Question about Garden
Got spark starting fluid wont turn it over - Garden
  • 32 Answers
Check to make sure you have compression in the cylinder, place you thumb over the empty spark plug hole and pull the cord, if it blows hard against your thumb then it has good compression, if it has spark and compression it will start unless it is not getting fuel. Be careful when using starting fluid as to much of it can damage the engine. If there is no pressure against your thumb then there is a copression problem where the piston rings maybe bad or something is stuck open in the intake or exhaust.
Posted on Mar 17, 2011
96 ciera 2.2 ran fine. parkedat night next morn wont start.its getting fuel and fire but sounds like its not even trying to start
Check for spark.. pull one spark plug out set it on bare metal(away from cyl hole fuel could light from spark) turn vehicle over and look for spark should be a nice lightning bolt looking spark... blue spark is weak spark.. and see if it's getting spark...,, if not,,."try new plugs.,wires,distributor cap&rotor " also first.spray a little starting fluid down the injection system turn it over and see if it fires.if it does then it's a fuel issue prob not electrical... try that.hope it helps
Dec 31, 2016 | Cars & Trucks
1990 oldsmobile wont start
Chances are its an ignition problem if nothing happened by using starting fluid. Have you pulled the plug wires and checked for spark ?
Feb 17, 2014 | 1990 Oldsmobile Cutlass Ciera
2001 dodge stratus 3.0l automatic cranks but wont start not even with start fluid
check the fuel pressure and make sure you got the correct pressure
Jan 25, 2014 | 2001 Dodge Stratus
2004 Chevy Van 2500 turns over but wont start
Try spraying starting fluid into the intake. Remove the air filter to do this. If it starts for a few seconds then you have a fuel delivery problem. If it does not, then you have an electrical problem with the ignition. there are 3 things needed for an engine to run if it turns over. Air, Gas, Spark (fire). No air filter solved the easy air issue. Add starting fluid answers the fuel issue. Only leaves spark after that.
Aug 03, 2012 | Chevrolet Cars & Trucks
Wont start,,turns over,but no spark. wont even start with starting fluid
If there is NO spark then starting fluid cant start any thing. I would be checking the crank sensor first for the spark then the ignition coil pack.
Feb 27, 2011 | 1995 Oldsmobile Cutlass Ciera
I have a 1990 yamaha 100 cc 4 wheeler and we replaced the spark plug and cleaned out the carb and its turning over but wont start. I know the spark is fine but it just wont turn over, any ideas? maybe...
If the spark is fine, then it is not wiring. It is going to more than likely be fuel. Try spraying a little starting fluid in the air filter. If it starts, then you will know that it is fuel. Make sure that the carb is getting fuel from the tank. A lot of times the filter in the tank will get plugged up. If the bike doesn't start with starting fluid, then the problem is not fuel and will have to be either the timing is off or not enough spark. The spark should be blueish purple.
If this helps you please rate by checking the 4 thumbs up! Thanks for using Fixya.com
Jan 12, 2011 | Yamaha G5 Motorcycles
I have a 1999 gmc Yukon it is getting fuel and spark i even sprayed starter fluid in the intake but it still wont start it turns over good but wont start
ok make sure you have good fuel pressure
you must have good spark must fire a spark tester
if all that is good then check compression
and don't use STARTER FLUID on a GAS ENGINE it can blow a hole through the piston
hope this helps
Nov 12, 2009 | 1999 GMC Yukon
Garden Logo
32 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
