Question about Sony VAIO PCG-K25 Notebook
Sony Vaio new harddrive install it says operating system not found will not boot from cd rom it attempts to spin but nothing happens. Cd works fine with old HD installed
  • 187 Answers
Try to load the BIOS to default
Posted on Mar 17, 2011
My sony vaio is not found operating system
recovery boot record with Hierens Boot CD or reinstall system at all with recovery CD or partition
Nov 11, 2012 | Sony VAIO E Series Notebook VPCEB1GGXBI
Hi, Im trying to re-install windows xp pro sp2 on to my sony vaio vgn-t1xp. i booted from the cd, deleted the partitions that were currently on the harddrive, and then went on to format it (NTFS). once...
Once the setup files are copied don't let it boot from the cd-drive anymore, at the prompt "Press any key to boot from cd...", please do not press any of the keys. However you do require the cd in cd-rom for the rest of the setup.
Jul 18, 2011 | Sony VAIO VGN-T1XP/L Notebook
Hello. I have Sony Vaio PCG-5426. And I can't reinstall windows on that machine. I have out CD-ROM "II FreeCom" and i try to reinstall with that. In BIOS menu I acces for first boot drive...
you shouldn't need to have to press f9 to boot from cd rom if you have it set in the bios as the first boot device , are you sure the copy of windows on cd that you have is bootable. Try booting from the disc on another laptop or pc and see if you can start it
Another option to try is to boot from a usb drive
instructions on how to do that are here
http://www.xtremesystems.org/forums/showthread.php?t=118576
once you have booted to usb you should be able to access the cd rom
depending on what version of windows you are trying to install you will need to run different programs.
you could also install vista or windows 7 to usb drive and install it from that, it is much quicker than installing from cd/dvd you would need to be able to boot from usb to start with though
how to install vista or windows 7 from usb instructions can be found here
http://www.intowindows.com/how-to-install-windows-7vista-from-usb-drive-detailed-100-working-guide/
please vote for me if you found any of this useful
Feb 20, 2011 | Sony VAIO PCG-5212 PCG-5426 PCG-551L...
When i turn on the laptop computer, a message appears: primary hard disk drive not found, fixed optical drive not found. No bootable devices: strike F1 to retry boot;F2 for set up utility. I tried but...
Your BIOS is looking for a drive to "boot" from and does not see your harddrive or CD-rom.
You may have a harddrive failure or bad drive controller.
One way to see is to load your operating system disc in your CD-rom and see if the computer sees the drive and boots up. If it boots, try to locate your "C" drive. If you can't locate the harddrive, it's a good bet it's damaged.
If the CD-rom doesn't boot, it is most likely a bad drive controller or cable.
Dec 30, 2009 | Computers & Internet
Ibm x series 226 attempt to install os and says no harddrive
Make sure that the motherboard and/or disk controller recognize the drives during POST.
Then check and see if IBM has a server installation CD-ROM that you can use boot the server and automatically load the correct drivers to prep for the OS install. I have downloaded installation CD ISO files from HP and Dell that walked me right through the OS install.
Another important consideration is that servers frequently use disk controllers that are not included in the operating system's driver files.
For example, when installing Windows OS on a RAID controller you must press F6 immediately after the installation CD-ROM starts up.
Later in the installation you will be prompted to insert a 1.44 diskette with the driver for your RAID controller.
The only challenge is to find the correct version of the driver and get it on a diskette.
I hope this helps.
Jul 16, 2009 | IBM xSeries 226 Server
Operating system not found
On my Sony VAIO Windows 7, I have got "operating system not found" error, to fix problem, Windows Boot Genius helped me finally!
Apr 09, 2009 | Sony Computers & Internet
Ibm thinkpad r40 laptop just installed new harddrive, powers up no operating system found..... reorder harddrive, still no change setup and booted from cd, no change when placing windows xp cd will...
The problem is that you need to boot up the laptop with the CD as the first boot device so you can then install Windows XP.
If you press F12 a boot up you will get a list of alternate boot devices oher than the hard disk as the first boot device, which was set up in the BIOS. Select the CD as the first boot device and when prompted press the space bar to start the CD.
Jan 07, 2009 | IBM ThinkPad R40 2722 Notebook
FATAL ERROR MESSAGE/DELL OPTIPLEX GX150 DESKTOP/WINDOWS XP PRO
I have experienced this problem as well, it is either the CD is scratch or the CD-rom lens needs cleaning, however it can read the content of the CD, I would susgest you try a another CD-rom , borrow it from a friend. It works for me.
Nov 06, 2008 | Dell OptiPlex GX150 SF PC Desktop
Install hard drive
Dear PBRIM ,
First of all you have to format new Hard disk then you have to install the Operating system and drivers on it then it will be work.
Cheerup and Be Happpy always
Mar 11, 2008 | Computers & Internet
Changing Sony Vaio BIOS
you should be able to exit and save changes, which my guess is you are exiting without saving the changes. theres is a way around this, by pressing either F8, F9, F10, or F12 to access the boot menu, and then you can boot from cd to install your linux operating system
Jan 09, 2008 | Sony VAIO PCV-RX511 PC Desktop
Sony VAIO PCG-K25 Notebook Logo
109 people viewed this question
Top Sony Computers & Internet Experts
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
