Question about NetGear WGR614 Wireless Router
Earlier this evening I was trying to add my son's laptop to our wireless network. I was able to do so by hardwiring into the router. But when I went to go back and use my laptop that we always have been able to use without hardwiring I was unable to do so.
  • 415 Answers
A couple of things:
1. make sure that the wireless adapter is enabled - under NETWORK CONNECTIONS
2. for now at least just set the configuration to "obtain automatically" and make sure the
gateway number is the same as your router... ie 192.168.xxx.xxx
3. Go on your router (via web interface... see manual for instructions) and make sure that DHCP is enabled
then... go to RUN and type in cmd a black window with text in it will pop up and a cursor will be flashing in it. Type ipconfig and hit enter (some windows versions "winipcfg" instead) and see what it is showing for your ip address. It should be 192.168.xxx.xxx for IP address.
Double check how you have the wires in the router. Some wifi adapters perfer to use their own software to configure the first time...
Posted on Mar 17, 2011
I have my router setup hardwired to my desktop and wireless to my ROKU netflix reciever. I want to allow my son to connect to the wireless network with his laptop but he cannot connect. He connects to the...
on your browser. got 192.168.1.1
username = admin
password = password
then enable Broadcast SSID. This is the name of your wireless connection. You can name it anything.
You can also put WEP password to prevent others to connect to it.
tell your son to scan for network access again, then chose the name of the wireless connection you chose with the password.
Hope this helped you
Apr 08, 2011 | Belkin (F5D8235-4) Wireless Router
I cannot connect my laptops to netgear. I need to change to password for my netgear wireless router. My son says his exbox says that I have multiple networks with the same name.
Connect temporary your laptop with ethernet cable at the router, go to router's settings page and DISABLE the wireless. After a while set up the wireless network again.
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Sep 03, 2010 | NetGear WNDR3300 - RangeMax Dual Band...
Laptop cannot aquire network address from wireless router
If you connect the computer to the router , it works.
That means the wired connection is OK.
Open the set up page of the router check the wireless settings of the router.
I think your network is secured and you are not typing the correct network key.
just open the router set up and check the wireless settings .
Make sure that the DHCP server on the router is enabled
Click Here for step by step solution
Apr 30, 2010 | D-Link 802.11g Wireless Router WBR-1310...
Cant get wireless router to work on laptop
First, try to connect your laptop hardwired to the router, if it works fine, its just the wireless configuration. Make sure you are using the correct wireless network key to connect to your wireless network. Go to the Control Panel > Network Connections > Right-click Wireless Network Connection > Properties > Wireless Networks Tab and delete all the names listed under Preferred Networks box. Click Ok. Right-click on Wireless Network Connection again > View Available Wireless Network > Choose your own network and click Connect. If it asks you to type the network key, type in your WEP or Wireless Network Key and press connect. That should do it.
Oct 06, 2009 | Computers & Internet
Setting up and configuring networks
The main problem on your setup is your router. This BEFSR41 doesn't have wi-fi or wireless capability. You can only go online on your laptop if you connect it hardwired to the router just like your desktop. You must purchase a wireless router if you want your laptop to work wirelessly
May 09, 2009 | Linksys BEFSR41 Cable/DSL Router with 4...
Have wireless network at home trying to add my sons laptop to network but have forgot security key/passphrase which laptop is asking for
All you need to do is log into the router usually with the pc that is attached to the router (wired) by typing into the run command box http://192.168.1.1 Depending on the brand of router you'll either put in admin and no password or admin for the password or admin and password for password. Once in the router go to the wireless security tab and you can see the network key. Hope this helps
Nov 06, 2008 | Computers & Internet
Connection to iMac not working
the easiest way is hard wire a windows laptop and use the CD that came with the router.
Oct 13, 2008 | Microsoft Broadband Networking MN-500...
Hardwiring laptop
hello!
the number ports are the actual ports at the back of the router where you will plug the cable to connect your computer directly to the router.
to find the network key for your wireless connection, you need to connect your computer directly to the router and access the setup page of your router. You need to go to the wireless settings and get the wireless network key from there.
Aug 27, 2008 | Belkin (F5D5231-4) Router
NetGear WGR614 Wireless Router Logo
27 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
