Question about Avanti Coffee Makers & Espresso Machines
I have an avanti Siena espresso machine that i have had for 2 years without any issues. Now, when you switch the button to on, the light flashes and then turns off. It also pops the gfi. We have tried other outlets, and it does the same thing. Any ideas?
ausis
  • 6 Answers
SOURCE: Saeco Vienna De Luxe Espresso Machine not turning on
Sounds like it could be a simple fuse in the machine or just needs a reset code
Posted on Aug 30, 2007
  • 8 Answers
SOURCE: replacement parts for Braun 3062 espresso machine
Google Braun 3062. They are offering all kinds of parts
Posted on Dec 30, 2007
oldnovii
  • 667 Answers
SOURCE: DeLonghi Caffe Siena Instruction Manuel
Hi Karen- I believe I have found your manual. Is your machine a Bar 8 Espresso Machine? If so, let me know. I tried to give you a direct link to it but the way they have their pages setup won't allow it. I can tell you how to get there but it involves abut six steps. I don't want to send you on a wild goose chase. This was posted under Bar 8 and I found a manual for that model but it didn't mention Caffe Siena. Tell me if it's a Bar 8 and I'll get right back to you with steps. Thanks.
Jeff
Posted on May 05, 2008
peyton32034
  • 410 Answers
SOURCE: Fridge is popping my GFI switch
refrigerators are not supposed to be plugged into gfi outlets as they can operate normally and still trip the gfi protector. try plugging the unit into an unprotected outlet and it should work fine. incidentally you'll probably have to replace the gfi outlet as it has probably weakend from being used on the refrig.
Posted on Jul 04, 2008
I have a cafe firenze delohghi bar 8 coffe maker cpfno 0132007018 and have no manual can you help please
Posted on Jul 28, 2008
Schaerer coffee art plus dispenses different amounts
Is the levels issue with milk drinks or with black coffee/espresso? And how old is the machine please provide first 4 digits of the serial number.
First of all, check that the machine definitely has a good water supply to eliminate a blocked filter.
If no fault with supply then the flow meter is faulty. This can occur without displaying a fault on screen, what happens is, if you make around several cups of reg black coffee they may all be different volumes.
If you provide more details I can further assist you in diagnosing.
Apr 08, 2014 | Schaerer Siena Espresso Machine
How do you prime the siena?
Schaerer Siena machines can become airlocked from time to time leaving the pump running yet sounding rough. Easiest way of remedying this is by running the hot water (either by pressing the jug button or turning the hot water knob on the side depending on which model you've got) option through the silver wand. Once you get a strong water flow through this then the machine pump has been primed and you can then begin making coffee as normal. You'll notice the sound the pump makes will change as the water comes through.
Dec 08, 2012 | Schaerer Siena Espresso Machine
Schaerer Siena 2 is showing 'water tank empty' even though it's full - can anyone help out?
There is a float switch in the water tank which is most likely sticking in the downward position. Take out the tank, at the back left you'll see a red piece of plastic. This is the float switch, jiggle it up and down and couple of times and ensure it moves freely, then fill the tank with water and check that the switch rises up with the water level. If this doent solve it, let us know.
Oct 04, 2012 | Schaerer Siena Espresso Machine
Siena 2 not working - display is blank and all leds flashing (not the indicators symbols)
Hi, sounds like 1 problem has created more problems. If display is blank then that is the board. If the lights are flashing then that could be lack of water, or because of the blank display. Need to take it to a repairer. Dazza REPAIRER
Sep 23, 2011 | Schaerer Siena Espresso Machine
Which de-scaling solution is recommended for the siena-1 espresso maker
Hi
There is a liquid called Durgol or you can use the powder which is citric acid. Not recommended using something that has a taste or you would use in the bathrooom/kitchen.
May 24, 2011 | Schaerer Siena Espresso Machine
Schaerer ambiente locked in the flash mode
If you have a Ambiente p/s espresso machine;
it may be stuck in cleaning
simply turn the machine off.. press and hold down the on / off & cleaning button release them at the same time look for the word " Clear Flag " if you see that word you should be out of the cleaning mode ... Note coffee boiler may not be up to temp.. or water flow is blocked..
Feb 21, 2011 | Schaerer Siena Espresso Machine
How do I clean and descale my Schaerer siena 1 espresso maker. We have lost the manual.
Remove the coffee grounds container & leave it out.
Press & hold the cleaning button for approx 5 seconds, you will then see the words " Caution Hot"
Then push the cleaning button once (the one with the plus sign on it) This will start the descaling....I have a Siena-2 & I too could not figure out how to descale, I sent an email to schaerer who sent me an pdf with these instructions which are close to what I was doing. They said it sounds lie I had an older model version - They were very helpful.
remo.weber@Schaerer.com
see the guy who helped me - email above.
Jun 05, 2009 | Schaerer Siena Espresso Machine
Instructions to descale Schaerer Siena
With the machine off remove the grounds bin ( leave it out ) the press & hold the cleaning button until the de-scale symbol flashes
May 14, 2009 | Schaerer Siena Espresso Machine
Coffee Makers & Espresso Machines Logo
390 people viewed this question
Top Avanti Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you an Avanti Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
