Fan runs constantly - Computers & Internet
    Brigadier General:
  • 10,406 Answers
The fan _should_ run constantly, in order to cool your computer.
If your computer is "dusty" inside, then the dust is insulating some parts, causing those parts to get warmer, and the fan to spin faster (with more noise) to try to cool those parts.
Posted on Mar 17, 2011
My car fan come on when the car at normal temp constantly. I just replaced a cracked radiator and thermostat. Now my car fan constantly run when the car is in park or stand still
you have created an overheating problem by replacing the radiator and the thermostat and not ensuring that there was no air lock in the cooling system
The fan is now constantly running because the coolant sensor is reading a high coolant temperature
First step is to ensure that there is not an air lock in the cooling system by bleeding the air out and if the fan still runs then check the way the thermostat was installed
Apr 15, 2015 | 2006 Infiniti M35
Cooling fan stays on
Just had that problem had to put in regulator. Well my mechanic did.
Jul 18, 2014 | Skoda Octavia Cars & Trucks
The fan on my Side by side GE Hotpoint HSM25GFRFSA refidgerator was making a constant whining noise from the condenser fan. I replaced the fan and the nose stopped but it seams the fan is running...
the fan only runs when the compressor runs . are the coils clean. and if fan was bad maybe it was running all the time . run time is controled by the min pc control. .it may have to be replaced it is located in the back on the left side under the plate cover .. mm hope this helped .
Oct 21, 2010 | GE HSM25GFTSA Side by Side Refrigerator
Desktop computer fan runs constantly
Desktop fans do run constantly, you cannot avoid this.
The reason they get loud is because there will be a build up of dust on the fan blades.
To rectify this problem turn off the computer and remove the power cord from the rear. Then you need to remove the side panel from the base unit to expose the motherboard.
You will see that inside the case it is full of dust. Look at the CPU fan (the fan on the motherboard) also take notice of any case fans too, they are at the back.
To clean the fans and the case you can use a clean dry paintbrush or compressed air.
Once the inside of the case is cleaned you will see a noticeable drop in noise.
Regards.
Jul 03, 2010 | HP Compaq Presario SR2150NX PC Desktop
Exhaust fan is running constantly, without even
It could be that the fan button is sticking or a contact has welded itself closed therefore its getting power all the time.
Mar 08, 2010 | Maytag Appliances Over-the-Range Microwave...
Compac Presario F700 makes constant humming noise
Sounds like its the fan . The more demand you place on the system makes it run hotter so the fan speed automatically increases to compensate
Jan 19, 2010 | Compaq Presario 700 470024-192 Notebook
My fan is running constantly computer seems
Yes, the fan should run continuously else the processor will get toasted. It get very hot without the fan even when the PC is not doing anything visibly.
Dec 15, 2009 | Acer Aspire M1201 Athlon X2 320 Gb PC...
Goodman a/c blower runs on auto and humidity problems
Is the air cold inside? You are talking about the fan inside? Have system check for freon but more than likely, it sounds like a t'stat problem. And it's not normal for the fan to run constantly.
Jul 05, 2009 | Goodman CLQ36AR49 Air Conditioner
Fan runs constantly
one reason that a CPU fan may be running constantly is that it may not be able to cool the cpu down. usually this could be due to dust or debri clogging the incoming or outgoing vents or even dust accumulated on the fan itself or the heatsink.
Jun 03, 2009 | HP Pavilion a1110n (PX743AA) PC Desktop
Fan / Compressor runs constantly
Condenser fans (the fan next to the compressor) do run all of the time. That is normal.
Sep 18, 2008 | Sub-Zero 661/F Side by Side Refrigerator
Computers & Internet Logo
David Payne
David Payne
