Question about HP LaserJet 1320 Printer
HP Laser Jet P2035 is not printing the "from address" on envelops and even the "to address" is not being printed on the right spot. The envelope size, tray and feed mechanism are followed exactly as per the instructions
  • HP Master
  • 1,915 Answers
The easy way to diagnose this is to put a regular piece of paper in and print the envelope on that to see where it is actually printing. This is likely a wrong envelop size selected in your software not a problem with the printer. It is only reproducing what it is told to. Also make sure that the paper options in the print driver reflect the correct settings for size of paper.
Posted on Mar 17, 2011
Can HP color laser jet CP1215 print envolpes
You should be able to put single envelopes through the printer. Just be sure to select paper type as envelope as this will slow down the printing process and ensure that the toner bonds to the paper.
Jun 28, 2016 | HP Office Equipment & Supplies
Can't get small envelopes to print correctly on hp laser jet pro MFP M127fw
Go to printer setting options and choose paper size and font size, according your size choose it. I share a more help full links.
Read More Help...
Scale document to fit on different paper sizes
Resize the page or paper
And HP Printer Support
Thanks,
Aug 27, 2014 | Office Equipment & Supplies
We have a Laser Jet Pro CM1415. It wrinkles linen envelopes when printing. Is there a quick fix (adjustment etc.)? It prints slick envelopes OK.
that printer is really not designed to print on those envelopes but the wrinkling is usually caused by to much moisture in the envelope or paper stock. When the printer heats the print stock to bond the toner to the paper in the fuser unit the moisture evaporates and causes the paper to wrinkle. Don't know of a fix for it other than use different print stock.
BuddyMc
16 Years HP tech
Aug 10, 2011 | HP Office Equipment & Supplies
HP Color LaserJet CM2320nf MFP Envelope wrinkles
On alot of printers when you print envelopes theres a back door on the printer to prevent the curling or wrinkles. Just open the back door when doing envelopes.
Best of luck and have a happy and safe 4th of July weekend!
Jul 02, 2010 | HP Office Equipment & Supplies
When printing envelopes the printer suddenly prints fact sheet
have you updated the firmware on your printer? hp has a firmware update utility down load for it that just might help you with your problem. iu fixed a simular problem by using the download
Jun 03, 2010 | HP LaserJet 1320 Printer
How do you print the return address on envelopes on the hpl7780? The return address that I need is there I just don't know how to move it to the return address spot when I put the address in the box
Hi, Make sure your software is set to use the right size envelope and printing layout/direction or orientation. Some software will let you add the "envelope" printing to the document; after which you can preview the print before using a trial sheet or envelope. Some software will even let you move the address elements around for problem solving placement or font issues. If it fits in the "preview" you should not have any difficulties in the print.
Apr 30, 2009 | HP Hewlett Packard Deskjet 6988 InkJet...
Print en enveolppe with hp color laser jet 2600n
Envelopes can be printed from tray 1 or 2. Select the type of envelope you are using from the PRINT dialog box or the driver. In your program, set the margins. Typical margins for a commercial #10 or DL envelope would be: Return Address Top margin 15mm(0.6 Inch) Left margin 15mm(0.6 Inch), Delivery Address Top margin 51mm(2 Inches) Left margin 89mm(3.5 Inches). For the best print quality, position margins no closer than 15mm (0.6 Inch) from the edges of the envelope. Avoid printing on the seams of the envelope. Envelopes with a peel-off adhesive strip or more than one flap that folds over to seal must use adhesives that are compatible with the heat and pressure of the printer fuser. the extra flaps and seals can cause wrinkling, creasing and feed jams, could even damage the fuser.
Apr 15, 2009 | HP Color LaserJet 2600n Printer
How do I print envelopes on a hp p1006 laser printer?
to print envoleps u must first change the printing settings
in the settings u can see the envelop print choose tat
then u can print it
Mar 15, 2009 | HP LASERJET P1006 Printer
My HP 1350 will not print cards/envelopes from the right side of the printer. They have to be loaded on the right but the printer keeps printing in the center.
Printing envelopes with an HP 1350:
If you use MS Word, select ENVELOPES. When address window appears, select OPTIONS on right > select PRINTING OPTIONS > select FEED METHOD option on far right (envelope placed on right of tray face down); select FACE DOWN; select FEED FROM UPPER TRAY. The only problem I have with this is that the address prints off in the lower quarter of the envelope rather than in the center of the envelope as we would write it manually. I am currently working on solving that problem.
Mar 02, 2009 | HP PSC 1350 All-In-One Thermal Printer
Printing envelopes on a hp laser jet p215dn
Please load envelops from tray 1.
When printing from application, just Ctrl + P and OK.
- Nikhil
Jul 10, 2008 | HP LaserJet P2015dn Printer
HP LaserJet 1320 Printer Logo
240 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
