Question about Insignia 5.1-Ch. Home Theater System with DVD/CD/MP3 Player/VCR
Insignia 5.1 home theater dvd won't load CD or DVD disk error
  • Anonymous Apr 03, 2009
    Everytime I try to load a disk it just goes wrrrr... and the display says ERR DISK. Why?
SOURCE: My Insignia 8" Portable dvd player does not detect dvd!
Try playing a regular CD first and take it out if it played. Then put the DVD and it will play fine because the player just realign its lense. Hope it will help
Posted on Jul 31, 2007
simplemitch
  • 752 Answers
SOURCE: INSIGNIA IS-PD040922
The laser has become damaged/worn-out. There is no fix for it as replacement parts are not made for it.
Posted on Sep 23, 2007
  • 170 Answers
SOURCE: Insignia NS-7PDVD portable DVD player - no picture
The unit is failing and is not worth repairing. There is either a short in the wiring that leads to the screen, the inverter board os failing, or the decoder is failing. These are all hardware problems.
There are several tests to find where the problem may be, but the average consumer doesn't have the ability or access to parts to fix these issues.
Posted on Apr 17, 2008
Agent Aaron
  • 265 Answers
SOURCE: insignia DVD player NOT WORKING
Hey jgconstable,
Before seeking repair assistance, there are a couple of options that you may wish to try out at home.
First, you may want to try cleaning any affected discs if you are only encountering this problem with a select few titles. Any kind of contaminant (dirt or lint) can often cause optical devices to not recognize a media title that is inserted. I would suggest checking each disc that is affected for any signs of scratches, and try cleaning them with a soft, lint-free (typically microfiber) cloth. Remember to use gentle, outward strokes from the center of the disc towards the outer edge.
Second, you may want to try cleaning the lens of the player itself. Many retailers (including your local Best Buy™ store) often sell commercial cleaning kits that are designed to be inserted directly into the player, in place of a normal CD or DVD.
If cleaning doesn't resolve the problem, you may wish to attempt resetting the player. Many DVD players will have either a physical reset button located someplace on the exterior casing, or be capable of a "soft reset." A soft reset is typically done by pressing and holding the power button for five to ten seconds, but please keep in mind that your owner's manual would have the most detailed information on how to reset the player to the original factory settings.
Should the player continue you malfunction, remember that you can always bring your DVD player into your local Best Buy™ store for service and repairs.
Hope this helps you out.
Sincerely,
Aaron
Go Ahead. Use Us.
Posted on Jun 10, 2008
SOURCE: Sony DVD Home Theater System remote control code
sony dvd surround sound remote codes
Posted on Oct 25, 2008
Player says error
Most likely your cd/DVD drive needs cleaning, or needs replacement. See a dealer, or send the unit to a Bose service center.
Dec 15, 2013 | Bose 3 2 1 GSX System
READ CD BUT NOT DVD NO DISK Disply
you need to replace the laser assembly in the drawer laser is going out
Jan 20, 2013 | LG LHT250SC Theater System
Cds will not play in loop. plays one cd and shuts off will not move to the next cd
Troubleshooting Solution
  1. Lift disk changer doesn't work comes message "Disk Error"
  2. Lift disk changer work fine but doesn't load a DVD
  3. Power light is ON but doesn't want to Power UP
  4. From the beginning start DVD movie the picture distorted and freeze
    avsystemparts.com
1. Possible Problem w/ Main Board PCB
2. The dive laser assy replace. or full complete 5 Disk changer ROM
3.More chance problem w/ Main Board
4. Problem w/Main board need replace it.
Dec 24, 2012 | LG LHT874 Theater System
How to reset DVD VCR?
put into dvd mode with no disc in tray turn on and hold stop button 5 seconds this will reset to factory video/audio mode
May 11, 2012 | Insignia NS-H3005 Theater System
Put movie in to play. Movie gets fuzzy and stops by itself.
Available parts: avsystemparts.com
Available parts
Jan 22, 2011 | LG LHT874 Theater System
Fios remote does not work with my Insignia is-htib102732 5 disc dvd/cd/mp3 dvd receiver
If the FiOS remote has a scanning or learning feature, you should be able to find a usable code to control your home theater system. Insignia is unable to provide a code for the reasons described here.
Jan 04, 2010 | Insignia Digital-to-Analog Converter for...
Place DVD in any slot and it says "reading disc" then "no disc"
When you get no disk error, that is usually because of a problem with the optical laser lens that is dirty, faulty or opaque, and will start operating on certain disks better than others.
In that case you will hear disk spinning, whirring and clicking, but the TOC (table of content track at start of CD/DVD will not be read, therefore the error.
Whe this problem is starting you may be able to read only CD, DVD or Blue ray, or for example only DVD-R and not +R , or only to read and not to write and so on. After more prolonged usage , often the unit goes losing the rest of functions, and ends up not reading anything at all.
If instead there is no noise, and disk does not spin at all , then there is a faulty motor, or the motor micro-switch is bad. This situation is far less common than the lens problem.
Try first using a CD/DVD or Blue ray lens cleaner disk to clean the lens. If that does not work you will need to disassemble the drive , and clean lens directly with q tips and isopropyl alcohol, or to replace the CD/DVD lens, or the whole drive unit.
May 04, 2009 | JVC THC5 Home Theater System with 5-Disc...
Need remote code
Many codes are on the website of the universal remote manufactuer.
If not, just ask them.
Jan 15, 2009 | Insignia 5.1-Ch. Home Theater System with...
Insignia 5.1-Ch. Home Theater System with DVD/CD/MP3 Player/VCR Logo
128 people viewed this question
Top Insignia Audio Players & Recorders Experts
Alan Matzke
Alan Matzke
jason
Are you an Insignia Audio Player and Recorder Expert? Answer questions, earn points and help others
