Question about GE (PSS26MSRSS) Side by Side Refrigerator
I have model TFX20JR side by side and the freezer is at 20 and fridge at 60, 61 & 62. I just moved in this house and need to make this fridge work.. Please help..
  • 32 Answers
There is an adjustment for both sides as well as vents from one to the other check each of these.
Posted on Mar 17, 2011
I have a WESTINGHOUSE WSE7000SF side by side
Yes, they can and there will be a wayer line on the freezer door side that will also need to be disconnscted at the bottom.
Sep 21, 2014 | Refrigerators
New fridge is making sound like hammer drill in concrete on freezer side in the middle. for approx. 15-20 minutes almost every hour
The evaporator fan is hitting the housing or shroud. There is no other moving part in a freezer.
Sep 11, 2009 | Maytag Refrigerators
How to use temperature settings on Bosch Classixx fridge freezer
You can find most user manauls at, www.managemyhome.com, on the right side of the page. You will need the model number off the product information label affixed to the unit.
Jul 05, 2009 | Bosch Classixx KGV28323 Bottom Freezer...
Not cooling properly GE TFX20JR i tried the defrost timer and it is working, now what other possibly problems could there be? thanks!
Do you have ice /frost buildup on freezer wall?If so auto defrost is not working.3 possible causes ,turn the defrost timer manually to defrost position either measure amps @ 3.5 amps or listen in freezer section for crackling popping or sizzling.If you dont hear/measure this you have a bad heater or defrost tstat .Remove freezer wall look at top of coil for thermodisc 2 wires and 1 or 2 glass heaters (btm,mid coil).Tsat can be bypassed by connecting the 2 wires or checked for continuity closed at approx 20'.heaters may be visibly burnt or broken recommend changing both parts
Jun 19, 2009 | GE GSH22JFR Side by Side Refrigerator
Freezer in my kenmore refrigerator isn't cold
Make sure the freezer fan motor is running. The wires may have come off when it fell.
Mar 08, 2009 | Kenmore Refrigerators
Model #10657058791 freezer and fridge not cooling
Check your connections in the back make sure no wires are lose or rattled lose off of the compressor or anything like that
Feb 09, 2009 | Kenmore 52632 / 52634 / 52639 Side by Side...
GE TFX20JR BK WW side by side won't cool or freeze
First point: The entire fridge is cooled by the freezer section. A fan blows air across to the food section.
2) Every 8 hours or so, a timer shuts off the compressor cycle, and starts up a heater to defrost the freezer coils. If the heater(s) are burnt out, or if the safety thermostat (to prevent overheating) is open, then you will have no defrost. The coils will frost up and eventually prevent airflow to the food section. Milk goes sour.
3) In rare circumstances, the timer itself can stall. This cause the same symptoms as above, but this is not as common as the other 2 causes of No Defrost.
Sequence: Check heater continuity. Check safety thermostat continuity while cold. Check defrost timer operation.
Hope this helps. I am a journeyman with 39 years exp. Happy New Year.
Dec 24, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Fridge does not get cold
I had the same problem. The problem was my freezer was not defrosting itself and for a while i opened up the back and manually defrosted the freezer with a hair dryer (to make it defrost faster) and lots of towels (to soak up all the water). I replaced the defrost heater in the freezer and no more problem. Go to searspartsdirect.com and put in your model # then look for the part. Hope this helps.
Nov 12, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Maytag fridge
Without knowing the type of fridge(side by side, freezer on top etc.) all I can offer is this: Somewhere between the freezer and the fridge there's an opening thermostatically controlled to transfer cold air from freezer to the fridge. Most have a fan to move the air. So either the fan (if so equipped) stopped, and need to replace, or opening is stuck closed, or plugged.
If freezer is working fine, this is the only problem I can think of.
Hope this helps
Dec 15, 2007 | Maytag MTB1504A Top Freezer Refrigerator
GE (PSS26MSRSS) Side by Side Refrigerator Logo
361 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
