Question about Invacare Pronto M51 Power Wheelchair
The left wheel will not move. The led light says left brake fault. How do I disengage the brake?
  • 692 Answers
You can't You will have to replace the left motor/gearbox/brake assembly. The controller checks that you have a good signal from the brake and will not move if it doesn't get one disengaging the brake will not remove the fault and the chair will not move. If Medicare paid for your chair than they wil pay for repair. Contact the provider that sold you the chair and ask if they can repair it or contact Repair Express @ 1-877-581-3733 or Roadrunner Mobility @ 1-800-467-2668 to see if they can have a tech come out to repair your chair. Hope this helps you
Posted on Mar 17, 2011
Golden compass power chair
Each wheel is run by a separate motor. This looks like either bad controller box, or bad motor. If it starts out working fine, then the one wheel stops after a short period of time, then it is probably a controller at fault. However if the motor is overheating due to mechanical binding such as a brake failure (the parking brake) or lacks lubrication causing excess power consumpltion, then the controller will shut down at some poiunt to avoid damaging itself and/or the motor. have a helper put the chair up on cememnt blocks, or woodne boxes etc, so you can observe it running. Listyen to the motor by doing left full and right full turns. The motors should be equally quiet and run at the exact same speeds. Dragging noises indicate a problem. be sure your parking brakes are disengaged. Now with the chair off, rotate eaach wheel by hand. They should need the same amount of force to move. if the bad wheel is harder to turn then it may need replacing or has bad brushes, brakes binding or in most cases dried up grease in the gearbox.
Feb 19, 2013 | Golden Technologies Alante' Power Chair
Blinking yellow wrench light on pride jazzy 614 HD
Your version has a Dynamic Controls model controller and joystick.
Unplug the charger and engage the motor/brake lever so the chair is no longer in free-wheel mode (con't push by hand)
Turn the chair off, wait 5 seconds, turn the chair back.
If chair still does not run and your wrench is flashing you have a problem. Count the wrench flashes - the flash count indicates the error detected. 3, 4, 5, and 6 flashes indicate and error with the motors.
3=Left motor fault
4=Right motor fault
5=Left brake fault (may not be engaged)
6=Right brake fault (may not be engaged)
Any other fault code usually means the electronics or wiring is bad and not worth fixing.
Jan 06, 2013 | Pride Jazzy 614 Hd JAZZY 614HD
1999 F250 4x2 - was stored for 3 months and when I tried to move it - the right rear wheel turns but the left rear wheel won't turn. Took off the brakes and caliper - still won't move. I can move...
Hello, The rear rotor has 2 sets of brakes on it. The other thing is to look for slight movement in the driveshaft when it clunks. Depending on the rearend, some have to have both rear wheels off the ground to turn each side. And of course the trans in Neutral.
With the rear wheel you have an Emergency brake and a drum brake inside the center of the Rotor.
The rear of the brake backing plate has a rubber plug which is covering the Star-wheel adjustment for those drum brakes. You can try to loosen the Star-wheel to disengage the Emergency brake shoes. You can try pulling the brake cables toward the cab, to loosen the cables.
If this does not help, your Emergency brake shoe probably rusted off the brake mount and is jammed inside the drum. The linings fall off the metal like banana skins. I can tell you that if the Emergency brakes are a State safety requirement, you need to consider new rotors because the drum portion is usually trashed with rust.
I hope my Solution is very helpful to you.
Jun 11, 2011 | 1984 Ford F 250
My Drive Cirrus Plus power wheelchair doesnt move, it flashes the first two LEDs in red and when moving the joystick it won't move or make the sound. What could be wrong? The battery is at full charge
The Drive Cirrus Plus power wheelchair is a folding frame chair with a VSI controller. The VSI controller (joystick) will indicate a fault code when it detects a problem with your power chair. It is manufactured by a company called Penny Giles Drive Technology. An LED flash code of 2 on the battery display indicates that the left motor is disconnected. There may be a brake fault also.
The left motor can be disconnected at the plug where the VSI harness plugs into the motor plug. The pins for the motor or VSI output may be pushed back in the connector or not making contact due to corrosion or dirt. Unplug this connector and inspect the pins and make sure they are making good contact and are clean. Spray contact cleaner on the contacts to clean or re-orient the pins to make better contact. The folding frame of the chair may have dislodged the connector. The wiring harness from the motor may be pinched or cut. The brake wires and pins may have become disconnected also. The brake lever may be in the disengaged freewheel position causing a fault, so put the brake lever in the correct position. Strictly speaking, this fault code is for the motor only, but always check the motor/ brake assembly since the wiring runs from the same plug.
