Question about Sony STR-DE945 Receiver
My STR-DE945 5.1 channel, works "fine" just a small issue that started to bother me... when i start the thing the 5 speakers have sound (also the bass), but after like 5 or 6 minutes, i hear a clicking sound and then the 5 front speakers just shut off, and they have no sound at all, if i turn the device for a couple of hours, then they start with the sound again, this has occurred to me every day of this week... (10 march 2011) till today... now that the weather is a bit hotter, could it be that my device needs some inner cleaning? it has a dvd player sitting on top of it, but it is on a well ventilated space... I wanna know what to do... Every speaker works just fine for like 5 minutes, then the 2 frontal speakers just stop working after the Receiver makes a clicking sound
  • 26 Answers
Commonly your problem is a result in bad thermal connectivity on the power transistors.
Each power transistor is coupled to a heat sink with thermal paste / thermal conductor. When they run hot, they **** more power. There is commonly a thermistor which acts as a protection from blowing out the transistors.
There is probably a transistor that is nearing the end of its life. It will work for a while (when you power up the system) but after a couple of minutes, it starts to **** power, heat up, and trigger an thermistor up stream of the transistor, and it shuts the power stage of the amp off.
This is unfortunately a problem for a technician, or you would need to be armed with a schematic to be able to work with this problem effectively.
Posted on Mar 17, 2011
Why is center channel dead?
Sony STR-K840P Sound center speaker - Questions - Fixya
www.fixya.com > ... > Sony > Sony STR-K840P
... sound from center channel during viewing, or during speaker level test- all other speakers emit tone, but center is dead. I have optical digital cable and hdmi ...
Sony STR-K840P Sound center channel - Questions - Fixya
Sony STR-DB940 pulled back from the brink - Page 2 - Badcaps ...
www.badcaps.net > ... > Audio Equipment Discussion
Jan 01, 2016 | Sony STR-K840P
I have a sony str de998 receiver,here is my issue.when first turned on,i get sound from the surround speakers,but after a few minutes,i get no sound from them.i run the test tones,and again,i get soun
Contact any service technician. Its audio output circuit board need to be troubleshoot. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Sep 07, 2014 | Sony STR-DE997 7.1 Channels Receiver
My sony receiver STR-DE135 is showing a protector message
Check for shorted speaker cables, or even a bad speaker. I'd start by disconnecting all speakers, see if the indicator goes out. If so, try one speaker at a time until you find which channel is bad, and then examine the cables carefully for things like a stray wire strand. Less likely, but possible is a shorted speaker. If you disconnect them all, and still have the protector circuit on, it's an internal issue, and you're going to need a technician.
May 30, 2011 | Sony STR-DE135 Receiver
Str-gx800es sony receiver problem- right channel speaker sound is 'static', low and distorted. I have checked checked all speaker and output/input source cable connections with no luck. All left channel...
If you have checked the speakers and wiring, the right channel has a audio driver or output problem, which explains the low volume, static, and distortion. A service technician will be required to fix the receiver so it will balance the left side.
Jan 10, 2011 | Sony STR-GX800ES Receiver
I have set up a BOSE Accustimass System with my STR de485 receiver. How do I adjust the treble/bass?
hi,
if u are using bose speaker system then remember one thing. go to speaker setup and select all the speakers as large not small. then only u will get a good tone. bose speakers will handle the output power of ur amplifier.
u can only adjust the bass and treble of ur frond Channel speakers. for that
select multi channel surround sound and the increase and decrease the bass and treble
ok
Dec 31, 2010 | Sony STR-DE485 Receiver
I have a Sony STR-DE845 5.1 Channels Receiver and it has been functioning flawlessly for years. Recently though, it has started producing a loud "pop" sound within a minute after turning it on....
You probably have a discrete component failing inside it.
Generally speaking, an amp protects itself from heat, shorts and overloads.
Overloads can be from excessive periods of high output and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced hands-on tech.
Dec 22, 2010 | Sony STR-DE845 Receiver
Right front channel not working
try to check balance adjustment if working.
Apr 16, 2010 | Sony STR-DE475 Receiver
Sony STR-DE525 Left Rear channel not working
Most likely the amp for that channel is defective. If memory serves me correctly, there is a small amp chip mounted on the heatsink that is for both the left and right rear. I would change that first. It should have about 5-7 pins.
Dan
Nov 30, 2008 | Audio Players & Recorders
Poor voice track but great sound.
Unhook your center channel speaker and see if it still goes into protect.You might have bad center speaker
Sep 09, 2007 | Sony STR-V555ES Receiver
Sony STR-DE945 Receiver Logo
116 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
