Question about Whirlpool GEW9868K Electric Dryer
Dryer stop powering on after unplugging the unit and replugging. I got a shock when I did so. Any clue?
  • 32 Answers
Check the back of the dryer where the power cord goes into it and make sure there is not a cut in the cord causing a short, there should be a protective clamp or ring to prevent this from happening but sometime people do not take the time to put them in right. Be careful with it because that is running on 220 and a good shock from that could literelly kill you. So carefully unplug it or better yet turn the breaker off first at the electric panel for it.
Posted on Mar 17, 2011
Dryer stop working then start shocking you when touch
The first thing you need to do is turn the breaker off to the dryer , that way you don't risk shock trying to unplug it. The next step is to locate where the wire is arcing over, I would start at where the plug comes into the dryer and move on from there. Thats a very dangerous situation, be careful and good luck
May 27, 2012 | Whirlpool Dryers
Frigidair galaxy electric dryer comes on for a few seconds and shuts right back off error code reads PF
PF means Power Failure,try unplugging the unit for 20 minutes to possibly clear the computer control inside the unit,then try starting it again,if this doesnt help try unplugging and replugging in all connections in case theres a bad connection,lastly if this doesnt solve it,replace the control board
Feb 12, 2012 | Frigidaire Dryers
Wii stopped working. the light is not on. There is a disk inside that won't eject. We tried unplugging and replugging everything. Could it just be the 3V battery ?
did the power go out while your Wii was plugged up and on or in sleep mode? if it was, you probably need to unplug you wii from everything and let it sit for a few minutes. your Wii probably just got 'shocked' by the sudden lack of a power source. If the power didnt go out, then I dont know how to help you~ Sorry. I hope I helped!! ^-^
Oct 02, 2010 | Nintendo Wii Console
Lg dle3777w dryer filter light remains on and dryer is not working even after cleaning the filter.
I'm sure you solved the problem but as i had the same problem on my electric LG front loader and saw no response i figured I would leave one for anybody else in the future. My girlfriend told me the dryer would not start and as i looke i saw the panel would not power up, I unplugged the power cord for 5 minutes and the LG reset and the panel was on and reading clean filter after checking the filter which appeared clean I tried to restart the dryer at which time it powered off. I again unplugged the dryer and replugged it and again the display read clean filter. I then gtabbed a phillips #2 and unscrewed the filter lint sceen which had a total of 4 scews in the interior of the dryer holding the filter housing unit. Youll see a piece of the housing unit remains screwed into the washer hooked up to two electrical plugs. Seperate both plugs from the unit and unscrew it and remove the unit youll notice two silver strips on the unit and I'm guessing will be covered with a small amount of lint. Clean the unit with a brush and damp cloth inside and out reattach the unit screw first and housing unit and turn on. If the dryer again turns off unplug and youll see the clean filter light. Simply push the custom program light or anything similar and the panel should start working again. I hope this helps someone.
Aug 08, 2009 | LG DLE3777 Electric Dryer
Dell E510 has a solid amber light, no light codes or sound codes. Unit powers up but will not boot. I unplugged and replugged all the wires to no avail. Does anyone have a clue as to why?
Contact dell technical support for a replacement motherboard. If I remember correctly this model had a recall due to faulty capicitors and should be replaced even if you are not under the service agreement still.
Jul 14, 2009 | Dell Dimension E510 Dual Core 2.8 Ghz...
Control panel dead
1. Unplug dryer.
2. Remove 2 screws from rear top of dryer.
3. Lift panel assembly up, taking care to not pull wires.
4. Check plugs on circuit board for panel display. Press each one firmly, but carefully.
5. Put back together, plug in, turn on.
Jun 14, 2009 | GE Profile Harmony DPGT750EC Electric...
Sony WEGA KD-34-XBR960
Push display - 5 - vol + or - then power. Clear CH setup if there and if the right numbers are not zero the push 8 then enter, that will clear the numbers, like reset. IF unit no workie the start up that way and any zero with numbers are what the units problems are.
BC
Oct 13, 2008 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Kenmore Dryer 80 series will not turn on.
HI thanks for your question. theres a belt break switch on the dryer so that if the belt breaks it wont allow the dryer to start. check that. thanks the appliance doc. please rate my answer .thanks
Oct 05, 2008 | Kenmore 62602 Electric Dryer
Hp 3325 printer does'nt power at all please help!
I have in two cases been notising the power supply been dying, maybe due to some slight power shock, or a weak component inside the unit ...
Jan 31, 2007 | HP DeskJet 3325 InkJet Printer
Whirlpool GEW9868K Electric Dryer Logo
60 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