A certified technician will have a hand held programmer to read the computer (VSI) fault log and determine the number of error codes for the various components.
Using a digital voltmeter you can check the motor at the plug. The two large wires on this 4 pin plug go to the motor; the two small wires go to the brake. On the resistance scale the motor should read between 0 and 1.6 ohms. The brake should read between 30 to 60 ohms.
There is a chance that the output of the VSI controller is bad. To test this swap the left and right motor output connectors from the VSI. If the error code now indicates right motor disconnected (flash code 4) you have a good VSI and bad left motor. Swap the leads back after you are done with this test.
Try blocking up the chair and see if the motor runs with no load on it or after spinning the drive wheel by hand. You can also inspect the motor brushes for burning and wear. If you pull the brushes, do this carefully and blow out the dust from the motor armature. This may allow the motor to work again for a short time.
You will probably need to hire a technician if, after checking for bad connections and the brake lever in the wrong position, you still have problems. I like to replace the brake/ motor/ gearbox as a complete assembly to avoid future problems. Labor for the diagnosis and reading the fault code log with a hand held programmer should be under 1 hour. A return visit to replace the motor brake gearbox is under 1 hour. Hope this helps.
Dec 25, 2010 | Drive Medical Cirrus Plus Folding Power...
I have a golden companion scooter and it wont move it flashes a green light but i haave no info on where to obtain the trouble codes
The L.E.D. located on the tiller
dashboard will indicate with flash codes what problem is occurring.
L.E.D. Flashes 1 time and pauses, 1 time and pauses…. Batteries are low,
scooter will still operate.
L.E.D. Flashes 2 times and pauses, 2 times and pauses…. Batteries are very
low, scooter will not operate.
L.E.D. Flashes 3 times and pauses, 3 times and pauses….Over voltage to
controller.
L.E.D. Flashes 5 times and pauses, 5 times and pauses….Brake is in the
freewheel position or connection to brake is open.
L.E.D. Flashes 6 times and pauses, 6 times and pauses….Paddle or speed
potentiometer problem.
L.E.D. Flashes 7 times and pauses, 7 times and pauses….Paddle or speed
L.E.D. Flashes 8 times and pauses, 8 times and pauses….Motor
disconnected or faulty.
L.E.D. Flashes 9 times and pauses, 9 times and pause….Controller fault.
I hope this helps they are pretty standard codes I got this from Golden Tech Web Site
Aug 17, 2010 | Golden Technologies Golden CompanioN II -...
When i turn on the chiar the led lights blink, and...
Check the freewheel lever at each wheel. If the brakes are disengaged, the chair won't let you use it for safety reasons... (ever wanted to stop at the end of a wheelchair ramp?)
May 20, 2010 | Pride Jazzy 1113 ATS Indoor Power...
Parking brake disengaged but car acts like it is still engaged and will not move when put into gear and there is a light burning smell. It has a manual transmissin.
Although you've released the parking brake, inside the car, are you sure the cable moved and disengaged the rear brakes ? A physical removal of the rear wheels will be required and parking brake cable and linkage operation inspected. If the cable appears to be a BINDING , a heavy dose of WD-40 will cure it. Hope this helps
May 12, 2009 | 2005 Chevrolet Cobalt
Handbrake indicator light
I'm sorry but i laughed in dismay when I read your problem. The dealer is an idiot clear and simple. It is perfectly reasonable for you to expect the handbrake to be disengaged if the indicator is off.
Yes it is quite possible to drive the car with the handbrake on but you would feel it no question. However if it was only slightly engaged there would indeed be some wear on the rear brakes. The handbrake has merely got a thin metal cable that runs underneath your car that splits into two separate cables which in turn connect to the rear left and right brakes. So there aren't any extra brakes for the handbrake just the ones which are on the rear wheels.
Of course the other thing is you may have a faulty handbrake indicator light. So it's not really about who's fault it is but where the fault lies on the car. I'd go and check out a local garage unless of course your car is still under warranty.
If it is go to another dealer and armed with the info above don't let them fool you
Good luck and i hope you get it sorted
Mar 27, 2009 | BMW X3 Cars & Trucks
Invacare Pronto M51 Power Wheelchair Logo
312 people viewed this question
Top Invacare Health & Beauty Experts
wcdoc1953
wcdoc1953
Colin Taylor
MobilityRepairSpecia...
Level 1 Expert
Are you an Invacare Health and Beauty Expert? Answer questions, earn points and help others
