Question about Watches
I HAVE A CASIO G SHOCK WATCH AND I MISPLACE THE OWNERS MANUAL AND CANNOT SET THE RIGHT TIME SINCE DST.
    President:
  • 2,501 Answers
You can get instructions from the Casio web site.
Go to the casio web site "casio.com".
Select "support" and the "manuals",
watches;
Accept terms
Select "watch manual archive"
Read the number of the back of your watch and enter it into the search box
Posted on Mar 17, 2011
Daylight savings time change casio atomic watch has not changed is there a way to change it manually
An example for G-shock: I searched for casio g-shock manual and got this: http://world.casio.com/wat/download/en/manual/
You enter model from back of watch and it gives you a searchable PDF manual.
For mine, model 2638 (and likely most G-shocks), you press and hold the upper left (Adjust) button until the City Code flashes. You then press the lower left (Mode) to enter DST mode then press the lower right (Receive) as it cycles through On, Off and Auto.
On moves 1 hour forward, Off moves 1 hour back. After you select, you press the upper left button (Adjust) twice and it's set. I would not pick Auto anymore as my watch is still set to the original DST days which were changed in the US years ago and no longer match, I don't believe the DST days used can be changed by the user and I don't believe Auto receive adjusts for DST.
Mar 13, 2011 | Casio Watches
Setting the DST on my Casio G-Shock... plus 4 minutes fast!
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all CASIO watch manuals.Rate me, please
Mar 18, 2010 | Casio Watches
Change time to dst
Select "support" and the "manuals", watches;
Accept terms
Mar 16, 2010 | Casio G-Shock GW300CA-1V Wrist Watch
Have a casio model 2608 and its one hour too fast. this is supposed to be a atomic watch that receives the signal and sets itself...help?
It may be that you watch is set to daylight saving time (DST). If you don't have a manual telling you how to remove this, you can get instructions from the Casio web site.
Accept terms
Click on "search" and the download your instructions.
Feb 14, 2010 | Casio GW1500A-1AV G-Shock Atomic watch
HOW DO U TURN OFF DST?
I have a caiso watch but not the same model as yours but they probably operate the same way.
The buttons are labeled A (top left), B (top right),
C (bottom left) & D (bottom right).
Press A and hold it until the transmitter symbol flashes.
Press C twice to obtain the DST setting screen.
Press D to cycle through the options until you reach "DST (off)"
Press A twice to return to normal mode.
If this doesn't do the trick, then copy of your manual can be obtained by going to their web site (world.casio.com/wat/download/en/manual/)
At this page you must enter the number on the back of the watch to obtain the correct manual.
Jan 09, 2010 | Casio G-Shock GW500A-1V Wrist Watch
G-shock Wavecepter is 1 hour to fast
(I posted this solution elsewhere but it should help you as well.)
Firstly, the manual that comes with these watches is absolute garbage,which is a stark contrast from the watches themselves. ( I love casiowatches - high value)
The good news is that Casio DID make a good manual for these wavecptor watches. If you go to this url
you will be at a spot where you can type in your 4 digit module numberand get a great document that tells you how to operate your unit andsome of how it works. (Adobe Acrobat - PDF file)
You should be able to hold in the "Adjust" button until the time zone starts flashing and push "Time Memo" and/or "Recieve" buttons until you are in the right time zone. Push "Adjust" again and your are done. The Manual above was very useful for me.
Hope that helps. :-)
Dec 05, 2008 | Casio G-Shock GW500A-1V Wrist Watch
How do I get the wave ceptor to come on ?Casio-2688
Try Googling (casio)(2688)(manual) without parens for instructions.
May 08, 2017 | Casio Watches
How do you set the time on a casio g shock watch????????
I had the same problem following recent daylight savings time (DST) change. The watch has three DST mode settings (ON, OFF, and AUTO). You get to the setting mode by pressing and holding the "adjust' button until the city time zone indicator starts to flash. Then press the "mode" button. This should give you the DST setting. Now press the "receive" button to cycle through the ON, OFF, and AUTO modes for DST. I set it for AUTO. I then existed the setting mode by pressing "adjust" again.
Now you can initiate a manual update of the time by pressing and holding the receive button. Put your watch by a window and make sure the signal strength indication is showing level 4 (full picture of satellite dish on my version). Give it a few minutes to down load new time.
After doing this the watch corrected itself and now shows correct time. Other wise I assume you could set the DST function to ON or OFF as well depending on whether you need to add or subtract the hour from the time.
Oct 26, 2008 | Casio G-Shock GW500A-1V Wrist Watch
Need too set time on my g shock casio watch
Press Adjust and hold until blinking city appears.
Press Mode until DST appears flashing.
Press Recieve until mode that you want appears ON OFF AUTO
Press Adjust until not blinking city code.
Mar 10, 2008 | Casio G-Shock GW300CA-1V Wrist Watch
Atomic watch
You most likely don't have the Daylight Savings Time (DST) set to AUTO mode. Just hold the ADJUST button until the time starts blinking. Then hit MODE and DST will show on the top. Hit RECEIVE as needed until you see AUTO in the bottom. Then just hit ADJUST 2 more times and you're set.
These instructions are actually for my Casio G-Shock MTG-900 but I imagine they're very similar for most G-Shock atomic watches.
Nov 15, 2007 | Casio G-Shock G701D-2AV Wrist Watch
Watches Logo
89 people viewed this question
Top Watches Experts
Jimmy Accardi
Are you a Watch Expert? Answer questions, earn points and help others
