I have an Envision G22LWK monitor and it won't start for more than a few seconds. It flickers and turns off after a second or two. I have taken the monitor apart in an effort to identify the problem hardware, and when I disconnect one of the power terminals from the backlight it stops flickering when I turn it on. This is the JT229ZP6MR power board and the connector I remove connects on the bottom left corner of the board. The plug is labeled "P904" Albeit the flicker stopping, the monitor still turns off after a second or two. This is beyond my troubleshooting skills. I do not understand how the power board works well enough to continue. I can provide images upon request. Thank You for your time! Will Nelson
kakee
  • 1269 Answers
SOURCE: Flickerin Screen
The problem is within the power supply. It sounds like a diode problem on the power supply board. Try double check any other burned components like bulged capacitor and burnt resistors. Replacing them could fix it.
Posted on Sep 23, 2008
SOURCE: maxent
what would cause this and is it worth to fix
Posted on Jul 11, 2009
  • 60 Answers
SOURCE: My tv screen keeps flickering on and off
  1. Need Model # of set and the brand so I know if its a plasma, LCD, or CRT set keep me posted
Posted on Aug 23, 2009
yammy_alf
  • 666 Answers
SOURCE: RCA 37" FLAT SCREEN NON STOP FLICKERING/FLASHING SCREEN
you need to remove main ckt, (m.board) some part need to re solder specially in hot area. (lost contact i one of the flickering problem you encountered.
Posted on Mar 26, 2010
SOURCE: Our Phillips 47PFL5432D/37 LCD HD
mine was doing that before the picture finally went all the way out
till then to get it to stop flickering open menu go to picture setting and cut on light sensor
its prolly the backlights going out as well has the capacitors going out
Posted on Dec 23, 2010
My Envision LCD Monitor screens turns gray once its power on. I have tried changing contrast will not work.
When it have this kind of error is a problem of the powerboard.
Anyway you must open it and look at the all capacitors and if are them inflated, if them are inflated must change them.
But can be a problem with inverters... control the transistors - MOSFET on the powerboard.
Mar 27, 2014 | Envision G22LWK 22" LCD Monitor
I have an Envision G22LWK 22" LCD monitor that keeps turning off every 30 secs. How can I stop it from doing that?
is it turning off or going into sleep mode? If turning off, you have issues with the power supply. look at it and see if any capacitors are bubbled up on the ends and replace if you see this.
Nov 08, 2013 | Envision G22LWK 22" LCD Monitor
Out of Range
Your horizontal should be between 30k-80khz while vertical should be 50-75 hz. So you are definitely too high. I would check supply voltages and open it up and look for any obvious issues with capacitors.
May 14, 2013 | Envision G22LWK 22" LCD Monitor
When i turn on my monitor (Envision G22LWk) it will go blank about 1 second after I turn it on. What might be the problem?
You may have power supply/inverter board problem due to bad caps, or worst case will be bad lamp assembly, the one shown here has broken lamps, you can hear arcing sound if you listen real close.
http://s807.photobucket.com/albums/yy352/budm/Envision%20G22LWK/
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series
Apr 09, 2011 | Envision G22LWK 22" LCD Monitor
I have a n envision 22" flat panel TV purchased
I don't think there is still warranty for this TV. Usually, warranty last for 1 to 2 years... In summary there is not warranty for this TV, it must have expired.
To further confirm, check the receipt of purchase. The warranty duration should be stated there.
I hope you understand the above....
Good luck.
Mar 19, 2011 | Envision G22LWK 22" LCD Monitor
Hi, i bought a used envision G22LWk... Can you tell me why it turns on? Then, in about 2 to 5 seconds it goes blank? I didnt get the guide with my monitor or i would look it up.
Usually it's because it doesn't detects the signal. Check the cable and the pc. User manual
http://www.retrevo.com/support/Envision-G22LWK-Monitors-manual/id/6893ag909/t/2/
Mar 15, 2011 | Computers & Internet
Will not power up
try to disasemble ur video card then put it back again the open it...
Nov 08, 2009 | Envision G22LWK 22" LCD Monitor
Hi My name is denise, I have the invision 22" Moniter can you tell me are there build in speakers on the moniter.
http://www.testfreaks.com/blog/review/22-envision-g22lwk-dvi-widescreen-lcd-monitor-wspeakers-black/
Here is a review of the monitor, it says it does have speakers, but not very good review, but most if not all speakers that are built in are not great. I hope this helped, Gym
Dec 21, 2008 | Envision 19" Widescreen Flat Panel TFT LCD...
Monitor started to flicker then went blank
I have a envision professional series and I love it, but I will get to the point.
I recent ly received a Envision EN9410e monitor, had the same problem (flickering screen then turned on, then off then on then blank). The problem is bad capacitors. There are 7 electrolytic capXon capacitors that will need to be replaced. You should see if the caps are bulging or leaking, if so replace. As known by many replace with the same capacitance and voltage. There are a few incidences that the capacitors where replaced and the problem wasn’t solved; this is because the cap problem wasn’t taken care of and damage occurred to another part of the monitor. The back light is a Royer oscillator (cool things) and it uses two smd mosfet transistors. They are on the green side of the circuit board near a big control chip (they each look like a off rectangle black square with eight pins) you need to see if there is any carbon or chard residue between the pins or burning smell from them, if there is you need to remove the transistor and do some board repair then ether put a new transistor or try the old one. No offence to the people at Envision but not smart putting the drain, gate and source so close to each other under the chip where there is such high voltage! Hope this helps.
Dec 24, 2007 | Computers & Internet
Televison & Video Logo
139 people viewed this question
Top Televison & Video Experts
