Question about Kenmore Dishwashers
How do I remove the upper wand in my Kenmore Dishwasher?
  • 32 Answers
What model is it ? it should have a scewed in center retainer that it rotates on.
Posted on Mar 17, 2011
No power
Those have a tendency to short out in the wands. Use a test light or meter to find out where the power stops. Test lower wand first then upper then hose, then unit. Replacement wands are available, there's really no fixing them. I'll include a link to the wands I'm referring to.
Good Luck!
Lower (most common)
http://www.vacuummedic.com/product.php?id=452
Upper (very common)
http://www.vacuummedic.com/product.php?id=450
Feb 12, 2013 | Kenmore 25512/ 25513 Progressive Canister...
Belt not turning
Good Luck!
Lower (most common)
Upper (very common)
Feb 07, 2013 | Kenmore 25512/ 25513 Progressive Canister...
The unit is 6 years old. Dishes on the top rack do not get cleaned. Dishes on the bottom rack are fine.
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher
Spray Arms not Spinning
How to Buy
Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The
Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Jan 06, 2011 | KitchenAid Dishwashers
Upper water wand does not rotate ? maytag dishwasher How can we solve this problem?
Remove the wand and clean it out as well as the water inlet hose that attaches to it. Make sure you have good water pressure or it will not turn.
Oct 10, 2010 | Maytag MDB7100AWB Dishwasher
How to replacement the upper dish rack on Kenmore dishwasher
On the front end of the rails, there should be plastic or rubber stoppers. Remove these and the rack should roll right off as if youre pulling it out to load it.
Feb 06, 2010 | Dishwashers
Kenmore Progressive Canister Vacuum -Model 116 22812200.
hello... you might want to try checking the elbow or neck of the power nozzle for blockage. Remove the wand from the head and look through it. Also look through the wands . If there is no blockage, maybe there is a problem with you nozzle. Reattach all the parts and turn on the machine, turn on the power nozzle. Can you hear the other motor start? If so, check to see if the belt is turning. If it is not, and you definitely hear the secondary motor, then you need a belt. If it doesn't make any sound then, with the machine still running, press the button on the upper part of the power nozzle, this should reset your motor. I hope these tips helped ya, let me know, by giving feedback when asked. thank you, Rene (The Vacuum Doctor)
Nov 10, 2009 | Kenmore Vacuums
Where do I find the serial number for the Kenmore Ultra wash III dishwasher
Look at following areas for the model number
* On Right Hand Side Of Upper
* Front Tub Or Door Jam
* On Flange Behind Dishwasher Door
* Behind Latch Strike
* Upper Left Corner Of Frame
Jul 19, 2009 | Kenmore 24 in. 15932 Built-in Dishwasher
Upper rack spinning device fails to aquire water and does not spin
Jeff, When a dishwasher acts like this, the most common problem is a blockage in the sump area, underneath the lower spray arm. Removing any/all filter and covers down there (screws will need to be removed) and inspecting with a flashlight, remove all debris (watch out for broken glass!)  Also, inspect the "impeller" that is turned by the wash motor for damage or being loose while you are down there.  Reassemble and test out.
If problems remain, the next most common problem is a failed wash motor.  It is common over the years for it to weaken as it heads towards total failure.  These motors, when they fail, can not be repaired, rather they must be replaced.
Please post back with what you find, OK?
Apr 14, 2009 | Kenmore 24 in. 16152 Built-in Dishwasher
Open Questions:
Dishwashers Logo
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
