Question about Linksys Wireless-G Broadband Router
My Linksys-G power light is blinking and will not recognize connections. the power light is the only one on (blinking) and none of the others light up at all.
  • 583 Answers
A blinking power light indicates it is/has failed the self test and needs repair. Before you replace it, you can try and do a factory reset (you'll have to go back in and reset all of your settings after you do this - if it works). To do a factory reset, press and hold the reset button on the back (with power applied) for 20 seconds. If this does not get your router working, you'll need to replace the router as a new router will probably cost less than repairing this one (unless it is still under warranty).
Posted on Mar 17, 2011
Testimonial: "THANK YOU!!!"
My Linley security is turned off
Posted on Mar 18, 2011
Linksys router not recognize internet
Make sure your router's WAN port is set to dynamic IP. If the light on the front doesn't glow/blink for the WAN port, try a different cable. If a different cable doesn't work it's probably toast. :( This problem appears to be directly linked to the relationship between the WAN port and the modem. Given that the devices can connect to the router, but not internet, it has to be the WAN. Sometimes if the modem goes out it will send too much voltage through to the router and fry the WAN. Had that happen to my parents router. If the above doesn't "fix ya" then try a different router.
Worst case, you might have to put a wireless card in your PC and bridge the modem (wired connection) to the wireless card and broadcast for your wireless devices. At least until you get a new router.
Aug 02, 2013 | Dell Computers & Internet
My linksys router WRT120N is having power light stable but no other lights are neither blinking nor stable!!! need your help
At power up the device runs a self test, it take a minute or so. What is it connected to, what is sending the signal, a cable modem, DSL, etc.? If you have cables runing from the Cable modem or whatever, to the linksys, try another cable, OR, reboot the cable modem, unplug, remove battery, if applicable, remove power from the WRT120N, Insert battery into the modem, plug in, wait for the self test, plug in the Linksys, wait for self test. Connect a ethernet cable from the linksys to the computer. Does it connect? Try to connect wirelessly, Does it connect? Is the Linksys secured with a passcode? If you push the reset button , and hold for a minute, in the rear of the device, it will reset the Linksys to default settings. Try to connect. Did the Linksys work at one time? Did you set it up? Is it on a surge protector? Have you had any Electrical storms? Surges? It may be bad, hard to say until you verify all the steps. Who is your internet provider? Have you verified that they are sending a signal? Comcast will verify ,by phone, that the signal is good and run check on the cable modem.
Nov 22, 2012 | Cisco - Linksys Wireless-n Home Router -...
I own a linksys E1000 wireless router. After a storm & power blink-out, I could not access internet. Notice the 1,2,3,& 4 lights not lit. all other lights on right side were blinking. When I...
Normally on the back of the routers there is a small reset button you can press and hold for 15 seconds. This will reset the unit.
Click here for linksys tech support page. At the bottom there is a live chat option.
-G33k
Aug 09, 2011 | Cisco Linksys Wirelessn Router Black...
We have had a working router for 2 yrs, until my son pressed the middle button of the router. Now none of our laptops 'recognize' and are unable to connect. Our cell phones that used to connect to WiFI...
I just try to reset the router to factory default settings.Here is how:
Step 1:
Take note of the current settings of the router before resetting.
Step 2:
Press and hold the Reset button of the router for 30 seconds.
Figure 1: Location of the Reset button on a Linksys BEFW11S4 router.
NOTE: The image may vary depending on the model number of the Linksys device.
Figure 2: Location of the Reset button on a Linksys WRT54GX router.
Figure 3: Location of the Reset button on a Linksys WRT54GC router.
NOTE: If the image of your router looks different from the ones shown above, consult your router documentation.
Step 3:
If the normal reset does not work, try to press and hold the Reset button for three seconds. The Ethernet light should go OFF then back ON. Unplug and re-plug the router's power adapter while pressing the Reset button. Keep holding the reset until the power light stops blinking.
NOTE: The router must be powered ON when you press the Reset button.
To reset the router via its web-based setup page, follow the steps below.
Resetting the Router Using the Web-Based Setup Page
Step 1:
Access the router's web-based setup page. For instructions, click here.
NOTE: To learn how to access the router's web-based setup page using a Mac computer, click here.
Step 2:
When the router's web-based setup page appears, click Administration then click on Factory Defaults.
kb4008-004_en.png NOTE: If the screen on your router's web-based setup page looks different, click here.
Step 3:
Click on Restore Factory Defaults and select Yes.
kb4008-005_en.png Step 4:
Click OK.
Nov 15, 2010 | Linksys Wireless-G Broadband Router
Linksys has stopped working - no connectivity. I directly connected the modem to computer and it works fine. Power light on Linksys is green but is blinking and does not go to steady green.
You can try to follow the steps from this link to fix the blinking power light of your router, because a blinking power light is a sign of something is bad on the router. But if after doing the steps and still a blinking power the router is already bad and needs replacement.
http://www.fixya.com/support/r3801591-fix_blinking_power_light_linksys
May 06, 2010 | Linksys Wireless-N WRT150N Router
The send light blinks alot
Well if it works perfect and has no problems then no you don't need a new modem. if it is not doing so well and is messing up a lot then yes i would look into one, Other then that sounds normal for a router or ethernet to be active or none active.
You do got random programs on your pc that do connect to internet while not around or not even using or browsen the net.
Jul 23, 2009 | Linksys EtherFast Cable Modem with USB and...
Blinking power light no connection
Try this :
If the Power LED is flashing, then power off all of
your network devices, including the modem, Router,
and computers. Then power on each device in the
following order:
1. Cable or DSL modem
2. Router
3. Computer
Apr 03, 2009 | Linksys WRT350N Wireless Router
Linksys WRT54G router
Yes there's a possibility that the router is dead already because that diag light will only be lit up when there's a hardware failure on it, you can try press resetting the router by holding the reset button for 30 seconds then power it off then power back on hopefully the diag light will be off, if still on you need to replace the router already...
Hope that helps.........
Aug 15, 2008 | Linksys Wireless-G WRT54G Router
Linksys WRT54GS not detected
I am having the same problem with the WRT54XG4 but i discovered that if you disconect the internet port of your router and leave the ethernet port conected to your computer. You can access to the router and you can upgraded.
Hope it help you
bye
Feb 24, 2008 | Linksys Wireless-G WRT54GS Router...
Linksys Wireless-G Broadband Router Logo
288 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
