Question about JVC KD-S570 CD Player
I have to hook up the battery 12 volt to the accessory on my KD-S13 just to run it but I can't shut it off is this wire harness a bad one
    Problem Solver:
  • 10 Answers
I would say try running you 12 volt constant to the cig lighter fuse or somethings that always hot then run your switched to to the radio fuse and see if that helps you might need to get a new harness off of ebay if thay have one or just put a toggle switch on the radio to turn it off or on,
Posted on Mar 17, 2011
Ezip 500 won't run : new batteries fully charged but it still shows low battery light...what else could be wrong
i'm having the same problem. checked fuses and both are good. going through the wiring harness to look for shorts. have a bad feeling the micro controller died, that is the little plastic box with metal fins on it under the seat post behind the batteries ******* to the frame. i can bypass the micro-controller and connect one 12 volt battery directly to motor and runs full speed. somehow it is wired with 2 - 12 volt batteries in series to give 24 volts and them the processor cuts back down to 12 volts to run the motor. not sure why this is engineered this way? still working the problem. what sucks so far is that the micro controller is encased in resin so it is virtually non repairable.
* Update added.
Found these wiring harness for sale online scooter stores and on ebay. I replaced mine with some intermediate level adapting the harness to my model scooter and this includes some soldering and wire splicing changing power connector heads off old harnedd to new harness to fit bike. Works great.
Jan 02, 2013 | UPG New Replacement Batteries 4 EZIP E Zip...
Where do you connect the memory wire on a jvc kd g110 car stero.....what color is the memory wire ?? what does hook red wire to acc fuse mean??? what wire does the red wire on the radio connect to on...
The yellow wire is most likely the memory wire as it needs to be connected to a constant 12 volt source.
"Hook red wire to to acc fuse" means you need to hook into the fuse block under an Accessory Fuse. (ie: something that can't be turned on unless the car is running or the key is in the "Accessory" position)
The red wire is explained above. It does not connect to the harness.
Just remember that the yellow wire needs to be hooked to a constant 12 volts and the red needs to be hooked to a circuit that is only active when the car is running or switched to the "ACC" position.
Mar 02, 2011 | JVC KD-G110 CD Player
The memory on my new jvc car stereo model kd-s17 does noty work whenever i turn the key off then on i have to reset the clock and presets all of my wires are connected
need to check the yellow constant power wire on wire harness to see
1. connected to battery with constant 12 volts
2. if wire has power 12 volts
if no power check fuses to see if blown
with out this wire working right you will never have pre set station on radio or clock
with correct time
Dec 22, 2010 | JVC KD-G801 CD Player
JVC KW-AVX710 not save. after switch off the car .when start it again all settings become to default
If your unit is not maintaining it's memory, it may be associated with the lack of a constant 12 volt power source. Test the units yellow wire, it should rest at 12 volts with the key in all positions; off, acc, on/run, start. This yellow wire should be connected to the vehicle's battery wire. Also, test the red wire. This wire should be connected to a switched 12 volt power source. It should read 12 volts with the key in accessory and on/run only. If you used a vehicle specific wiring harness to complete the installation, the wires may be switched in the harness. It's not a common issue but, I have seen it happen.
Dec 04, 2010 | JVC KW-AVX710 Car Monitor
3 way dometic RV fridge RM2612 won't work on propane or 12 V
Check any fuses/circuit breakers in harness from battery. That battery should supply 12 volts dc to fridge lugs/terminals at bottom of fridge on outside behind vent.
If battery is good and hooked up properly but no 12 volts to fridge, then you will have to trace back to battery for broken /bad wire. If you want to test quickly, just run 2 jumper wires from battery to those 2 lugs marked + and - Battery + to + (pos)at fridge, and - battery to -Neg at fridge. That should allow you to run it on propane or 12 volt. Remember, running it on 12 volts will kill that battery pretty quick, unless it's being charged. When you are plugged in, the converter supplies the 12 volts to your fridge, as well as should be charging your battery.
Jun 18, 2010 | Dometic RM2652 Refrigerator
I have removed my JVC KD-G801 from my car but realised that there is still a CD inside the unit. How do I remove it?
Hook your power wires and ground up to a cordless drill battery , 12 volt, or 14 volt. Or use jumper wires from car battery. Hit eject. You don't need all the speakers etc hooked up.
Feb 13, 2010 | JVC KD-G801 CD Player
I WOULD LIKE TO KNOW HOW TO HOOK UP THE RED AND YELLOW WIRES FROM A JVC KD-R400 CAR STEREO TO THE WIRING OF A 1999 PONTIAC MONTANA
The red should be ACC. Meaning it only supply 12 volts when the ignition is in the acc position or in the on position or when the car is running. It do not supply 12 volt if the ignition is off. The yellow wire is Battery(sometimes called B+). That means it has 12 volts at all times even the ignition is off. This wire is responsible for memory. Get a meter or a test light. Turn the ignition off and find which wires has 12 volts, you caonnect that to the yellow wire. Now turn the ignition key to ACC, and find the wire that has 12 volts, now turn the key off , the 12 volts should go away, You connect that to the red wire.
Nov 25, 2009 | Vehicle Parts & Accessories
I need a schematic for the x-treme scooter
Check the batteries, they need at least 12+volts to run scooter. Blinker may be burned out or the wire came loose. If batteries are charged Two things That could be wrong are: Twist throttle is NO Good, Or the controller is BAD. You need a voltage tester, (Disconnect the Wiring Harnesses) and check voltages coming out of the controller(the silver BOX with lots of wires) and see if it is sending voltage to the twist throttle. Controller wires to the Twist throttle should read 4-5 volts.
(Make Sure You Unplugged That Wiring Harness) There is 4-6 wires in that Wiring Harness then find + and - test them for voltage from that Controller box wiring harness. If You get a positive reading out of that Controller wiring harness then the Twist Throttle thing is bad. If you get NO READING out of that Controller Wiring Harness Then if is BAD. Normally it will be the dead batteries or the Twist Throttle that go bad. Batteries are expensive, Twist Throttle Cheap. Good LUCK
Apr 03, 2009 | Electric X Treme X 360 Scooter
Installing a new car radio
if you have a wiring harness al the wires are color coded to match the after market radios colors. the yellow constant wire goes to 12 volt or battery wire. the accessory wire would be the red wire that is the switched 12 volts. the remote is for the factory amp or an aftermarket amp which turns on and off it would be the blue with white wire.
May 28, 2008 | JVC KD-SX990 CD Player
No wiring harness for cd player
http://www.dvbcaraudio.co.uk/product_info.php?products_id=3338
Apr 19, 2008 | JVC KD-S570 CD Player
JVC KD-S570 CD Player Logo
69 people viewed this question
Top JVC Car Audio & Video Experts
Radames Pagan
Radames Pagan
xxxxxx xxx
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
