Question about Poulan Garden
Im trying to put a new ignition switch on my Poulan make: PO17542LT model no: 960120100...I need a wiring diagram if possible. There are letters on the back of the switch I need to know which wires go to which letters. Thank you
  • 32 Answers
It should be in the owners manual or repair manuals or you will need to get it from the dealer or parts supplier.
Posted on Mar 17, 2011
2008 audi a6 ignition switch wiring diagram
Take out the 30th fuse from SB42, in the instrument panel fuse box for 30 seconds and then reinstall. This will reset the control module.
Jun 23, 2016 | 2008 Audi A6
Fuse diagram for poulan model: po17542lt size of fuse and the location of fuse
20 amp automotive-type plug-in fuse. The fuse holder is located behind the dash.
Feb 12, 2015 | Husqvarna Outdoor Poulan PO17542LT Lawn...
Calibre thermo fan wiring diagram
never ever wire to the ignition or other EFI parts
no car model stated, no year, and no engine option type, size etc.
A SUZUK, something...
the cooling fan wires to ground and power via a thermostatic switch
best is to wire it to IGN1, feed at the ignition key .
using an inline fuse.rated for you r fan draw.
if you trust that new switch (id not) some wire it to the battery
but if it sticks on , it will drain the battery.
post car spec. what car, so i can tell you exact wire location.
Jan 18, 2014 | Suzuki Cars & Trucks
I have a 70 F 100 that im wanting to put the ignition system and motor out of a 76 in to it. im having problem figuring what color wires i need to splice the red and the white wire in to. or i would like...
Put the red wire to the ignition on, and white to ignition start, You can place the red wire on the opposite side of the battery on the starter solenoid and the white on the igition terminal on the starter solenoid.
Jun 19, 2011 | Ford F-100 Cars & Trucks
I replaceed spark plug,and still on spark. Whats next? (poulan 4218) chainsaw
Remove the flywheel side cover to expose the flywheel and ignition module. Check the flywheel magnets to ignition module gap with a thin business card for a gauge. If ok, remove the grounding wire that goes to the ignition switch and try for spark again. If still nothing, it's new module time. If removing the grounding wire got it to spark, replace the ignition switch or perhaps the grounding wire has shorted out on it's way to the ignition switch. Hope this helps!
Apr 17, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
My dog tore out some wires on lt1000 17.5 hp ridng mower. inow have it wired so it will start and run,but have one wire i dont know where it goes. from the ignition switch the blue is hot the black im not...
If you unplug your harness from the key switch on the back of the key switch you will see by the terminals letters stamped a S for solenoid a L for lights B for battery G ground and a M for magneto. This will tell you were the loose wires should go. Hope this helped.
Mar 17, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I need to rewire and ignition switch for a Murray riding mower, model # 0-40606X8B. What is the wiring?
The switch uses a plug in block so there is no "re-wiring" involved. There is a potential problem if you get the wrong switch. There are several switches with the same terminal patter so it is possible to get a switch which will mount to the new switch but can cause a dead short when you key the switch. Be sure the letters next to each terminal on the switch match on the new switch.
Sep 13, 2009 | Garden
Car wont do anything when key is turned on.
magnetic pellet ,doesn't have one . Besides it's not a magnetic pellet . It would be a resistor pellet for the anti- theft system , which your vehicle does have . And it wouldn't be the ignition lock cylinder either if you can turn the key to the start position . Possibly the electrical part of the ignition switch . Viewing a wiring diagram for power flow and checking with a DVOM - digital volt ohm meter would be the proper way to diagnose .Free wiring diagrams here http://www.bbbind.com/free_tsb.html Enter vehicle info. year , make , model and engine size . Under system click electrical distribution ,then under subsystem click on power distribution . Click the search button then the blue links . The light's work because they have seperate power supply ,looking at first diagram you will see this . Thrid diagram down is ignition switch power feed . Top right of the page you will see the letter A , that gets B+ voltage from fusible link B . Finding the ignition switch under the dash on the bottom of the steering column an testing for B+ voltage on the red wire . If B+ voltage is there fusible link is good . Fusible link B is attached at the starter solenoid .B+ stud . If there is B+ power to the ignition switch check for power from the switch .Can you figure that out ? You should also check out some videos on youtube for basic automotive electrical testing .
Electric Testing Techniques You Need to Know
Oct 12, 2017 | Chevrolet Camaro Cars & Trucks
Garden Logo
159 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
