Question about Sony VAIO® VGN-CR120E PC Notebook
My sony vaio vgn-cr120e won't turn on. The adapter is working.
  • 37 Answers
Perform power cycle. Disconnect all power sources, battery and power cord. Press power button for 5 secs. Reconnect power and start unit again. Do you see VAIO? Do you enter BIOS by holding F2 as soon as you press power button? If not then its probably hardware related, i mean needs service. Otherwise if you see any of what i mentioned above try turning off and then on and pressing F8 for safe mode or repair your computer options and then try system restore from accessories menu or F10 for full recovery with data loss (Restore C drive)
Posted on Mar 25, 2011
  • JPHH Apr 01, 2011
    If the computer turns on but turns itself off call Sony as this is a possible recall
No image is coming out of its LCD. It's diagnosed to have damaged video chipset. It seems its cooling system is inefficient. model: Sony VAIO VGN-CR131E
Hi
Who diagnosed it?
If the surface of the "video chipset" (graphics chip) is damaged it may be possible for a specialist, with an Infra Red Workstation to repair it:
Ball Graphics Array Reflow
or
Ball Graphics Array Reballing
These repairs can be expensive and the fault can come back after repair.
But it might also be a fault with the LCD Panel, the Cold Cathode Backlight or the LCD Panel Power Inverter.
Connect the laptop to an external desktop monitor with a VGA cable, using the Fn + F5, F6 or F7 button to send the image to the external monitor. If no image appears, then the fault is with the graphics chip, if you get an external image then the fault is with one of the other components I mention above.
I hope this helps.
Aug 26, 2011 | Sony Vaio Vgn-cr131e/l / Vgn-cr120e/l /...
HI, I have a VGN-CR120E laptop. This laptop had shutdown certainly when I am using it. Sometime It last about 1 hr, sometime it last 10 minutes in order to shutdown. I had checked the fan/ change the...
It's possibly overheating. If so, you can clean the cooling fins on the heatsink, and/or sit the unit on a cooling "plate"; they usually have a USB plugin to power their fans.
Feb 25, 2018 | Sony VAIO® VGN-CR120E PC Notebook
Got a black screen on a vgn cr120e and the hard drive light is off, i know its hibernating just need to know how to get it out of that state
i have also a vaio cs320 series got the same problem ... try to restert it or take the battery out and restart your vaio it will work for sure hope you have not got some imoportant data
Nov 30, 2010 | Sony VAIO VGN-CR120E Notebook
My Vaio VGN CR120E laptop has been beeping quite obnoxiously every time I start it up for awhile now, and has also started doing it every now and then while I'm using it. The beeps last about 1-2 seconds...
in 99% of cases its detected bad ram connection take out all the ram cards clean the copper pins with a hot damp rung out rag and re insert ram should fix it
Nov 27, 2010 | Sony VAIO® VGN-CR120E PC Notebook
I just install window 7, and now my motiion eye on my vaio vgn-cr120e doesn't work, what can i do?
Click on the Sony support page and download the VISTA driver for this device and follow the compatibility guide below.
http://esupport.sony.com/US/perl/swu-download.pl?mdl=VGNCR510E&upd_id=3586&os_id=28
I
Here are the steps to run the web cam driver in Vista compatibility mode:-
1. Right click on the web cam driver.
2. Click Properties
3. Click on Compatibility tab,
4. Put a check mark on Run this program in compatibility mode
5. Select the operating system as windows Vista
under Privilege Level, check mark "Run this program as an administrator"
6. Click on Apply
7. Click OK.
If you need to see an illustrated view of this procedure, click on the link below.
http://www.sevenforums.com/tutorials/316-compatibility-mode.html
Jun 26, 2010 | Sony VAIO VGN-CR120E Notebook
I have lap top model vgn-cr120e but my motion eye web cam doesn't work what can i do?
UNINSTALL DRIVERS
then restart PC
INSTALL DRIVERS
helpful ??
vote me........
Apr 02, 2010 | Sony VAIO VGN-CR120E Notebook
I have a Sony Vaio CR-120E laptop. The battery on the laptop is dead, so I took it out. Can I run only the AC Adapter to power the computer? Also is there a setting within the computer to set AC Adapter...
Yes, you can start using the laptop only with AC input and there is no extra settings to configure the same. But you will be not getting any backup when the power goes.
Revert back for more assistance
Jan 18, 2010 | Sony VAIO VGN-CR120E Notebook
Sony VAIO® VGN-CR120E PC Notebook Logo
193 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
