Accidentally pressed a button on the remote which has returned our 26' dynex rc701da hdtv to setup mode cannot get it set up again despite following instructions always ends up "plse run channel auto scan" plse help
    Genius:
  • 1,112 Answers
Hi:
The unit is telling you to run autoprogram to program in your channels, make sure also the TV is in cable mode and not TV mode which is for local channels, If you have cable do a autoprogram so the set can program in channels. Auto Scan is the same as autoprogram.
Posted on Mar 17, 2011
  • mary_greg Mar 20, 2011
    the fix was to select cable then input and components (not tv)
My closed caption on my new dynex 26L 150A11 will not turn on. I have followed all instructions in the book. I need the cc. any one have an answer? thanks cosycat
There are several possibilities here so you will need to work with me to resolve this problem. In order for Closed Captioning (CC) to work, you need to make sure the CC settings are correct on the TV, and then make sure they CC is switched on. In addition, if you are using a cable or satellite receiver box, CC also needs to be switched on for these "boxes".
It's easiest to start with the TV. Please make sure you have done the following:
1. Check the Closed Caption settings are as follows from the TV on-screen menu as follows:
a) Press the "MENU" button on the DYNEX remote
b) Press the RIGHT arrow twice to highlight the "SETUP" menu
c) Press the DOWN arrow once to open the "SETUP" menu
d) Press the DOWN arrow twice to highlight "CLOSED CAPTION"
e) Press the RIGHT arrow or the "ENTER" button once to open the CLOSED CAPTION MENU
f) Make sure the Closed Caption option "CC MODE" is set to "ON". This can be changed using the UP/DOWN arrow keys to highlight "CC MODE" and using the LEFT/RIGHT arrows to switch between off and on.
The "Basic Selection" and "Advanced Selection" settings are for analogue and digital closed-captions respectively. In addition, the "Options" sub-menu can be used to change the size and style of the digital closed captions (Advanced Selection). All three of these options should eventually be set according to your personal preferences, but for the purposes of making sure it is working, I suggest you set them as follows:
Basic Selection = CC1
Advanced Selection = Service 1
These options are the basic settings which will display only the spoken dialogue of the TV program.
g) Press "EXIT" on the remote to close the menu and return to viewing mode.
2. Press the "CCD" button on your Dynex remote control. This can be found in the bottom right-hand corner of the remote. Each press of the "CCD" button will cycle the closed captions between ON and OFF. (CCD means Closed Caption Display)
3. Check the Closed Captions are displayed and then adjust the Basic and Advanced Selection options until the type and appearance of the closed captions are how you like them.
If you have done the above and still cannot get it to work, please let me know whether you are using a cable or satellite receiver and the brand/model number. I will then be able to assist you further.
Regards,
BElectric
Dec 30, 2010 | Dynex 32 in. LCD Flat-Panel HDTV
Some of my video setting are not highlighted how can I acess these settings?
If you are in analogue mode, switch to digital mode - usually marked as DTV on the remote. Alternatively, if you are already in digital, switch to analogue mode - again press DTV on the remote.
Some menu/setup/picture options are only available in analogue and others only available in digital. Don't ask why . . . it's stupid.
Please rate my solution if this helps. Thanks.
Oct 14, 2010 | Dynex 32 in. LCD Flat-Panel HDTV
Hi i have a dish network universal remote cant seem to get the right code for tv
Turn ON the electronic device you want to program the remote to control.
Press the TV Mode button on the remote until the appropriate mode light is flashing.
Press the Power button. The mode light will stop flashing and stay lit.
Press the Up or Down arrow button to set the remote to the next code. The Down arrow button scans backward and the Up arrow button scans forward.
When the correct code is reached, the device (whether a TV, VCR, or other) will turn off.
Press the pound key button to store the code in the remote control memory. If the code is valid for your remote, the mode light will blink 3 times.
Turn the device back ON by pressing the Power button.
Press sat mode key once you power back on the tv to be able to operate the receiver box.
Try some other functions to make sure you have the correct code. Occasionally the Power button may work when others do not.
If the other buttons work you are finished.
If the other buttons do not work, repeat the previous steps. The scan will resume from the last code stored.
The mode light will flash rapidly when the scan has returned to the starting point and all codes have been tested for that mode. The remote control may not control some device models.
Jun 30, 2010 | Dynex 32 in. LCD Flat-Panel HDTV
Need code for dynex television, using a nexxtech 1519000A remote.
Programming with Code Search
1. Manually turn on the device (TV or
Cable box) to be controlled.
2. Press and hold the P (Program) button
until the red indicator stays on. Release
the P button.
3. Press and release the desired mode
button (TV or Cable). The red indicator
blinks, then stays lit.
4. Press the Channel Up button repeatedly
(up to 300 times) until the device to be
controlled changes channels. If you
accidentally overshoot the desired code,
press the Channel Down button to
backtrack through the library until the
device changes channels. Pressing
Channel Up changes the direction to
forward again.
5. Press and release the Enter button to set
the code.
If the device does not have a Channel Up
button, use Power instead. If you go all the
way through the code library without
finding the correct code the indicator blinks
a few times then goes off.
Feb 05, 2010 | Dynex 24" Standard-Definition Digital TV
When I click chanel up or down the tv says please
For the Dynex ZRC-102 remote control channel switching.
1. Press the MENU button and select SETUP.
2. Go down the list and select FAVORITE CHANNEL MODE and switch it to OFF.
The +/- CHANNEL buttons will then switch channels when pressed.
Sep 28, 2009 | Televison & Video
Dynex 42" HDTV - pressed "Comp" button now cant get back to TV
Press the TV button on the remote. You are confusing the Comp button with the Input button which allows you to switch between input ports.
Dec 14, 2008 | Dynex 32 in. LCD Flat-Panel HDTV
Sony PCS-1 dont remember admin password
1. Access the Setup menu as follows:
Press and hold the MENU button on the remote commander.
2. Select Dial using the �� button on the remote commander.
3. Access the Service menu as follows:
Press 7 then 2 on the remote commander (without pressing the
PUSH ENTER button).
The Service menu appears. (See Figure 1.)
NOTE: To cancel Service mode and return to the Setup menu,
select Cancel using the arrow buttons, and press RETURN
Clear setup and FINISH
Bye Zamani Ali
azamani@iooc.co.ir
Nov 24, 2008 | Sony PCS-1 (PCS1) Video Conference
ORIGINAL SETTING
Hi Jun,
see below....
Changing the Display Language
To change the language that is displayed on the control panel,
take the following steps:
1 In ready mode, press the Menu button ( ) on the control
panel until you see “Setup” on the bottom line of the
display.
2 Press the Enter button ( ) to access the menu.
3 Press the Enter button ( ) when “LCD Language” displays
on the bottom line of the display.
4 Press the scroll button ( or ) until the language you
want to use is displayed.
5 Press the Enter button ( ) to save the selection.
6 Press the On Line/Continue button ( ) to return to
ready mode.
Aug 08, 2008 | Samsung CLP-510 Laser Printer
PCS-1
Reset password sony pcs-1
PUSH ENTER button).
select Cancel using the arrow buttons, and press RETURN.
Jan 18, 2008 | Sony PCS-1 (PCS1) Video Conference
Televison & Video Logo
745 people viewed this question
Top Televison & Video Experts
