Question about Belkin Surf N300 Wireless N Router
Can I remove the installed program on the CD from my computer, i.e.the Belkin Router Management ?
    Master:
  • 346 Answers
Alan - Hi, you absolutely can.
You would remove the software like any other in windows. Go to the Start Menu -Then Control Panel and then in XP (Add or Remove Programs) or Vista/Windows 7 (Programs and Features) and remove the software as you would any other.
There will be a list of software. You will move to the Belkin Software and click it to begin the removal. The system will notify you when it's done.
Thanks for using Fix Ya
Mikeywaf
Posted on Mar 17, 2011
Testimonial: "Thank you. It is quick and fast."
Tip
To get rid of multiple issues with belkin routers
To resolve the issue with Belkin routers:The routers that are released recently by Belkin Inc., are Basic / Connect N150, Surf / Surf N300, Share / Share N300, Share Max / Share N Max300, Play / Play N600, Play Max / Play N600 HD
  • These routers comes with a software CD.
  • Belkin router monitor is the software that gets installed in the computer when you run the setup CD in your computer.
  • This software is really an unwanted one that takes around 30 minutes to get installed in your computer.
  • In addition to that, this software displays unwanted popup messages.
  • 90% users are not aware that they can use the routers without installing any software in their computers.
Inorder to make your router properly, these steps has to be followed...
  • The belkin router monitor software has to be uninstalled from your computer.
  • Firmware of the router has to be updated to the latest version available from the belkin support site.
  • Self healing feature of the router has to be disabled.
  • Wifi protected setup (WPS) has to be disabled.
To uninstall the belkin software:
  • For Xp computers, Goto control panel > Add or remove programs > select belkin setup and router monitor and remove it.
  • For vista & win7, Goto control panel > Uninstall a program > select belkin setup and router monitor and remove it.
To update the firmware for your router:Goto http://www.belkin.com/support/
  • Select your router and download the firmware for your router. The file with a .bin extension will be downloaded to your computer.
  • Connect the Computer to the Router in one of the 4 ports named wired (usually grey in color) using an Ethernet cable.
  • Open internet explorer / Firefox or any of your default web browser.
  • In the address bar type the default gateway address of Belkin router http://192.168.2.1
  • Belkin router setup utility will be displayed.
  • Login to the page. (password: leave it blank and click submit)
You will have the status screen.
In the status screen, you will have the very first box in the centre of the screen says "version info", under that you will have firmware version.
Just note down the firmware version there. If the firmware version in router is lesser than the one downloaded from support site, then the firmware has to be updated.
On the far left side below the Utilities you will have "firmware update", you need to click that.
Now on the right hand side you will have "browse".
Click on browse and locate the downloaded .bin file from your computer and click update.
Click ok for all the warnings.
You may see a count down now.
Once its done you will be brought back to the status screen.
Login to the router again with a blank password and click on restore factory defaults below the utilities and click ok for all the warnings.
Now the firmware of your router must have updated with the latest version.
To disable Selfheal:
On the far left side below the Utilities you will have "self heal", you need to click that.disable the self heal and apply changes.
To disable WPS:On the far left side below the Wireless you will have "wifi protected setup", you need to click that.wifi protected setup will be enabled by default, disable it and apply changes.
Click here to learn more about wps...
on Dec 20, 2010 | Belkin Basic Wireless Router
I have a Belkin wireless router- I haven't used it in a while- I have a new laptop and it keeps asking for a security code. I've tried all the numbers on the router and even tried with the 00in...
if you had a cd that you installed it should be in the program.
Look for a Belkin program on your computer, the password should be there, you can change it after you've found it.
Sep 23, 2011 | Belkin N150 Enhanced Wireless Router...
On my windows vista, after i installed the cd; i am not able to setup because a window pops up saying that the "setup application/belkin router has stopped working"
To avoid the pop up Kindly right click on the Belkin router monitor Icon in the system tray & click exit. To avoid it happening all together, Go to control pannel & click on add / remove programs & unistall the router monitor software. The router would still work in the absence of the router monitor software.
Thanks..
Dec 27, 2010 | Belkin Basic Wireless Router
Need to Download Belkin Setup Assistant
I would suggest the following:
in another computer attempt tocreate an image file of your driver cd as you mentioned you still haveit (I strongly suggest you don't lose it), then with a usb thumb drivemove that image into the computer where you want to run the wizard (the one that does not have the cd drive working). now for you to create an image iso file on the othercomputer (virtual image of your cd) you need nero or magiciso oranother program to create iso files from a cd, now to read that imageon your cd-trayless computer you can use a program called magic disc.
there are other programs you can use to make iso image files that are free
free alternatives to nero
magic disc
- this is free and it will create a virtual cd drive on your computerwithout cd drive, you just need to mount the iso file you created withthe other programs and it will work like a cd drive so you caninstallation cd without ever inserting the actual cd.
good luck!
Dec 27, 2009 | Belkin N Wireless Modem-Router F5D8633au4A
Can I install my belkin router without setup cd?
you may install the belkin router by following the instructions given below.
1. Connect your modem to the internet port of the router.
2. Connect your router to the computer.
3. now reboot the modem and computer.
4. open the router setup page, and click on detect the internet connection.
5. now follow the instructions to install the belkin router. for more information you may follow the instructions given below.
How To Setup Belkin Router Install Belkin Wireless Router Fixotip
Sep 21, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
SETTING UP EASY INSTALL WIZARD - Belkin F5D7230-4
just type 192.168.2.1 into your browser and it will get you into the settings, just as a cd would but you still have to manually enter your settings with either way of setup.
Sep 06, 2008 | Belkin (F5D7230-4) Router (587009)
How to uninstall my belkin 54g wireless router
goto either "add or remove programs" in the control panel.
Or in your start menu > all programs > belkin > remove belkin router
all installed programs weather it be belkin, or any other program can be removed by one of these methods, some programs can be removed by either way.
Please reply if you need more help before marking not helpful, thanks
May 06, 2008 | Computers & Internet
Belkin Installation CD wont install any software for my wireless router
click on the start button, all programs then go to accessories and then the program compatability wizard see if it will run from there if not try start, run then click browse then on the right hand side my computer, then click on the cd drive then the setup one of these should work
Dec 10, 2007 | Belkin F5D7230-4 Kit (F5D7230V4SNPDQ)
Belkin Surf N300 Wireless N Router Logo
96 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
