If you will make contact with George at M-One-Specialites he can track that down for you and help you get that fixed. He has a very extensive list of repair parts for faucets.
First turn off the hot and cold water supply taps. Then to remove the spout you simply unscrew the spout cap counter-clockwise; you should then be able to lift the spout up and off the supply post.
Go to this website and you can download an instruction manual for this faucet. Good Luck! http://www.moen.com/chateau/chrome-one-handle-low-arc-kitchen-faucet/_/R-CONSUMER%3A7437
Does it turn off when you push on it, put pressure on it. Make sure the handle is not interfering with the escutcheon. Does the handle keep turning all the way around? You may have not installed the stop or posi-temp gear.
I'm sorry to hear you are having trouble with Chateau faucet. Please call our consumer services at 1-800-BUY-MOEN and they will be able to help you out with the problem.
On a Moen Faucet the set screw is behind the little "blue and red plastic tab", remove this tab very carefully with a small flat screwdriver. Then you should be able to see the set screw. make sure to turn of the water supply under the sink first. The set screw will probably be an "allen head" type and you will need an allen head wrench. This is a hex shaped 6-sided tool in a rod shape and is available at your local hardware in a set. Next you will need the model # of your faucet and take this to your local hardware to match with a repare kit. Moen usually has a lifetime warranty and if you have your paperwork just call Moen directly and they will send you a free replacement kit, free shipping too. The kit has installation instructions with it.
take a good look at top of faucet,w/handle assmb,off there is a small brass/cooper colored,horse shoe shape clip that must be removed to remove cartridge.i think that's your after.
Yes it is fixable and easy.To save you time because I belive you will be needing a new part from Moen I am sending you this easy link to quickly resolve your issue. Just be sure to tell Moen you are original owner of faucet and all parts are lifetime free including shipping. Go Moen!!!
