IBM ThinkVision L170 17" LCD Monitor Logo
Posted on Mar 17, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My background on my screen recently developed a purple hue to it, instead of a white. Can this be corrected?
Thomas P
Level 1:
New Friend:
  • Contributor 24 Answers
  • Posted on Mar 17, 2011
Thomas P
Contributor
Level 1:
New Friend:
Answers
24
Questions
0
Helped
8269
Points
78
This is likley a problem with the monitor's signal cable. Try moving the cable around steadily and see if the color suddenly goes back to normal or changes to a yellow hue. If this is the case and you are able to remove both ends of the cable then a replacement can easily be purchased from a local computer store or online. (Try www.amazon.com or www.monoprice.com).
Anonymous
Level 2:
  • Expert 356 Answers
Anonymous
Expert
Level 2:
Answers
356
Questions
0
Helped
81444
Points
991
Purple hue can be caused by loose cable connection on the back of the computer or the monitor itself (some models have attached cables instead). Verify both are plugged in firmly.
If not you can try adjusting the color settings, but the problems get worse sometimes, so you may have to replace it if its too annoying.
Please leave feedback if you found this helpful. Thanks.
When plugged into laptop, projects images with a purple haze
This will depend on the brand, model, cable connection type and OS of the laptop. Most have a color control which you can adjust.
1helpful
White has turned pinkish
sounds like the linear adjustment is out of whack.....most projection type tvs, projection, lcd, plasma, have to be correctly aligned so that the color grids overlap each other to properly display the correct hue being created. you'd need the service code to re-adjust it, or have it serviced. also possible that one of the color grids is bad, but if you have all three (red,blue,green) colors showing on the entire screen area i would doubt it
2helpful
HP photosmart c7280 printing photos with purple hue
Does the c7280 use seperate Magenta and PhotoMagenta cartridges? If so make certain the right cartridge is in the correct slot.
1helpful
2answers
Yellow spot in center of screen
I have recently developed the same yellow spot problem on my Sony KDF-E50A10  50" LCD television...a large yellow circular hue that takes up the bottom center of the picture and is especially noticeable against a white background.  It has been diagnosed as the optical block (light engine) and without an extended warranty Sony refuses to assist with the repair cost.  Repair was estimated at $1,100 plus tax and travel fees to my home.  So you see, it is not only a Hitachi problem.  You would think they could build something that would last more than two years considering the initial cost of over two grand for the TV !
Pictures have a purple hue to them Cyber-Shot DSC-P52
I suspect that the color is fine in the screen, if that’s true I would check the “White Balance.” This control is use to compensate for different light sources. The electronics will respond different for sunny or cloudy days and for incandescent or fluorescent lamps. I suspect that it was taken out of AUTO mode. I find that AUTO works well for most people in most situations.
Select photo or movie mode press menu, select WB, select AUTO.
Top IBM Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
ExpressFiX
ExpressFiX
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
