Question about Refrigerators
I would like to find out how the temperature controls and all the settings work on this used refrigerator my boss just bought for the restaurant.i've never seen a control box like this one.thank you very much in advance.
  • 32 Answers
How many controls are there and what do they look like ?
Posted on Mar 17, 2011
Electrolux refrigerator not working properly i have change new one picture i ve attach here thou sometime it run but after few minute it stop please suggest what should i check.
Hi, have you tried adjusting the thermostat control, if the fridge is not cooling enough you can set it to a lower temperature. There will be a rotating knob somewhere on your fridge that can turn the temperature down. Sorry if I appear a little confused, the fridge is supposed to stop after a few minutes of cooling, it should not be using the compressor all the time.
Maybe lowering the temp will soet the issue.
Jun 15, 2015 | Electrolux Refrigerators
I have a 2yr. old Maytag Frig.,freezer on top.I cannot get a stable freezing temp. I can set, with the setting control, readings of 4 or 7 with no effect on the actual temp. I bought a freezer thermometer...
If the refrigerator is not cold enough then please check the following and also click on the blue coloured links for more info.
How To Check the Temperature1x1.gif In most refrigerator freezers, the refrigerator gets its cold from the freezer. The evaporator fan circulates air over the coils in the freezer and cold air circulates into the refrigerator through vents. If the vents are blocked or closed, then the fridge will not get cold enough but the freezer will. If neither is cold enough, then the number of possibilities increases.
Lowering the freezer temperature will increase the cooling cycle activity. Setting the refrigerator temperature may have little affect on the cooling cycles because it simply changes the vent opening size. Decreasing the fridge temperature opens the vents more and increases air circulation from the freezer.
The temperature can be adjusted using the controls found inside the refrigerator or freezer. The ideal freezer temperature is about 0 to 5 degrees (F) and about 38 degrees (F) for the fridge.
Measure the temperature by placing a cup of water with a cooking thermometer into the refrigerator for about 2 hours or more. To test the freezer, substitute alcohol or cooking oil.
Goodluck,
Please don't forget to rate the solution.
Mar 27, 2008 | Refrigerators
GE GSS25QSTSS Side-By-Side temperature controls isn't working
I bought a GE profile Side by Side refrigerator PSS26NGPBB for $1,800. The temperature settings won't hold. We were gone for the day, came home and found our food all thawed in freezer. Inside temp both sides is now 70 degrees. Whats wrong???
Sep 17, 2010 | GE GSS25QSTSS Stainless Steel
We have a bought a secound hand fridge but had to remove the motor when transpoting it. the fridge was in full working order when bought. now we tryed to put it all back together and cant remember where...
The temperature controls in a refrigerator are typically mechanical. The mechanism could have become disconnected during transport. You can remove the housing inside the refrigerator and reconnect the linkages to restore temperature control.
Nov 01, 2009 | Refrigerators
Cooler wont cool below 48 degrees.
Keep a thermometer handy. (adjust temperature control knob accordingly)
Periodically monitor temperatures inside your cooler. (adjust as necessary)
Keep the refrigerator door closed as much as possible to avoid temperature fluctuations
The temperature of the refrigerator compartment is
controlled by adjusting/setting the thermostat control
knob, located on the ceiling of the refrigerator
cabinet.
To start the refrigerator, and achieve maximum
cooling quickly;
• Turn the temperature control knob (using a coin
or screwdriver) clockwise to the furthest
(maximum) setting on the darker blue section of
the graduated control dial.
• Allow the refrigerator to run at this setting for 3~4
hours.
• When maximum cooling is achieved, turn back
the temperature control knob setting to the 2:00
o'clock position on the graduated blue control
dial.
• Correct cooling temperature is a key factor to
consider in storing and dispensing draught beer.
• Optimum temperature for serving draught beer is
between 34ºF ~ 38ºF.(1ºC ~ 3ºC)
• To maintain temperatures ranging between
34ºF ~ 38ºF.(1ºC ~ 3ºC) We recommend the
thermostat knob be positioned at the "2:00
o'clock" setting on the graduated blue control dial.
• To turn off the refrigerator, (no cooling) rotate the
control knob to the "0" position.
Jan 31, 2008 | Danby DKC646BLS Full Size / Pony Beer Keg...
Food is freezing
usually there is an adjustment at the back for the difference between the fridge and freezer compartment. Often is just a vane that blocks freezer air, too much air would freeze the food. Normally you set the fridge thermostat for a normal food temp, then adjust the air to keep the food warmer than the freezer.
Jan 28, 2008 | Arctic Air R22CW Refrigerator
Fridigaire FRU17G4JW - all refrigerator unit not cold
Things to check
Check .
for Frost build up and if Fan is blowing,
Check condenser...
To make sure clean, and the fan is blowing by compressor & IF it is running
Check Recirclating Vents in refrigerator... to make sure theres no blockage,
CONTROLS ...should be in the middle setting,
Oct 25, 2007 | Frigidaire FRU17G4JW Refrigerator
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
