Question about LG 32LG30 32 in. LCD HDTV
"the audio output of lcd
  • 61 Answers
You just buy an adater to that plugins, you can take a picture to your adio aoutput and bring it to the nearest electronic store,,,
Posted on Mar 17, 2011
When i try to play my x box on my sanyo tv no sound comes out of the tv
Try a different HDMI input and a different cable.
DVI is same as HDMI in regards to the picture signal, but lacks the audio.
Apparently for some reason the TV does not pick up audio and that could be because the HDMI port has a problem (say physical contact) or because the cable has a problem or (of course) because the XBOX does not output signal for some reason.
My first two picks would be the port and the cable.
hope this helps!
www.coppelltvrepair.com
Oct 08, 2012 | Sanyo 52" Class LCD 1080p 120Hz HDTV,...
Magnavox LCD tv external speaker
Hello
The jack you describes here "Digital Ouput Device To" means, you can connect these jacks to the output of a digital device, such as DVD or so. It is meant for to get signal into the TV, not ot out.
HDMI [High Definition Multimedia Interface] is a type of connection, which the TV an be connected to any HDMI device from outside. Both the above said are, signal in to TV connections. Not out.
If you want to connect this TV to any amp or any other external audio devices; look for any audio out option is there.
Feb 05, 2012 | Televison & Video
I have a LG 47 inch flatscreen.i cant find any audio output plugs to hook it up to surround sound.how are you supposed to hook it up.
this is from the LG website about that TV.
- Rear,
2 x Composite video/audio input (RCA phono x 3) - Side,
2 x S-Video input (4 pin mini-DIN),
1 x USB (4 pin USB Type A),
1 x Audio line-out (RCA phono x 2),
2 x Component video input (RCA phono x 3),
2 x Audio line-in (RCA phono x 2),
1 x Digital audio output (optical) (TOSLINK),
1 x Digital audio output (coaxial) (RCA phono),
3 x HDMI input (19 pin HDMI Type A),
1 x RGB input (15 pin HD D-Sub (HD-15)),
1 x Audio line-in (Mini-phone stereo 3.5 mm),
1 x Serial (9 pin D-Sub),
1 x Remote control (Mini-phone 3.5 mm)
Mar 20, 2011 | LG 47LC7DF 47 in. LCD HDTV
The sound from the amp does not match up with the video on the TV. We have 2- 25' RCA jacks, 1 to the "Video" and 1 to the "Audio-R" in the "AV IN 1" section. Are our cables...
If those are rca jacks on tv being used to go to amp ?
Are you sure they are not input TO tv rather than outputs ?
YOu must use the AV out connectors on TV to go to amp.
25 inces is fine.
Please dont forget to vote if you liked my answer
thanks
Feb 13, 2011 | LG 42LH50 42 in. HDTV LCD
How do I connect my Logitech music system to the TV. What connection and plugs is required? Kindly advise.
If your music system is only audio,then you need two RCA type audio cables pair for left& right audio channels(male pin jacks).Connect them at Music system audio output with left & right channels accordingly while on yr TV,connect the other ends to the audio Input jacks(female type). If there is a video out also from your music system then add the yellow video cable as well in the same way.
Aug 23, 2010 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
My self diagnosis problem. (standby)imdicator is flashing in red,six times between two second break ??????
Information from Sony:
Audio Output Error (6X)
There are three possible failures that can cause a 6X protection mode, and they are as follows.
Short Audio Amplifier Outputs
Lose of 15V Supply
Lose of 9V Supply
The key to determining what to check first is if audio is heard before the TV shuts OFF.
If audio is heard before the TV shuts OFF, then the next step is to check the 15V supply at CN7503/pin 1. If the voltage is missing replace the G1/G2-Board. If the voltage is present, first check the fuse PS7001 for a possible easy fix. If the fuse is OK replace the AU-Board.
If no audio is heard before the TV shuts OFF check for 9V at CN9502/pin 1.
If the 9V is missing replace the BU-Board. However, if the 9V is present check and confirm that the protection circuit output voltage is making it to the Main Microprocessor IC1001/pin 26. If 2.8V is present at IC1001/pin 26 then the Main Microprocessor is defective. Replace the BU-Board. If the voltage at IC1001/pin 26 is 0V then the audio output circuit has actually failed. In this case, replace the AU-Board. A shorted audio output or a DC voltage level measure across the audio output will cause a 6X protection mode indication. In either case the problem will exist in the audio circuitry on the AU-Board.
May 24, 2010 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Need to locae he audio outputjcks on my 32 in LG
Here is the list from the spec. sheet of all of the connections available on your TV
1.0 x HDMI ( RCA phono x 3 ) - Rear , 1.0 x Composite video/audio output ( RCA phono x 3 ) - Rear , 1.0 x VGA input ( RCA phono x 2 ) - Rear , 1.0 x Remote control ( 4 pin mini-DIN ) - Rear , 1.0 x S-Video input ( 19 pin HDMI Type A ) - Rear , 1.0 x Serial ( 4 pin mini-DIN ) - Rear , 1.0 x Composite video/audio input ( RCA phono x 3 ) - Rear , 2.0 x Composite video/audio input ( Mini-phone stereo 3.5 mm ) - Side , 1.0 x Audio line-in ( 15 pin HD D-Sub (HD-15) ) - Rear , 1.0 x S-Video input ( RCA phono x 3 ) - Side , 1.0 x Audio line-in ( TOSLINK ) - Rear , 2.0 x Digital audio output (optical) ( 9 pin D-Sub ) - Rear , 1.0 x HD component input - Rear
Nov 20, 2009 | LG 42LC2D 42 in. LCD HDTV
Cant connect my wireless headphone to my lcd tv?
Hi,only through a Music system   because the TV has no port  unless u want to temper with the mother board  of the set .
This is the easiest  method  for u to enjoy ur headphones coz music systems has the headphone jack pin  socket .
good luck
Oct 02, 2009 | Panasonic DMR-EZ47V DVD Recorder/VCR
Using different speakers for TV
If it does not have anything besides optical it will not work unless you have a system capable of optical input (some Logitechs have it, but don't remember which ones, i know that the Z-5500 does certainly have it but that's not too cheap).
Weird that it doesn't have a a headphone jack indeed. But if it doesn't, that optical digital out is the only way to connect it.
Jul 02, 2009 | Televison & Video
No voice
first u have to chek pri amplifier stage 4 exp
at the back of it theres a pin av out put insert a pin (av pin )in audio out put n the second end in (take any amplifierto which there' audio in put 4 eg a music system)the music system play n c it aux on ur music system if there's audio there's audio then pri amplifier is ok there' prob with ampli card replace it
if not contact on my no 9764434445i will b happy to help
Oct 15, 2008 | Sharp Aquos LC-30HV4U 30 in. LCD HDTV
LG 32LG30 32 in. LCD HDTV Logo
Computer Repairing
Computer Repairing
