Question about Kenmore Dryers
It does not turn, it might be the band - Kenmore Dryers
  • Kenmore Master
  • 43,501 Answers
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Mar 20, 2011
How do I adjust it so the blade stays on?
one of the big wheels has an adjustment on the center pivot that tilts that wheel to keep the band running true
turn that adjustment while turning the band by hand and you will see the band run back onto the wheel ( or off it if you go the wrong way)
Oct 04, 2015 | Blade Saws
How d I adjustthe band on 92Dodge Caravan
Low reverse band
Loosen, then back off locknut approximately five turns.
Tighten adjusting screw to 41 in.lb.
Back adjusting screw off 3 1/2 turns, then tighten lock nut
Kick down band
The kickdown band adjusting screw is located on the left side, top front of the transaxle case.
Loosen locknut and back off nut approximately five turns,
Ensure adjusting screw turns freely in the trans axle case.
tighten band adjusting screw to 72 in.lb
Back adjusting screw off 2 1/4 turns, then holding screw in position, tighten lock nut
Sep 25, 2014 | Transmission & Drivetrain for Dodge Ram...
Band adjustment, how many turns out on 1987 300zx
Transmission Bands are adjusted when you rebuild a trans
They do not wear enough to need adjustment
Two things happen
If you turn the screw the wrong way, parts fall inside the trans
& you can't get it back together
Next-- if you need to adjust the band or bands, it is time for a rebuild, as many many parts are worn, long before the slightest band wear.
Mar 19, 2014 | Nissan 300ZX Cars & Trucks
Why doesnt the wheels on my band saw turn when I turn the saw on?I can't even turn them when the saw is off.
Most likely the blade has come out of position and jammed. One place to check is at the guides just above and below the table.
To be sure the guides are correct, Google on "adjust band saw" to find out how to adjust them.
Jan 19, 2011 | Craftsman 12 Tilt Head Band Saw Owner...
I have a calumet watch, and the band is getting dirty. Is there a way to clean the band?
Polyurethane Band
Polyurethane Bands, which are made of soft plastic, may turn hard after 2-3 year's use. Colour fading can also be seen.
If bands are kept wet and in highly humid locations or are exposed to sunlight for a long time, the deterioration of the bands may be accelerated in a relatively short period and some cracks may appear on the band surface. (This is called 'hydrolytic cleavage of polyurethane')
Kindly pay attention to the condition of polyurethane bands, which are often worn in such occasions as marine sports/outdoor activities
  • We recommend immediate exchange when your polyurethane band loses elasticity or develops cracks.
  • Semi-transparent/white/fair coloured polyurethane band may turn a different colour due to light/stain ( or sometimes may absorb colours from other materials). In addition, polyurethane bands have many small holes on the surface, which easily catch and hold stains/other different colour material. Thus it is rather tough to entirely clean polyurethane bands. Kindly replace current polyurethane band with a new one when you find extreme discolouration.
  • There exist some sorts of stains (like oil/cosmetics), which cannot be removed off. Smoking cigarette/long time use may turn the colour yellowish.
CAUTION!
Do not use solvent/chemicals (benzene/thinner/breach) for band/bracelet cleaning!
Aug 24, 2010 | Alessi Watches
White band turned yellow
mcdevito75 here, Sounds like the chlorine in the pool water dis-colored the band, not to mention, possibley the watches mechanism also. Look for a small watch repair shop in your area for a new band and possible remedy for the water inside the watch.
Jul 07, 2010 | Adidas Adibot ADH1325 Watch for Women
I do not know how to change the blade on a dewalt
I'm not familiar with that particular band saw but I have had a few different band saws and they all pretty much work the same.
Unplug the saw and remove the top and bottom wheel guards.
Look behind the top wheel and you should see a large bolt standing vertically it may have a knob on it or it may not, look on the bolt to see if it has stop nuts if so loosen them then turn this knob so as to lower the wheel enough so you can remove the old blade.
Clean the rubber tires on both wheels and install the band with the teeth facing down.
Now the tricky part, adjust the top wheel so that it is firmly against the band and turn the wheel slowly by hand (be sure the saw is unplugged) if the band "walks" one way or another, you will have to find the set screw or set screws that adjust the tilt of the wheel, adjust these until the band runs true on the wheel. When it does, tighten the wheel a litte more and turn again slowly by hand repeat this until the band runs true and it is very tight on the wheel, Put the guards back on before you turn on the power. You should be good to go.
Apr 05, 2009 | Dewalt dw3988 14tpi portable band saw...
Help with my dw100 band saw
Pull the plug on the saw, take off the covers on the upper and lower wheels of the saw.
You will see an adjustment bolt above the upper wheel and below the lower wheel, with the band saw in place on both wheels turn the upper wheel by hand, if the band saw moves to either side of the wheel use the adjustment bolts to center the band saw.
Jan 29, 2009 | Saws
Cobra xrs757 X Band
The x-band is the considered a "trash band". It picks up things like automatic doors at supermarkets and such. About every radar detector made has an X band for non-police radar. There is no way to turn this band off on the XRS-757.
Holding down the dim button for 2 seconds turns the V alert on/off
Holding down the city button for 2 seconds turns the Spectra on/off
Holding both city and dim together for 2 seconds turns K and Ku band on/off.
