Question about Toshiba Ct-90121 Remote Control
How do you set up subtitles? - Toshiba Ct-90121 Remote Control
  • Michael Wafkowski
    Michael Wafkowski Mar 17, 2011
    Greetings - Your TV (whichever one) doesn't have the ability to turn on/off subtitles. They are either in the source video or not. If you're talking about Closed Captions that's something else and are controlled via the TV and/or the remote.
    If your talking about subtitles on a DVD that's also different story and are controllable via the remote.
    What device are you trying to view subtitles from?
    Regards,
    Mikeywaf
Subtitles stuck on!! Using a one for all remote with no button for subtitles. Using a celcus tv!! Pre christmas ive been stuck with this
You are confusing subtitles with closed captioning (CC). Subtitles are part of the medium, e.g., English subtitles in a French movie. Closed captioning usually is selected during initial set up of your TV. You may have to return to the initial set up procedure to cancel CC.
Apr 23, 2016 | Celcus Televison & Video
How do I turn the subtitles off for the yamaha HTR-5730 AV receiver? When I hook the cable up directly to the TV, there are no subtitles, but when the video output goes through the receiver, subtitles
The receiver manual may list it under "CC" (closed captions) instead of subtitles. Also, don't just check your AV receiver; try checking the setup menu on your TV, and look at the TV remote. See if there's a CC setting that may be turned on, either through the TV setup (probably under the "Display" or "Video" tab) or because you've accidentally pushed the CC (or Subtitles) button on the TV remote.
Nov 26, 2014 | Yamaha HTR-5730 Receiver
Subtitles always on
We believe you have the Closed Caption decoder in your TV enabled. Please turn off the CC feature in the TV.
Jul 17, 2014 | Panasonic DVD-S27 DVD Player
Subtitle choice grayed out on vizio e390i-a1
May 13, 2017 | Vizio E390i-A1
Subtitles always on
Hi - welcome to FixYa,
There are 2 methods for changing the subtitle settings on your DVD player.
Method 1.
To turn off the subtitles on your DVD player during playback:
1. Press the "SUBTITLE" button on your remote control
The subtitle button is just below the "0" (zero) numerical key on the remote control. It is marked "SUBTITLE" above the button and the button has "ABC" written inside a white rectangle on it.
2. Use the left "<" and right ">" arrow keys to change the subtitle setting
Each time you press an arrow key the subtitle language will change and eventually the language will read "OFF". The subtitles are now switched off during playback.
Method 2.
To turn disc subtitles off from the main menu:
1. Press the "MENU/LIST" button on your remote control (directly below "STOP")
The main menu will now appear
2. Press the down arrow key on your remote once to highlight "A" in the left hand column of the main menu
3. Press the right arrow key on your remote once to move to the right-hand column of the menu
4. Press the down arrow twice to highlight "Disc Subtitle"
5. Use the left and right arrow keys to change the subtitle options until your required choice is displayed
6. Once set, press the "MENU/LIST" button again to exit the menu.
This should solve your problem, but if you need any further assistance, please post back.
Regards,
BElectric
Nov 21, 2010 | LG RH-4820 DVD Recorder
Hi, how to enable subtitles for DivX movies from USB on LG 42LE5500? I connect USB, TV recognizes folder where DivX .avi file is but within same folder it does not "see" .srt subtitle. Also, in settings...
It seems that subtitle file must have exactly same name as movie file. For example: Movie file: Mission impossible.avi Subtitle file: Mission impossible.srt or Mission impossible.sub or Movie file: Mission_impossible.avi Subtitle file: Mission_impossible.srt
Aug 14, 2010 | LG 42LE5500 42 in. TV
How do i change the language on my pioneer avic-d3 player
here is the link to your manual:
http://www.pioneer.co.uk/uk/support/manuals/AVIC-D3/index.html
Setting the language
You can set a desired subtitle, audio and menu
language. If the selected language is recorded on
the Disc, subtitles, audio and menu are displayed
in that language.
1 Touch “Language” and then touch
“Subtitle Language”, “Audio Language”
or “Menu Language”.
Each language menu is displayed and the currently
set language is selected.
2 Touch the desired language.
When you select “Others”, a language code
input display is shown. Input the four digit
code of the desired language then touch
Enter”.
➲ “Language Code Chart for DVD” ➞
Page 114
from the manual:
English (en), 0514
❒ If the selected language is not recorded on
the disc, the default language specified on
the disc is output and displayed.
❒ You can also switch the subtitle and audio
language by touching “S.Title” or “Audio
during playback.
➲ “Changing the subtitle language during
playback (Multi-subtitle)” ➞ Page 75
➲ Changing audio language during playback
(Multi-audio) ➞ Page 75
❒ Even if you use “S.Title” or “Audio” to
switch the subtitle or audio language, this
does not affect the settings here.
Setting assist subtitles on or off
Assist subtitles offer explanations for the aurally
impaired. However, they are only displayed if they
are recorded on the DVD.
You can turn assist subtitles on or off as desired.
1 Touch “Assist Subtitle”.
Touching “Assist Subtitle” switches
between “On” and “Off”.
Cheers!
Jan 11, 2010 | Pioneer AVIC-D3 Car DVD Player
Sony DVP-NS55P subtitles
go to dvd set up menu and reset the settings. try again to see subtitles.
Aug 12, 2008 | Sony DVP-NS55P DVD Player
Can't get English subtitles on
Check the language settings on the DVD player. I'm not familiar with Panasonic machines, but most players have default language options for subtitles, soundtrack & menus.
The firmware update may have reset this option.
May 12, 2008 | Televison & Video
Toshiba Ct-90121 Remote Control Logo
47 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
