Question about Saeco Magic De Luxe Espresso Machine
No coffee coming from machine
Hi, We have this coffee machine and it starts to dispense the coffee, but only 1 or 2 lights come up on the led lights and stops. The button you press for the small, medium or tall coffee then just flashes.
Can anyone help?
  • zytech Aug 02, 2008
    Hi Mirran,
    Thanks for your reply. We can get water coming through the steamer tube/spout, but not through the coffee dispenser tubes.
    Any idea what a flowmeter would be worth?
    Cheers
  • 515 Answers
Can you make a cup of water or you can only get a half cup?
I think it can be your flowmeter in the machine that has to be replaced.
Posted on Aug 02, 2008
  • Mirko Blas
    Mirko Blas Aug 02, 2008
    If you can get water trough the steamer and make a full cup of water then is your flowmeter is ok. Make sure your brewunit is clean, on the top there are two screw, loosen this and take of the little plastic where the tube are, take out the little metalic pin and make sure that is clean.
    Hope this will help you.
Jura impressa z5 coffee machine is not dispensing coffee what is the problam
What sounds are coming out of the machine
1. When you switch on, does it rinse.
2. When you press for coffee does everything sound normal
3. Does it dispense hot water
Nov 13, 2014 | Coffee Makers & Espresso Machines
Giaggia Brera descaling problem
been talking to Gaggia (Philips) and they told me that with the newer Breras, you need to ill the water tank, put the machine into standby, then press the long and short cup buttons together for 6 seconds. This will start an auto descale programme (that they didn't mention in my manual!). A small amount of water will be dispensed through the coffee nozzles, then it will stop and the warning triangle and the prime warning light will come on. Place a large container under the panarello, then turn the knob to the right to dispense water. It will dispense about 50 - 100 mls (cold) water, then stop for about a minute. Just leave it and eventually it will empty the tank. Refill it and start again, but it will stop after a few seconds. Turn the knob back to central position, then it will dispense another small amount of water from the coffee nozzles, then stop with warning lights again. Turn the knob back right to dispense water, if it stops because of empty tank, just refill it. Eventually, the machine will stop and go to standby. Turn the knob back to the centre, refill tank yet again and the machine will start normally WITHOUT that descale warning light. HOORAY !!
Jan 22, 2013 | Coffee Makers & Espresso Machines
I have a Saeco Royal Coffee Bar that will intermittently fail to dispense espresso. It will grind the coffee but instead of dispensing the coffee, it dumps the (dry) coffee into the dreg drawer and resets...
Hi
Its not the water. More than likley its the lever on the right side of the machine at the top middle of the door. Its pushed all the way to the back or positive. Move it 1 mark towards the front of the machine and try again. If you put too much coffee in the brew unit, it can't compress it and kicks it out. It could also be your grind is too coarse. It should look like auto drip coffee.
Apr 02, 2011 | Saeco Royal Cappuccino Espresso Machine
Saeco Vienna coffee when the machine starts the coffee dispensing
Is it leaking only when brewing coffee ?
If not I would check the seal under the water tank (Part #NM05.006)
If so, I would check the following:
1- The water input port on the back of the brew unit (looks like a smoke pipe) might be clogged
2- The o-ring of the water tubes coming in and out of the boiler.
Jul 30, 2010 | Saeco Vienna SuperAutomatica Coffee...
Saeco Magic Deluxe - Coffee Cold,Lights not working
The thermoblock (boiler) element is burnt out and must be replaced.
Feb 10, 2009 | Saeco Magic De Luxe Espresso Machine
Blocked dispenser
Hi again,
here is how to get ride ofCoffee Dispenser Blocked issue. the reason for this error to come inthe screen is because the machine has reached the counter lockingnumbers of coffee. which is stored in the machines memory.
firstwith the machine switch on and Coffee Dispenser Blocked on screenpress menu button, than arrow up or down until you see VENDING onscreen and the courser flashing next to it press ENTER once. than u cCODE on screen DO NOT press ENTER yet, press arrow up or down untilLOCKING COUNTER on screen ( you need to increase this number) bypressing ENTER you will be asked to enter CODE the default is 0000press ENTER button 4 times than u will go back to LOCKING COUNTERpress ENTER again here u will c the last digit on the right isflashing by pressing and hold down arrow up u will increase thisnumber. keep pressing until 20000 or more it is up to u. when youselect what ever number u want press ENTER once again. than ESCbutton to exit the menu. Switch the machine off than on and u will beable to use your machine again. if u have any problem please sendyour phone # and I'm willing to call you to go throw it with u in thephone.
cheers
Feb 08, 2009 | Saeco Royal Digital Plus Coffee...
Saeco vienna "machine ready" light (second light) blinking--not allowing to dispense coffee.
Try to open the steam knob and make a cup of water(Tea).
Best regards
/Mirran
Oct 21, 2008 | Saeco Vienna SuperAutomatica Coffee...
Saeco Magic De Luxe Espresso Machine Logo
105 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
just-ice
83bj60
Level 1 Expert
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
