Question about Sharp Televison & Video
On our Sharp 27' box television :) there is a solid black box on the bottom of the screen, so you only can see the top half and the sides of the picture!
    Genius:
  • 1,112 Answers
Hi: Check your closed caption mode you have closed caption text selected. Look on yoiur remote for a button labeled CC or look in the menu for closed caption and turn or select the off option.
Posted on Mar 17, 2011
The top half of the screen is at the bottom...and the bottom half is at the top of the screen...theres a black line through the middle...why is this happening please...
The fault is with its vertical scan output stage circuit. Contact any service technician. This is not a user reparable fault. [Out of Sync: picture].
Gopakumar Gopalan Google
Feb 11, 2014 | Proton MM2701VT 27" TV
I have a 27" TCL 29T18. The top half of the screen went black and the bottom half has the top half of the picture. Help please!!
1-to solder vertical integrated circuit 2-see if any electrolitic filter is blow up-or 3-verify +24vcc 4-replace all electrolitic-filters.
Oct 02, 2013 | Panasonic CT25G7 25" TV
I turned on my tv and it has solid black grey and colored lines on left half of screen.
It sound that the T'Con board has damaged. Your TV need a thorough check up. Contact any expereinced service technician.
Jul 13, 2012 | Insignia 42" LCD Flat-Panel HDTV
I have a Sony FD Trinitron 27' Model # KV-27FV310. It is approx 8 years old. After turning it on and watching a full screen for a few minutes; all of a sudden, a line came across half the screen;
top half missing is in vertical circuit of set---if it is a 27 inch and this old consider retiring it and replacing----other option is consider having a shop repair it--a rough guess would be as high as 150 dollars parts and labor is possible for your problems.
May 01, 2012 | Televison & Video
Black box is taking up bottom half of the Screen
Check your closed-caption settings and make sure it's turned off. You'll probably find it's now set to text mode. The set is blanking out the part of the screen where text would be displayed, but there isn't any.
May 25, 2009 | JVC AV-27D302 27" TV
Top part of screen is black
A "black box" sounds like the close caption is turned on. Go into the menu and make sure it is off. If it is not close caption, you have a bad problem. If the top half of the picture is missing, this sound like a panel problem. The panel will need to be replaced. Panels are not cost effective to fix. Buy a new tv.
Nov 15, 2008 | iLO V27DMBX Television
Model 42mf231d/17 42" plasma
If the loss of picture is either on top half or bottom half of screen. there are y buffer boards that go from top to bottom on left side of screen when looking at back that control those sections. when there is loss of half of picture then buffer associated with that area would be at fault and would need to be replaced. when i see a degrading symptom such as loss of picture on top half or bottom half leading to no picture issue normally you would check heat syncs on y sustain board and if not heating up after a few minutes of being turned on would recommend replacing y main and both y upper and lower y buffer boards as they complete a circuit
Jun 04, 2008 | Philips Magnavox 27MS343S 27" TV
My screen Half Black - Half Red
you have a warranty! the set has a problem either with the panel or the main board take it back to the store where you bought it and exchange it or have it repaired by a factory authorized repair place.
Mar 02, 2008 | LG 32LC7D Television
Picture partially cropped at bottom of screen
Normallly, if the picture size button on the remote for the television does not achieve the desired affect, then, a cable box or a satelite box is where the change needs to be made.
For example:
A Motorola Cable box needs to be set up to go to a wide screen or zoom when an analog signal is detected.
Some Dish Network boxes have Size buttons on their remotes and also in their main menu.
It's difficult to determine the repair without knowing the types of the peripherals.
Hope this helps.
Dec 24, 2007 | JVC AV-27230 27" TV
Picture Problems
Closed Caption is turned on. Go into the menu and simply turn it off and this will take care of your problem.
Jun 10, 2007 | Olevia LT27HVX 27 in. LCD Television
Televison & Video Logo
48 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
