Question about HP DeskJet 695c InkJet Printer
Do i need to have both cartridge full of ink for a 695c, my colour is empty but black is full
  • 24 Answers
Both the black and color cartridges must be installed in order to print, however the color does not have to be full of to print in black-only. Be sure to set the printer to print only in black-and-white from the printer properties (or preferences). You can access this from the Print window from the application you are printing from. Select the printer from the list and then click the Preferences button (The button may also be called Properties, in some applications such as Office). Please note that not all printers allow this, however older models often do. Newer printers may even refuse to print if the cartridges are past the expiry date printed on the box. Be cautious if buying bulk-packs of cartridges if you don't print very often as they can expire before you get a chance to use them.
Posted on Mar 17, 2011
Will the Epson cx3900 print if one of the coloured cartrige is empty
No unfortunately the printer will not print unless all cartridges are present and have an adequate supply of ink inside them. Even if your only printing black and the black cartridge is there and full, it will still need the color cartridge ot be present and partically full of ink in order to print.
Aug 15, 2011 | Epson STYLUS CX3900 All-In-One InkJet...
Not printin g all the time & all blue
Without knowing the Model of Printer and any specifics I will try to cover all the bases I can.
If your printer uses a Tri-Colour cartridge and Black Cartridge then it is most likely that either the Magenta in the Tri-Colour cartridge is either Empty or Blocked or the Black cartridge is Empty.
To test this you can take the Tri-Colour and Black Cartridge out of the printer and press the Printhead against a tissue. The Black should be a solid black line approximately a centimeter long by 3 Millimeters wide. The Colour should have three solid lines, one of each colour Cyan, Magenta and Yellow. If either of these is not clear then the cartridge that does not leave clear footprints will either be empty or blocked.
If your HP printer uses seperate ink tanks for each colour then the Printhead may be blocked or the Ink Tanks are empty.
If it is a Laser Printer then there are several possibilities open. The Toner Cartridges are Empty or the Toner Seals have not been removed. If they are still full and the seals are removed then the Imaging Mirrors may be damaged or the Imaging Drum(s) may be damaged.
I hope that helps.
Jul 11, 2011 | HP Office Equipment & Supplies
Want to print only in black
search through your manual for grayscale options... this is usually code word for black and white...
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
Dec 21, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Colour Ink Jet Cartridges emptying during a black ink print run
If you go to your printer properties, there should be a setting whereby you have to select the option to "PRINT USING BLACK CARTRIDGE ONLY". Make sure this option is selected, otherwise your printer will use ALL colors even if you only print black.
Let me know if you need any further assistance.
Best wishes,
Graemevm
May 07, 2009 | Epson Stylus DX6050 All-In-One InkJet...
Can't Print with black ink because all color ink are empty.
yes you need to install all cartridge before printing any page ...I have also this model...but u need to install all 4 cartdge. before printing any page wheather color or blacknwhite..
Jan 08, 2009 | Office Equipment & Supplies
Does not print black
Most likely you have no black cartridge installed or it is empty causing your printer to use the colour cartridge for black. But if your colour cartridge has 1 colour which is less full than the others it causes black to become greenish or sometimes reddish depending on which colour is less. A new cartridge or a black cartridge will solve the problem.
Aug 08, 2008 | HP DeskJet 825c InkJet Printer
Why is there 2 black ink cartridges in my Canon MP600 printer
On some printers, probably including yours, the black ink will be taken from the reserves in your colour cartridge unless you specifically tell it to do a black and white print on each document, regardless of whether it's printing black exclusively. I wouldn't worry, the black ink in it's own cartridge can also be used for colour photos etc with no detrimental effects.
Mar 29, 2008 | Canon PIXMA MP600 all-In-One InkJet...
Printer not printing
Unfortunately, like most multi cartridge ink jet printers when one ink is empty the printer will cease printing regardless of whether you just want to print in black and white and you have plenty of black ink left. I have heard of people tricking the printer into believing the cartridge is full by placing coloured tape etc in front of the ink sensing device but I am not sure how the Brother senses the ink levels as i have some aftermarket ink cartridges for mine which seem to be completely non-opaque (unlike the originals). The need to have colour cartridges in even if you only ever print with black ink is good news for Brother as the MFC-210c uses a large amount of ink during it's routine cleaning cycles (that you cant stop) and will empty all 3 cartridges in under 6 months without ever printer a single drop of colour ink. Sorry about all the bad news, at least your not alone......
Dec 28, 2006 | Brother MFC 210C All-In-One InkJet Printer
HP DeskJet 695c InkJet Printer Logo
55 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
