Question about Whirlpool LGB6300 Gas Dryer
My dryer shut off and will not start. I checked circuit breaker and it is not blown.
  • Whirlpool Master
  • 43,501 Answers
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Mar 20, 2011
Does not heat and the timer does not shut the dryer off
Most dryers have two circuits. It sounds like one of these has a blown fuse. Check the breaker/fuse box and make sure the breaker isn't tripped or the fuse isn't blown.
Jul 24, 2011 | Dryers
The dryer does not start. Is there someway to reset it.
See if the circuit breaker connected to the Dryer line is off or if it is a fuse, if it is blown. There also may be a separte switch on the line near your dryer outlet. Follow the wiring back to your circuit breaker. Do not touch any wiring unless it is shut off at the main.
Unplug the dryer, wait an hour and replug. Turn on the power button. If that doesn't work press and hold the power button.
Aug 17, 2010 | Kenmore 62602 Electric Dryer
My dryer all of a sudden will not come on. Is there a reset button on these dryers?
Your problem could be a result of several possible issues:
* voltage coming to the dryer (110 V for gas & 220 V for electric); Check circuit breaker, voltage at wall outlet, etc.
* thermal fuse (non-resettable) that has blown and shuts off the dryer typically due to overheating (may be caused by clogged exhaust system)
* timer
* motor
* Start button or door switch
You should contact an appliance service company if you have checked the circuit breaker for proper voltage.
Jan 20, 2010 | Roper REX4634KQ Electric Dryer
No heat
If your dryer doesn't heat, check these:
Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it electric heating elements aren't repairable.
On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse which is about an inch long is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it.
Sep 03, 2009 | Kenmore Dryers
Dryer wont start
your dryer may not be recieving adequate voltage to start.
make sure your dryer is plugged in.
also check the circuit breaker panel to make sure all circuit breakers are in the right position.
check fuse box for blown fuse.
try plugging in something else in the same outlet.
also refrain from using an extension cord.
Mar 04, 2009 | Whirlpool GEW9200L Electric Dryer
Dryer no heat
i am sending you all the possibilities for your problem, check either of these causes ----and than let me know if it is solved----
Power from the house
Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse
On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring
A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Dec 24, 2008 | GE DSXH47EGWW Electric Dryer
Dryer wont shut off and gets no heat.
Heating element
Thermal fuse
Wiring
Dec 23, 2008 | GE DBSR453EBWW Electric Dryer
Dryer has no heat and wont shut off automatically
Heating element
Thermal fuse
Wiring
Dec 21, 2008 | Kenmore 64732 Electric Dryer
Roper Dryer heats for 5 minutes then stops heating but still tumbles. I haven't a manual so there isn't a schematic to work with. Appreciate any suggestions;
Heating element
Thermal fuse
Wiring
Sep 14, 2008 | Roper REX3614KW Electric Dryer
Dryer problem
Heating element
Thermal fuse
Wiring
Mar 11, 2008 | Whirlpool GEW9200L Electric Dryer
Whirlpool LGB6300 Gas Dryer Logo
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
