Question about VeriFone Office Equipment & Supplies
I need a down load for a verifone vx610 an operational manual
4 Suggested Answers
  • 173 Answers
SOURCE: I need an download for
Hey there,
Here is a link to the manual you need: http://www.verifone.com/PDF/guides/23216_Omni_5xxx_vx5xx_vx6xx_Installation_Guide.pdf
Hope this helps! If it did, feel free to rate me. Thanks for using FixYa.
Posted on Mar 17, 2011
  • 45 Answers
SOURCE: I need a download for
Hi, welcome to FixYa.
I hope this is the document you needed:
Tricky1991
  • 118 Answers
SOURCE: I need a download for an operations manual for a
The link below should be what you need.
http://office.manualsonline.com/manuals/mfg/verifone/vx_610.html
How do I turn off a verifone vx610
  1. Disconnet the power cable.
  2. Hold the red cancel key for ten seconds.
  3. Remove the battery
May 14, 2014 | VeriFone VX510
What does TAMPER
"TAMPER" displays on Vx510, Vx610, or Vx670 terminal Problem/Task "TAMPER" shows on Vx510, Vx610, or Vx670 terminal Environment VeriFone Connect Any Verifone manufactured device that has the capability to contain it's own internal encryption (including Vx510, Vx610, or Vx670 terminal) Cause The message: "Tamper" will appear on the Vx510, Vx610, or Vx670 terminal if it is physically opened, damaged, or if it is jarred enough to flip and enable the internal tamper 'switch'. The reason for this is to ensure any sensitive data that passes through the terminal during a credit card transaction is not intercepted or compromised. Customer Solution/Action 1.
Contact repair facility for repair/replacement of the affected device
If you still needs help call us at (775)358-2922 ask for Randy http://freshpoint.org
Sep 29, 2012 | VeriFone Omni 3700
Hi. i own a verifone vx610 wireless credit card machine and I'm getting the TAMPER message on the screen. is there anyway the fix this problem. thank you
if you still need help with your Vx 610 we can help you call (775) 358-2922 ask for Randy and YES we can fix the TAMPER error. Thanks
Jul 15, 2011 | VeriFone VX 610 Credit Card Terminal...
I have a verifone vx610. I need to change the sim card. I have looked at the online pdf and the instructions and pictures don't match up to what I have. When I removed the sled from the bottom of the...
You may or may not be looking at a GPRS modem (which require a SIM to operate) for your Verifone Vx610 . It could be a CDMA modem instead. To tell the difference (as long as the labels haven't been removed), simply look at the outside of the modem (you don't even need to remove that Phillips head screw and remove the modem from the terminal). You're looking for up to three labels: One is S/N:XXX-XXX-XXX and a barcode - does it read Sierra EVDO? A second one is CDMA-1.67-VZW-P1 act deact act The third one is ESN HEX:1234ABCD (8 alphanumeric characters) and ESN DEC:12345678910 If any one of these is true, it's CDMA and does not use a SIM. If none of these is true
Apr 01, 2011 | VeriFone VX510
I need a download for an operations manual for a verifone vx610
Mar 17, 2011 | VeriFone VX 610 Credit Card Terminal...
I need a download for an operations manual for a Verifone vx610
Mar 17, 2011 | Computers & Internet
I need an download for an operation manual for a Verifone vx610
Hey there,
Verifone vx610
#1 You need the Vmac and Comserv applications that were deleted when you cleared memory in order to perform an IP download. Without them you can only perform a dial only download.
#2 The programming for your VX510 will not load in your VX610 because they doth identify to the server as different models. If you did get the vx610 to connect and request your vx510 file you would only recieve an error "Application not configured" or "file not found"
Pro Tip: You can still clone VX terminals reguardless of model with the correct cable. Enter system mode and press 0 the # or 0 then * to send and recieve. This would put the application from the vx510 into the vx610 but your vx610 may not work through a com method other than dial depending on your processor.
Feb 10, 2010 | Computers & Internet
Verifone vx610 decline code 248
This is tricky to answer... different processing service use different codes. If the software you are running is built on a St. Pete's platform, this code means that the transaction you were processing was a 'reversal' (void) and the amount entered didn't match the original.
If you were running a sale and received this code and the display or receipt actually printed "declined" - it is a valid response indicating the customer card was declined and the code tells the service rep at your processing center why it was turned down (over limit, high risk, frozen account, etc...). If the response did show the word "declined", you can call your customer service department for your processor and they should be able to tell you what the code means in their system. If they don't - change processors as this is a standard service.
Aug 25, 2009 | VeriFone VX510
219 people viewed this question
Top VeriFone Office Equipment & Supplies Experts
George Mclaughlin
Willie Cooper
Willie Cooper
Are you a VeriFone Office Equipment and Supply Expert? Answer questions, earn points and help others
