Question about Whirlpool Washing Machines
Frequently i am getting FE Error Code Or PE In my White Magic F65--May I Have Solution
3 Suggested Answers
  • 6277 Answers
SOURCE: I have a Whirpool -
'dE' first then manual ;-0)
'dE' probably stands for 'drain Error' (rather than sometimes 'door Error'!)
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to rinse or spin or release the door lock if there is any water still left inside.
Following are my complete and generic guidance notes for checking both the drain motor filter and the drain motor ;-0)
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
Manual
You will need to type into your search engine/web browser '(make model number) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount.
You could also try the manufacturer's web site direct ;-0)
If these have assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
Posted on Jul 31, 2011
Testimonial: "Hi John C... At the offset ..thankyou evry much for your prompt resposne. Much appreciated..It was the drain error... Your a gentleman & a scholar"
TheMobilian
  • 8220 Answers
SOURCE: I got PE error code in my whirlpool white magic F65
The PF error code indicates a power failure on many different machines. This might occur while machine is working due to an external disturbance like a storm or power outage in the area. If the PF error code is displayed, turn off the power to the washer, unplug it for 10 seconds, and restart the wash cycle.
Posted on Aug 13, 2012
Whirlpool f65 whitemagic top load washingmachine pe error
consult the user manual from the Whirlpool website eric
Jan 05, 2018 | Whirlpool Washing Machines
Whirlpool F65 PE Error?
F65 STEAMER TIME OUT REACHED Error
happens if there is no communication between Central Control Unit (CCU) and steamer electronic board. The failure will reset after running the Diagnostic Test Program. 1. Check connections between the Steamer Electronic board and CCU.
2. Check mains supply is in range (90V-132V).
Jan 03, 2015 | Whirlpool Washing Machines
My whilpool white magic pro 700h is not storing water in the tank.it is draining.
Go to whirlpool website, in the service and support section you can get a copy of your manual. All the error codes should be listed.
Apr 03, 2013 | Pool & Spa
P.c.b. not working
Washing machine is showing error "PE" it's not a big problem you are washing machine is just fine.PE means error signal due to low voltage .Machine resumes functioning after the voltage comes back to normal.
Oct 21, 2012 | Whirlpool Washing Machines
Aug 13, 2012 | Washing Machines
I get a PE error code
I get PE error code in whirlpool white magic F65
Aug 12, 2012 | Washing Machines
I have an LG Senseclean and th FE code was showing and water level was higher than normal. Now PE code is showing and washer wont function at all?
LG's 'FE' stands for 'overFlow Error' (or Flood Error is how I remember it!) and 'PE' for '(water) Pressure Error'.
So- looks like you have a leak which has been detected by the sensor in the flood detection tray underneath which is there for exactly that purpose, sorry.
Service call ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
John C
Jul 10, 2011 | Washing Machines
Getting a E1 code one the front panel and will not finish the cycle
There is not a reference for an E1 error code.
The listed LG error codes are:
IE, UE, OE, FE, PE, dE, tE, LE, EE, and PF.
May 18, 2010 | LG WM2016C
Whirlpool white magic h65 model.what is LE. AFTER
LE error will get displayed when the Lid is opened. Close the Lid and this will get resolved. Similarly you will get FE when the water is not flowing properly into the Machine its a Fill Error.
Nov 05, 2009 | Whirlpool Washing Machines
Washing Machines Logo
234 people viewed this question
Dan Webster
Dan Webster
Sal De
