Question about Power Acoustik Pcnc3.0f 5 Farad Digital Power Stiffening Capacitor
How long will the cap last not in use.? Are the neons on during use. if charge again what do i use . what should the cap read not in use .But hooked up to 12v. and unhooked.?
    Problem Solver:
  • 8 Answers
I think it will read anywhere Between 12 and 14 Farad.. not Positive but hope this helps ;-)
Posted on Mar 17, 2011
I'm trying to locate the oil sending unit on a 2001 plymouth neon
How many miles on the car? I recommend hooking up a direct reading oil pressure guage. Oil level is not the only factor on oil pressure. As an engine ages, clearances and bearings wear and the pressure falls. Using too thin oil can result in low pressure.
Jan 02, 2015 | 2001 Plymouth Neon
Why is my 2005 dodge neon sxt automatic significantly jerking at 60 mph?
You have an intermittent problem, and it's probably going to be horribly difficult to track down. Your best bet might be to borrow an OBDII scan tool so you can read the codes while the problem is happening.
That mechanic who visually inspected your camshaft position sensor apparently doesn't understand that the sensor can LOOK just FINE while at the same time it's as dead as a doornail. You might try having that one sensor replaced, just to be sure.
Aug 04, 2014 | 2005 Dodge Neon SXT
My 98 dodge neon's speedometer started jumping up and down while driving, then the air bag light came on and stays on, next the car started making a puttering noise and sounds kinda muffled when shifting...
Hi. Look like your charging system is down. Check battery first, alternator fuses relay responsible for charging. Your battery doesn't have or hold voltage and air bags are first in the system as good indication of power lose unless is actual air bag fault
Apr 27, 2017 | 1998 Dodge Neon
Describe how to connect a scosche 500k micro farad
Put the capactior in parallel with your battery right before the amplifier. So Postive lead of cap to your 12 Volt line and negative lead goes to ground. It is also suggested that you charge the cap before placing it directly in parallel with the 12 volt rail. yo ucan do this by using a 1000 ohm resistor with a power rating of 1 watt. Disconnect your amplifiers so it is just your cap and battery. Replace the fuse with the 1000 ohm resistor. Once the resistor is in place hook up your cap. It will take a little bit for it to charge. RC time constant is T = Reistance X Capacitance. So 1000 ohms X .5 Farads = is about 8 minutes, or you can just measure the voltage with an volt meter and when the cap reads 12VDC you can then hook it up. BE CAREFUL NOT TO SHORT TERMINALS. THIS CAPACITOR I STORING A LOT OF CHARGE.
Jan 26, 2010 | Car Audio & Video
1996 Plymouth Neon stalls on highway during hot weather
Those cars are bad about the cam sensors going bad wouldnt hurt to repalce as good maintenance.
Aug 05, 2009 | 1996 Dodge Neon
Boat battery charging issue
Hook up a differant bank and see if it says charged, check volts of battery must read 12.6 volts to be fully charged. If it dont bad battery
Jim OMC Retired Mech
Jul 01, 2009 | Boating
95 neon revs to 2500 and holds by itself, will stalls while drvin
check coolant temp sensor need to see if it is reading -40 degrees
May 11, 2009 | 1995 Dodge Neon
Errattic temperatures in Freezer
Check out "victory-refrig.com" for manuals, diagrams, etc.
Cap tube systems are "critical charge systems". Can be difficult to get right. You did not mention pressures that you had. The split on the evap vs.box temp is almost always 10 degrees for freezers. If you want a -10 box, your evap needs to be -20. As a general rule of thumb, you want the high side to be "ambient +30". This seems to work most every time. Your problem might be operations related. Them leaving the door open alot and so on. It could also be a problem with the evap fan or the control to it. It could also be that since there had been a problem with the unit, they are now constantly checking it. Could be checking during a defrost cycle. When your box is at 0 degrees, your pressure should be about a -10 and no less that a -15 degree for the evap. You may have to babysit this thing and see how far it will pull down. You may have a weak compressor. Also, I have had many Hobart freezers fail due to dirty condensers. This causes the oil in cap tube systems to gel and clog up the cap tubes. The only fix is replacing the cap tube. There are alot of variables here so be patient, it's not going to be a quick fix. One last thing, since R404A can fractionate, you really need to pull the charge out and weigh in the correct charge with virgin refrigerant. This will eliminate 2 things. 1, it will ensure the correct amount of refrigerant and, 2 no chance of having a poor mixture of refrigerant in the system causing inconsistant readings and performance.
Hope this helps. And remember, cap tube systems are performance measured by the amount of superheat just prior to the unit making temp and cutting off.
Jan 07, 2009 | Victory Commercial Freezer VSF-3
I have a diagnostic code of p0700 and p1684 coming up for my 2002 dodge neon...anyone know what that means??
Hey, Code 0700-Transmission Control System (Malfunction Indicator Light Request)
Code 1684 -Battery disconnected during last 50 starts
Nov 30, 2008 | 2003 Dodge Neon
Power Acoustik Pcnc3.0f 5 Farad Digital Power Stiffening Capacitor Logo
115 people viewed this question
Top Power Acoustik Car Audio & Video Experts
Tygh Duval
Tygh Duval
Professor_V
Professor_V
Are you a Power Acoustik Car Audio and Video Expert? Answer questions, earn points and help others