Dec 18, 2008 | XRS-757 Radar Detector
Jeep grand cherokee revs for to high before changing gear
Message:
My 2002 Dakota has been somewhat confused about shifting as well. It showed a code P1762. I dropped the pan to install a new fluid filter and fluid-(use only ATF+3 or ATF+4). Since the pan was off I decided to adjust the bands. The front band controls the 2nd gear cluster. The rear band controls the 3rd gear cluster and reverse. For a 2-3 shift, the transmission shifts back to 1st gear with the front band while the rear band engages 3rd gear. If the front band does not release the 2nd gear clutches before the third gear clutches engage, the transmission binds, which shortens the life of the transmission clutches. If the front band releases too early in the shift, the engine will overspeed (sounds and feels like a slip) during the 2-3 shift.
The front band adjusting screw is on the driver's side above the shift linkage. The rear band is inside the fluid pan near the filter.
1. Loosen band adjusting screw locknut. Then back locknut off 3-5 turns. Be sure adjusting screw turns freely in case. Apply lubricant to screw
threads if necessary. The front band adjuster is on the outside of the transmission and the locknut requires a 3/4" wrench.
2. Using Inch Pound Torque Wrench C-3380-A, a 3-in. extension and appropriate Torx� socket (T-40), tighten adjusting screw to 72 in-lb. CAUTION: If Adapter C-3705 (from SPX Miller) is needed to reach the adjusting screw, tighten the screw to only 47-50 in. lbs. torque.
3. Back off adjusting screw the number of turns listed below for your transmission.
4. Hold adjusting screw in place and tighten lock-nut to:
41 N�m (30 ft. lbs.) for the front band
34 N�m (25 ft. lbs.) for the rear band
The adjustment screw inside the case is a square head bolt. You will need a 1/4 square head socket to fit your torque wrench.
Band adjustments for each model year:
1994
* Front Band - tighten to 72 in-lb, back off 2-1/2 turns (all transmissions)
* Rear Band
o 32/42RH - Tighten to 72 in-LB, back off 4 turns
o 36/37/46/47RH - Tighten to 72 in-lb, back off 2 turns
1995-1996
* Front Band
o 42RH - tighten to 72 in-lb, back off 2-1/4 turns
o 46RH - tighten to 72 in-lb, back off 2-7/8 turns
o 47RH - tighten to 72 in-lb, back off 1-7/8 turns
* Rear Band
o 42RE/RH - tighten to 72 in-lb, back off 4 turns
o 46RE/RH - tighten to 72 in-lb, back off 2 turns
o 47RE/RH - tighten to 72 in-lb, back off 3 turns
1997-1998
* Front Band
o 42RE - tighten to 72 in-lb, back off 3-5/8 turns
o 46RE - tighten to 72 in-lb, back off 2-7/8 turns
o 47RE - tighten to 72 in-lb, back off 1-7/8 turns
* Rear Band
o 42RE - tighten to 72 in-lb, back off 4 turns
o 46RE - tighten to 72 in-lb, back off 2 turns
o 47RE - tighten to 72 in-lb, back off 3 turns
1999
* Front Band
o 42RE - tighten to 72 in-lb, back off 3 turns. (TSB 21-16-98)
o 47RE - tighten band adj. screw to 72 inch pounds, back off 1 7/8 turns
* Rear Band
o 47RE - tighten band adj. screw to 72 inch pounds, back off 3 turns
+ The 47RH rear band requires a 1/4" hex driver, the front band requires a
T-30 Torx driver, the filter is held in place by two screws which require a T-20 Torx drive
2000-2002
* Front Band
o 42RE - Tighten band adj. screw to 72 in-lb, back off 3 turns
o 44RE - Tighten band adj. screw to 72 in-lb, back off 1 7/8 turns
o 46RE - Tighten band adj. screw to 72 in-lb, back off 2 7/8 turns
o 47RE - Tighten band adj. screw to 72 in-lb, back off 1 7/8 turns
From Bill Konolday's 47RE notes: I usually go a little looser than factory
specs on this front band - backing off the adjustment screw 2 or 2 1/4 turns.
Depending on the circumstances I have backed off the band up to 2 1/2 turns.
* Rear Band
o 42RE - tighten band adj. screw to 72 inch pounds, back off 4 turns
o 44RE - tighten band adj. screw to 72 inch pounds, back off 4 turns
o 46RE - tighten band adj. screw to 72 inch pounds, back off 2 turns
2003
* Front Band
o 48RE - tighten band adj. screw to 72 inch pounds, back off 1-3/4 turns
* Rear Band
o 48RE - tighten band adj. screw to 72 inch pounds, back off 3 turns
2005
* Front Band
back off front band adjusting screw 1-3/4 turns for diesel vehicles,
or 1-1/2 turns, for V-10 vehicles.
* Rear Band
94+ Automatic Transmission Bolt and Nut Torque Specs
* Front band adjustment locknut - 30 ft-lb
* Rear band adjustment locknut - 25 ft-lb
* Transmission pan bolts - 13 ft-lb
I just replaced the solenoid with the recommended transducer and all is fine now. The transducer cost me about $50 at a nearby dealership.
Hope this helps. -zman. rroszman@yahoo.com
Dec 09, 2008 | 2001 Jeep Grand Cherokee
Dryers Logo
26 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
