Question about RCA RCRN04GR Remote Control
Why does the power button on my universal remote flash three times whenever any button is pushed
  • 61 Answers
Did you tried to change the battery of your remote control,, there will be a posibility that the battery was already weak,,,
Posted on Mar 17, 2011
How do i reset my universal remote... i took the baterry so my daughter couldnt change the channel and when i put it back in, it stopped working...lol
try holding the power button down for about 5 seconds ortill the light on the remote flashes three times it should have and auto program try that
Aug 06, 2011 | RCA Universal Remote Control
MY Sharp LC46D62U wont turn on
Power and OPC LED lights flashes?Common on Sharp LCD tv.Tv is still useable.Tv have Tuner signal board problems.Every times Power and OPC LED lights flashes.Just push the remote power button again and wait.Sometimes Power and OPC LED light will flashes require push power again wait again Power and OPC will flashes two or three time push power button and wait.Must do this two or three time before the backlight will light up and tv work.
Jan 07, 2011 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Need remote code for symphonic tv. Have living solutions giant remote
    Programming a Living Solutions Universal Remote
  1. Step 1 Turn on the component you wish to sync to your universal remote--your television, DVD player, VCR or stereo.
  2. Step 2 Point the remote at the device you are programming and press the corresponding device button on the remote. These buttons are labeled "TV," "VCR", "DVD," etc. Hold the device button for three to five seconds.
  3. Step 3 Push the power button on the remote. This should turn on the device that you are syncing.
  4. Step 4 Push the "Channel Up" or "Channel Down" button on your remote gradually until the device that you are programming shuts off.
  5. Step 5 Press "OK" or "Enter" on the remote once the synced device turns off.
  6. Step 6 Press the device button for the component you just programmed, and hit the power button while pointing the remote at the component. If programmed correctly, the device should turn on, and you should be able to control it with your Living Solutions Universal Remote.
Jun 30, 2010 | Symphonic ST420FF 20" TV
Need Scientific Atlanta 8300HD DVR code
You can follow the two methods I have explained below:
AUTO SEARCH FOR CODE
To program your remote in Auto Search Mode, first turn on the device you wish to program and point the remote toward it.
Then press and hold the SET and POWER buttons until the LED turns on.
Then press the device key ( CATV or RCVR) .
The LED will flash once.
Then press the CH+ button.
Then hold the POWER button for about two seconds until the LED turns on.
Release the POWER button and the LED will flash slowly. Your remote is searching through all of the codes. Continue to point the remote at the device until your device responds.
If your device turns off, turn it back on and press the CH+ button on your remote. Then press the POWER button and CH+ button alternately until the device turns off and the code is correct. Press the ENTER button to confirm and store the code. The LED will flash three times and then turn off.
If the above is not helpful then try manually searching for code:
First, press the device button on your remote.
Then press and hold the SET button. While holding the SET button, press 1 to find the first digit, 2 to find the second digit or 3 to find the third digit.
The LED flashing time will stand for each code number. If it doesn’t flash, it will stand for zero.
For example, the TV code you are trying to find is 102.
Press the SET button and 1. The LED will flash one time.
Press the SET button and 2. The LED will not flash.
Press the SET button and 3. The LED will flash two times.
Hope it helps to find your code. Thank you for using fixya!
Sep 25, 2009 | One For All URC-7800 Remote Control
I have a vextra universal remote control and need the code for a colby dvd player
How to auto program this remote
1. Turn on the device to be programmed.
2. Press and hold SET for three seconds
3 Press the corresponding Device Button (TV, SAT, VCR, DVD,CBL,Audio)
4. Aim the remote at the device. Press the power button once and release. Each time the Remote searches for a code, the device button LED flashes twice. When the device turns off, immediately press ENTER to save the code (before the device button LED flashes again) This could take several minutes.
Aug 24, 2009 | Televison & Video
The power button and number only work on the tv when the vcr/dvd button has been pushed and changing the channel and volume only work when the tv button has been pushed. How can I fix this?
you can set your universal remote to Tv Vcr Dvd and Sat. Just push the TV button whenever the problems occur.
About the power button, it is probably just a default in the remote. if you still have the package, it might have number that you can call to see if you can get a replacement remote in the mail (it is usually much cheaper than just buying a new one) if the package doesn't have a phone number, go on the website.
Jul 04, 2009 | Philips Universal PH301S Remote Control
Have a new Phillips 42" lcd tv. my cable box remote has been working intermittently. However the white light near the remote sensor on the TV blinks whenever I use the cable remote. after changing bat
your TV and, your cable box both "see" a series of invisible (infared) flashes of light like morse code these flases tell them what to do.one answer is to: buy a universal remote so that you can program a button for each device then when you want to control the cable box just push the "cable" button and, then volume etc. to turn your tv off push "tv" then "off" the service man was right but he should have explained this to you
also your cable remote may be programable to work with your tv like a universal remote check with your cable co.
May 22, 2009 | Televison & Video
CODE FOR TDE SYSTEMS UNIVERSAL REMOTE CONTROL
CANNOT PROGRAM THE TDE SYSTEN=MS JUMBO REMOTE WITH CODES FOR A CITIZEN TV
Mar 01, 2009 | Universal Televison & Video
Cannot find a device code for ATT Uverse DVR cable box
1. Release the volume controls and assign them to the AUX: A. Press and hold AT&T Button and OK Button at the same time, release both buttons. All the mode keys will flash twice indicating you're in programming mode.
B. Enter 955 on the remote keypad, the AT&T key will flash twice indicating a correct entry
C. Press the mode key you want to alway receive the volume commands - I assigned mine to the AUX mode button. The mode key chosen will flash three times indicating success. Volume commands will now be delivered to the AUX button regardless of the mode you are in. 2. Assign the AUX to the BOSE system: A. Make sure the Boze remote receiver is powered on (green light is on). B. Press and hold the AUX Button and OK Button at the same time, release both Buttons. All the mode keys will flash twice indicating you're in programming mode. C. Enter the 4 digit BOSE code on the keypad, I used BOSE Remote Code 4000.
D. The AUX Button will flash three times indicating correct entry.
Dec 28, 2008 | Bose Cinemate Digital Home Theater System...
RCA RCR 3273 universal remote
for codes:
http://www.rca.com/codefinder
Nov 27, 2007 | RCA Universal Remote 3 Device Remote...
RCA RCRN04GR Remote Control Logo
48 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
