Question about LG LDF6920 24 in. Built-in Dishwasher
Overheated electrical motor , bad smell .............. the motor may need replacing.............. price ???
  • LG Master
  • 43,501 Answers
That is not that hard to fix and you can easily buy the parts yourself online...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
heatman101
Posted on Mar 18, 2011
I have a frigidare dryer 5-6 years old. Recently, started smelling like something electrical is burning. If I hold down the start button the motor will turn the drum slowly and the burning smell returns....
Check for vent blockages! Overheating may be a serious issue and fire hazzard. A slow moving drum could mean a bad traction belt, jammed mechanical part or the motor is not spinning at a proper RPM which may indicate motor damage also. The electrical burning is a serious issue also and a fire hazzard. Dryers need periodical cleaning to remove excess lint, dust and debris. Lack of cleaning causes the dryer to work harder and run hotter. Excessive heat shortens the life of many parts such as belts, bearings, electronics, wiring, etc...
Sep 21, 2012 | Dryers
Hi my 3/4 hp 230/115 centurian is buzzing and i smell burnt electrics.....what do i need to order to fix?
If the motor can be turned easily by hand then sometimes the starting or run capacitor can be replaced with the same value device and the pump will run. If a new capacitor is installed and it doesn't run then the motor needs to be replaced. If the motor does not turn easily then usually the bearings are bad and the motor needs to be replaced. I hope this helps. The burned smell is either overheated wiring in the motor or a bad capacitor, etc.
Aug 05, 2011 | AO Smith Pool Pump Motor Hayward Swimming...
In my 2004 ford focus I turn my fan on and it runs for a little bit, then stops. About a minute later I smell burning. I turn the dial to 0 and the smell goes away.
Your blower motor is bad and overheating. You need to replace it. What you are smelling is the resin on the windings of the motor.
May 08, 2011 | 2004 Ford Focus
Smoke coming through vents temp. gauge going up acting like its going 2 overheat turn heater on hot and smokes bad turn to cool and smokes a little my husband thinks it's the thermostat and wants to...
If the heater core is leaking, you would get a lot of steam that would smell "sweet". That would also leave you low on coolant, which could be a source of your overheating. If it's more of an electrical smell, you may have a blower motor or a blower motor resistor going bad, but won't cause the engine to overheat.
May 03, 2011 | Ford Ranger Cars & Trucks
Strong burning smell coming from vents and from inside rheem electric central heat. Smells like rubber burning.
You must have to open it, try to clean it..and check for some eletric cables with short circuit or bad cables burning and overheating...check the motor fan and if it has a bad AC capacitor
check the photo, and you will have an idea.v4ndre_0.jpg Good luck!
Dec 06, 2010 | Heating & Cooling
Stadt J90 Heater electrical buring smell when unit fires up smell goes away after 5 - 10min for a day or 2 then comes back. Check but no signs of fire or smoke or burnt area. Unit is old but works well...
Hello
Could be your fan blower motor overheating.Normally you wont see any smoke or burning from this motor.
There are sealed bearings in these motors that go bad and cuase a strain on the motor.Also the windings could be clogged with dirt.
Have a look at the motor after you run for a little while.IF the motor is hot to the touch have it replaced.
Apr 12, 2010 | Heating & Cooling
Overheating/burnt rubber smell
classical sign of a bad motor. the motor has a thermal switch on it telling the unit to shut off when it gets hot. after it cools down, the switch will tell the motor to turn back on again. good luck, i'm pretty sure that's your problem. contact me for further help if needed. thanks :)
Jul 06, 2009 | Kenmore 73952 Gas Dryer
My whirlpool electric dryer smells hot.
generally if the uint shuts off from overheating and then will not restart for a 10-20 min period of time usually a sign htat hte motor is overheating and needs repalcing
Mar 31, 2009 | Whirlpool LER5636P Electric Dryer
Wont start up.
Sounds like the motor is failing. The main cause of failure is overheating due to clooged venting. Is the dryer taking more than 60 mins to dry?? If so then the vent is clogged. Its likely too that the motor is covered with lint and not being able to properly dissipate its own heat, you could clean it and see if it helps but usually once they are shutting down overheated (the burning smell is the motors' internal windings being very hot) they need replacement.
Nov 19, 2007 | Maytag Neptune MDE5500AY Electric Dryer
LG LDF6920 24 in. Built-in Dishwasher Logo
121 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
