Causes of multiple paper picked-up when printing, I use same substance of bond paper as before. hope u would help me. Thank you and more power to all
  • 583 Answers
This is usually caused by static cling which can be caused by too low humidity or it can be due to too much humidity where the paper just clings together... in either case, the remedy that usually works is to remove the paper and fan it (both ends) and then put it back into the tray. When paper is not in use, try to keep it sealed in a plastic bag or in a cool, dry, storage area. Paper that has been sitting in unsealed packaging (airtight) for more than a few months can absorb too much moisture and cause this very problem.
Posted on Mar 17, 2011
SOMEBODY CAN WE HELP US? WE HAVE A PROBLEM WITH DUPLEX LEXMARK X644.
If you mean that you are getting a ghost image of the letterhead on the page this is caused by not setting the paper type to letter head which caused the temperature to be wrong and print does not bond. Or you may have a bad fuser or bad toner cartridge. Try setting the paper type to letterhead or bond first to see if that helps.
Aug 07, 2014 | Lexmark X644e All-In-One Laser Printer
I have a Kyocera FS 3920DN. When i prints the papers come out torn / tearing in the middle of the lead edge ( intermitted ) I look at everywhere but can't not find any stuck paper or anything that can...
Clean the paper residue from all the rollers in the paper path. This can be done the hard way with alcohol and swabs or you can get cleaning paper from office depot or other stores of the same type. The paper has both sides covered with a sticky substance that will pick up paper lint but will not foul the rollers.
Feb 20, 2014 | Office Equipment & Supplies
We have a MFC8460N, when we go to make copies there is a loud clicking noise & it says 'paper jam' & will not make copies
Hi
The clicking sound comes from the paper tray. The problem is that the paper gets jammed when it feeds the paper and it will sound clicking because the printer cannot pick up the paper at the tray.
What you will do is to put bond paper into a tray but the paper head should not be so tighten. Just put the bond paper with the top paper in upward position.
Please rate and make a comment if you find this solution very helpful and might help others as well. Post more comments if you need more help.
Regards and thank you for using Fixya !
May 02, 2011 | Brother MFC-8460N All-In-One Printer
Paper comes out crooked.
A piece of paper or something traps the paper path then remove it or sometimes it happens when using a thin paper or substance 16 of bond paper, use only substance 20 or 24. Goodluck
Jan 12, 2011 | Lexmark X75 All-In-One InkJet Printer
My hp laserjet 3005 does has paper loaded in try 2 but always prompts me to load tray 1 to print. I would like the printer to print from tray 2 when it's loaded and try 1 is not loaded. Thank you.
Thank you for contacting FixYa with your printer inquiry.
This is a common problem. The device can be set to print from tray 1 if it is loaded, or to print only from tray 1 if the type of media selected is other than standard bond.
Pull out tray 2 and make sure the paper size adjustments are properly set to match your size of paper. If you are using std bond and the adjustments are set to A-4 it won't pull paper.
HP Control Print Jobs Support Page: http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=115&prodSeriesId=1846088&prodTypeId=18972&objectID=c00764862
HP Support Page: http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=c00764851&lang=en&cc=us&taskId=101&prodSeriesId=1846088&prodTypeId=18972
Hope this helps helps. Please keep us updated and remember to rate this answer.
Sep 02, 2010 | HP LaserJet P3005 Printer
My xerox 3119 frequently pick up more than 1 paper during printing. It cause paper jam and make it very hard to print of both side of the paper. Can you help me solve this problem?
The xerox laser printer rollers have shrunk, causing the paper to be picked up in multiple.
Try to fan the paper before adding it to the paper tray.
Aug 11, 2010 | Xerox WorkCentre 3119 Laser Printer
HP laserjet p4014n "Load BOnd paper in tray 1" issue. A couple of weeks ago all the P4014n printers on our network started getting out 0f paper messages on our 2003 servers. The users have to push the...
Check the media settings for your paper trays. Make sure they are set properly, also check the diver media settings. Is the problem happening with a specific print job? If it is check the page setup for that document.
Jan 26, 2010 | HP LaserJet P4014n Printer
Miss feeds when print multilpe pages
The paper feed solenoid is sticking, it can be seen thru a hole in the back with the door opened. Not easy to get to, but I have been able to bend the stop tab slightly and run just fine.
Sep 02, 2009 | Konica Minolta magicolor 2300DL Laser...
My Canon MF3240 picks up too much paper and causes a paper jam every time I print.
If the automatic document feeder picks up multiple pages instead of single sheets, the separator pad inside the automatic document feeder needs to be cleaned.
Aug 05, 2008 | Office Equipment & Supplies
Copystar 1635 copier/printer set up problem
What the problem sounds like is that the machine and print driver are set to diifferent paper types.
One says plain paper and the other bond paper.
Or something like that, the machine says bond and the printer plain paper.
Chech the size setting and paper orinentation.
Most of the time the paper type is wrong. Also check paper color etc etc. Something between the machine and driver is mismtached.
Feb 12, 2008 | Office Equipment & Supplies
27 people viewed this question
jasbo
jasbo
