arrow key to select Fax and press OK.
  3. Press the Up or Down Arrow key to select Report Setting and press OK.
  4. Press the Up or Down Arrow key to select Transmission or XMIT Report and press OK.
  5. Press the Up or Down Arrow key to select the option you prefer.
    • Off
      Transmission verification report will print only if a fax transmission is unsuccessful.
    • Off+Image
      Transmission verification report will print only if a fax transmission is unsuccessful with a portion of the fax's first page printed on the report.
    • On
      Transmission verification report will print after every fax transmission.
    • On+Image
      Transmission verification report will print after every fax transmission with a portion of the fax's first page printed on the report.
  6. Press OK.
  7. Press Stop/Exit.
May 10, 2011 | Office Equipment & Supplies
HOW TO PRINT FAX CONFIRMATIN PAGE MFC440CN
To print fax send confirmation report:
You can use the Transmission Verification Report as proof that you sent a fax. This
report lists the time and date of transmission and whether the transmission was successful
(OK). If you choose On or On+Image, the report will print for every fax you send.
If you send a lot of faxes to the same place, you may need more than the job numbers to
know which faxes you must send again.
Choosing On+Image or Off+Image will print a section of the fax's first page on the report
to help you remember.
When the Transmission Verification Report is turned Off or Off+Image, the Report will
only print if there is a transmission error, with NG in the RESULT column.
Apr 12, 2011 | Brother MultiFunction Center MFC-440CN...
How do I get a fax transmission report to print from a Fuji Xerox C1190FS?
Printing Transmission Reports
To select a default option for printing fax transmission reports:
1. On the printer console, press the System button.
2. Select Admin Menu, and then press the OK button.
3. Select System Settings, and then press the OK button.
4. Select Fax Transmit, and then press the OK button.
5. Select one of the following options, and then press the OK button:
- Print Always: A transmission report is always printed.
- Print at Error: A transmission report is only printed when an error occurs with the fax
transmission.
- Not Print: A transmission report is never printed.
Note: The factory default is Print at Error.
Mar 05, 2011 | Office Equipment & Supplies
Brother IntelliFax-2820 Plain Paper Laser Fax does not automatically print a transmission report each time we send a fax. Is there a way to automatically have that happen. We can't find it.
You need to set up the Transmission Verification Report and Journal Period in the menu table.
Press Menu/Set, 2, 4, 1.
-OR-
Press Menu/Set, 2, 4, 2.
You can use the Transmission Report as
proof that you sent a fax. This report lists the
the transmission was successful (OK). If you
select On or On+Image, the report will print
Selecting On+Image or Off+Image will print
Note
When the Verification Report is turned Off or
Off+Image, the Report will only print if there
is a transmission error, with ERROR in the
RESULT column.
1 Press Menu/Set, 2, 4, 1.
2 Press ? or ? to select On, On+Image,
Off or Off+Image.
Press Menu/Set.
3 Press Stop/Exit.
Printing reports
1.XMIT Report
2.Journal Period
Nov 15, 2010 | Brother IntelliFax-2820 Laser Fax
Need fax confirmation report .
1) Press <Menu>
2) Press Up or Down <Arrow key> to select "Fax"
3) Press <OK>
4) Press Up or Down <Arrow key> to select "Report Setting"
5) Press <OK>
6) Press Up or Down <Arrow key> to select "Transmission" or "XMIT Report"
7) Press <OK>
8) Press Up or Down <Arrow key> until the option you prefer appears:
  • OFF - Transmission verification report will print only if a fax is unsuccessful
  • OFF+IMAGE - Transmission verification report will print if a fax is unsuccessful with a portion of the fax first page
  • ON - Transmission verification report will print after every fax transmission
  • ON+IMAGE - Transmission verification report will print after every fax transmission with a portion of the fax first page
9) Press <OK>
10) Press <Stop/Exit>
I hope this helps!
Jan 15, 2010 | Brother Multi-Function Center MFC-240C...
How can I print a fax confirmation on a specific outgoing fax
Checking a report for the transmission result (?TX Report? function) A report containing the transmission results can be printed. The machine can be set to either print or not print the transmission report or to print it according to the machine setting or only when a transmission fails. To print the transmission report 1 Press the [Fax/Scan] key to display the Fax mode screen. 2 Touch [FAX Menu]. 3 Touch [TX Report] on the Set 1 tab. 4 Select how to output the report, and then touch [Enter]. ? Default: The transmission report is printed according to the previously specified method. For details, refer to ?Specifying report output settings (Report Settings)? on page 10-48. ? ON: The transmission report is printed with each transmission. ? If TX Fails: The transmission report is printed only if the fax could not be sent. ? OFF: The transmission report is not printed, regardless of the transmission result.
Aug 10, 2009 | Minolta bizhub 200 Copier
Hi how do I turn of tx and rx reports on faxcentre F110/
The machine can print a transmission (confirmation) report after each transmitted fax. This report indicates whether or not the fax has reached the intended recipient. Four different settings are available for the transmission report:
  • With: a report is printed when the fax transmission was successfully sent or when it is completely abandoned. There is only one report for each fax sent.
  • Without: no transmission report is automatically printed, however, the machine will save all fax transmissions that took place in memory. The faxes sent can be viewed by printing out a transmission log (report).
  • Always: a report is printed after each successful or interrupted transmission.
  • On Error: a report is printed only if the transmission failed or is abandoned.
NOTE: With each transmission report from memory, a reduced version of the first page is automatically reproduced.
To modify the report type setting:
  1. Press the [OK] button directly below the Display Screen. '1 Installation' and '2 Fax' will be displayed.
  2. Press [2], [5] on the numeric keypad. ‘25 >Send Report’ will be displayed.
  3. Press [OK]. The transmission report screen will be displayed.
  4. Press the up or down arrow button directly below the Display Screen to select a transmission report setting, then press [OK]. ‘25 Send Report’ will be displayed.
    NOTE: As the up and down arrow buttons are pressed, the menu will scroll through the available choices and move the greater than symbol (>). Stop when the greater symbol is in front of the appropriate selection.
  5. Press the [Stop] button on the Control Panel. The 'Date / Time' screen will be displayed
Dec 11, 2008 | Xerox FaxCentre F110 Plain Paper Laser
Konica Minolta C250 Scanner problem
To print the transmission report:
1. Press the [Fax/Scan] key to display the Fax mode screen.
2. Touch [FAX Menu].
3. Touch [TX Report] on the Set 1 tab.
4. Select how to output the report, and then touch [Enter].
– Default: The transmission report is printed according to the previously specified method.
– ON: The transmission report is printed with each transmission.
– If TX Fails: The transmission report is printed only if the fax could not be sent.
– OFF: The transmission report is not printed, regardless of the transmission result.
Feb 05, 2008 | Konica Minolta bizhub C250 All-In-One...
Philips PPF-531 Plain Paper Thermal transfer Fax Logo
145 people viewed this question
Top Philips Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Philips Office Equipment and Supply Expert? Answer questions, earn points and help others
